Question about Intel Desktop Board D815EEA2 (BOX815EEAA2) Motherboard
In-built VGA of the motherboard is not working so, I placed PCI 128 MB card and started the computer it is working nicely, but computer sometimes hangs and color mode is disordered.... so I went to BIOS to test whether card is working or not... but by Mistaken on Video Configuration option, I specified AGP, previously there was PCI. when I saved BIOS and ran the computer the display has gone no signal on monitor... How can I again re-store PCI option on Video Configuration on BIOS... Please help me...
  • Ohm Lama
    Ohm Lama Apr 18, 2007
    In the motherboard it is only J9G2 3 pin terminal the cap is in 1-2, but when i removed and placed 2-3 and restarted but same problem agin I placed 1-2 and restared but still same problem... not working....
    President:
  • 2,961 Answers
Leave the connection to graphics card in, and take the left side panel off the pc and on the motherboard, you will see either a terminal marked CLRCMOS,JBAT1, CLRRTC, RTC, this is the cmos clearing jumper to revert back to default and the need to reset the time and date. If it's JBAT1 3 pin terminal, the cap will need to be taken off pins 1-2 and put across pins 2-3 then back to pins 1-2. If it is one of the others and only a 2 pin terminal, use a jumper cap like the one on the back of your hard disk and cdrom drive and put it over the 2 pins. start up pc and you should get the screen a beep and it will say press f2 for cmos setup, correct the date and time and the bios should be reset to vga, so change to pci again.
Posted on Apr 18, 2007
  • andrew pester
    andrew pester Apr 18, 2007
    Is a J9G2 terminal a clear cmos terminal because i don't recognise it as this.
    Refer to your manual to clear settings, you can also try removing cmos battery for 10 minutes, it may clear it without the terminal shorting.
Hi, I need standard spec info of VGA built on Asus P5GC-MX 1333 whether 64 Mb or 128 Mb. Many thanks & regards, Richard
you can use up to a maximum of 224 mb of your computer's RAM for the onboard video chip to use. You can install a video card with any amount of memory (which would give you a lot better video performance).
Jun 18, 2011 | ASUS P5GC-MX 1333 BULK C2D LGA775 945GC...
I have intel 845 glly desktop board with 256 mb SDR. When I added 128 mb SDR in the second slot it is not recognising it. How to add 128 mb SDR with 256 mb SDR. When I fix 128 mb ram in first slot and...
1st try to exchange the cards in the slot.
2nd try another card
3rd ur RAM slot may not be ok
4th ur RAMs may not be compatible
5th ur new RAM card may not be ok
use same type of RAMs, and same size...
if u have 256, add 256
if u ahve 128 add 128
if u have SDR then dont add DDR
getting compatibility is little difficult...
some times no combinations can work...
note...technology keeps changing...so a old RAM card that was bought years ago may not be compatible with a new RAM card....
even i got all my old RAM cards(256+128) removed and got 2 - 512mb of the same type fixed...even i had issues with my RAMs for 6 months...
Dec 27, 2009 | Intel D845GLLY Motherboard
Intel Desktop Board D815EEA2 boot problem
Hi and welcome to Fixya!
this means that the BIOS is corrupt ..
Thanks for using FixYa!
Jul 18, 2009 | Intel Desktop Board D815EEA2 Universal...
Intel VGA Built in #N68011NW800637 MP25 BA92-02111A. i LOST MY CD FOR MY MOTHERBOARD
Hii, you can download all the driver of your Intel motherboard at
http://downloadcenter.intel.com/default.aspx?iid=gg_work+home_dowloads#
Go this site and at the left hand side, go to the desktop board and select your exact motherboard model. After selecting the model you just download the driver as per your requirement and install it.
Apr 12, 2009 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
ABOUT GRAPHIC SUPPORT
try to check it in your manual. i mean in the manual of the motherboard if what VGA card is compatible with or visit the website or the motherboard you have.. hmm you must buy VGA card to upgrade your graphics that compatible in your motherboard... example AGP slot 256mb VGA card, or PCI express slot 256mb or 512mb VGA card.. ^^
Feb 06, 2009 | Intel D102GGC2 Motherboard
Best Graphics card for my Pc
Hi Dr,
Best video card for you're Intel D845GVSR would be XFX GeForce 6200 Video Card - 512MB DDR2, PCI, DVI, VGA, TV Out. XFX carries a Lifetime Warranty.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3735736&CatId=319
Enjoy!
Mike
May 09, 2008 | Intel Motherboard
Intel 845 glly board please solve the problem
Hi Nadeem Nawaz,
No board will show display without memory. Your motherboard must run memory type;
Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts.
Unbuffered non-ECC DIMMs only.
Maximum total system memory: 2 GB; minimum total system memory: 64 MB.
Serial Presence Detect (SPD) DIMMs only.
Intel link showing memory specifications.
Intel Desktop Board D845GLLY
http://www.intel.com/support/motherboards/desktop/d845glly/sb/cs-012825.htm
If your memory is within Intel's memory specifications & you are not getting display on your monitor. It is possible that the integerated on board graphics (Shown on page 13 in your user manual), may be defective.
You can add a PCI video card to the PC. The Intel D845GLLY will auto detect the PCI video card. No need to enter the bios & make changes.
Please keep this in mind. The integrated video card is PCI, if it has failed, there is a good chance it will not see the PCI add in video card. If you can find a used (Working) PCI video card to test in the PC.
Intel Desktop Board D845GLLY main website link.
Luck!
Apr 19, 2008 | Intel D845GLLY Motherboard
Is there any PCI slot for graphics card in Intel D845GVRS
hi buddy, the graphics card u r talking about is an AGP not PCI, And most of the 845 chipset series do have an AGP slot, so idont think there is any issue, but do check for the AGP slot.
Bye, enjoy...
Dec 15, 2007 | Intel D845GVSR Motherboard
Intel Desktop Board D815EEA2 (BOX815EEAA2) Motherboard Logo
151 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
