Question about Curtis DVD5091 Theater System
How do I hook the tv up to the speakers?
I get no sound through tv only dvd
  • 3 more comments
  • anthony98453 Dec 26, 2008
    i got the same problem.
  • Ben Strength Jan 02, 2009
    The surround sound only works when playing a DVD.I want to watch TV programming with the surround sound on.PLEASE HELP!!
  • chrysdw Jan 24, 2009
    I have a Philips tv with only 1 coax port in the back (it's an older tv). We bought a Curtis Home Theater 5.1 (a dvd home theater). We would like to use the surround sound with the tv (cable) not just with the dvd player. Can we/how do we connect the surround sound to work with the cable box and the dvd player? Is it possible to use Curtis Home Theater as a true surround sound system or is our purchase only good for a dvd player?
  • siddsmith89 Feb 19, 2009
    want to hook it to the tv to have true surround sound
  • Anonymous Apr 13, 2009
    TV audio plays really loud through speakers when the dvd power button is off and there's no way to control the volume. Turn it on and the audio returns the the TV speakers. I would really like to just use the speakers for the TV and not just the DVD player. I've checked just about every setting on the tv and dvd player.
We had to hook sound cables from DVD player into digital cable box, not tv and now surround works in tv mode as well as dvd.
Posted on May 04, 2009
  • 548 Answers
Check all of your connections (you've probably done this 1,000 times already) but also check your TV manual. You may need to turn off the TV's speakers by making a menu selection thru the TV. Check the audio selector on the home theater, the one I have (different brand) makes me select the audio source each time I switch from cable, to dvd, to vcr. So when I want to watch a movie, I have to tell the TV to pull the video from the DVD source and the home theater to pull the sound from the DVD.
Hope this helps.
Posted on Dec 26, 2008
2 Suggested Answers
SOURCE: Can't get the surround sound to play the rear speakers and small front speaker
Sounds like it's just in 2 channel stereo mode, only 2 speakers working out of 5 and a sub, look for a selector switch for switching to 5.1 surround, as far as the no video problem try replacing the cable for the video connection.
Posted on Aug 07, 2008
Do not know how to wire my sa-w10 speakers together
For surround sound, you need an A/V receiver with 5.1 or 7.1 surround capability. Depending on what kind of receiver you have, the DVD player, satellite/cable box, etc hooks to the receiver, those signals go out to the TV, and the speakers hook to the receiver. The receiver decodes the signal from the cable/satellite box or DVD player and routes it to the appropriate speakers. If the TV program or DVD isn't HD or coded for surround sound, the best you can expect is 2.1 channel stereo sound. OR, you can hook everything (DVD, satellite/cable box) to the TV and run an optical cable from the Digital Output of the TV to the receiver, which is basically the same thing, just a different way to hook everything up. Hope this helps
Feb 23, 2014 | Audio Players & Recorders
Surround sound for DVDs.
If your DVD disc supports it, you will have to enable surround sound from the DVD, as well as the speakers.
May 10, 2008 | Koss KS3102 System
How do I hook it up to my TV. or do I hook it up to my DVD player?
You usually hook it up to your DVD player, but if your tv also has surround sound out, give that a try, see which you prefer.
Sep 04, 2010 | Logitech X-530 Computer Speakers
No sound
More than likely you need to go into your menu settings. Check to ensure that your TV speakers are enabled. The previous owners may had it hooked to theater system
Oct 20, 2009 | Toshiba TP50G60 50" Rear Projection...
55HDX99 TV with Sony DAV-HDX500
Connect RCA Red-White audio cable to INPUT of DAV-HDX500 and hook it to TV AUDIO OUT pins at back of TV.
Now select INPUT in DAV-HDX500 to get TV sound in Sony system speakers.
Apr 19, 2009 | Televison & Video
I need help hooking up my tv and dvd player to my surround sound
for your dvd player you just go from audio out on the back of the dvd played to the audio in on the surround sound. and you would do the same for the tv if it has an audio out. your surround sound shoud have more than 1 audio in. and then when you swicht from tv to dvd you might have change the channle, setting, source, or what ever it might be called on the surround sound. and if your tv does not have a audio out contact me at swinginflames@gmail.com and i try to help you. hope that works :)
Feb 22, 2009 | Durabrand 5.1 Surround Sound Computer...
Need home theater hooked to TV with built in DVD
This is the easiest way 2 explain it. Hook up on the home theater should be labeled in and out. same as on the tv. The TV might no have that feature as the DVD is built in. You might just have an option for sound from the TV/DVD to the home theater. Again OUT from TV IN to receiver. Same with any other device set up.
Jan 27, 2009 | Durabrand 5.1 Surround Sound Computer...
How to hook up additional speakers to the TV
If you have a surround sound system, (amplifier and speakers), run the DVD speakers out wires to the amplifier IN. Thi way, you don't even need the TV speakers.
Jul 26, 2008 | Sansui HDLCD3200 TV
Connection to a portable tv
The RCA set on a tv [Red /White /Yellow] are INPUT[ VCR/DVD player] not out put. Hook the speakers up the the 3,5mm earphone jack though you will need a conveerter plug like this
Jun 30, 2007 | JBL CREATURE II Computer Speakers
Curtis 5.1 Home Theater System
can it hook up to the cable and have the sound can out the speaker when wacth tv . so one can here it with not be so loud for the for any oneself,in the roon with then .
Jan 06, 2007 | Curtis Lifestyle DVD System
Curtis DVD5091 Theater System Logo
916 people viewed this question
Top Curtis Audio Players & Recorders Experts
Computer Links
NOEL
NOEL
Are you a Curtis Audio Player and Recorder Expert? Answer questions, earn points and help others
