Question about Motorola Mobility H500 Wireless Headset
Motorola headset h500 and LG380 connection problems
I can pair the two together and see it in my device list but the phone says the headset is out of range or turned off when I try to connect. They are within 1 foot of each other.
Go to your Bluetooth set up, and select power on... it should change automatically, and all should be well...
Posted on Feb 26, 2009
What do i type when it tells me to enter "passkey'?
Posted on Feb 15, 2009
I need help pairing my motorola h500 to motorola i580 phone
  1. Make sure your phone's bluetooth is on.
  2. Go to MENU > SETTINGS > CONNECTION > BLUETOOTH LINK > SETUP.
  3. Scroll to power then press change.
  4. Scroll to ON the press select to turn on the bluetooth feature. Bluetooth feature remains ON until it is turned off.
  5. With the headset power off, press and hold the CALL button for 6-10 seconds until the blue light indicator turns on and remains steadily lit. If it does not stay lit, turn off the headset. To turn it off, press and hold CALL button until blue light stops.
  6. While holding the CALL button on the headset, on your phone select MENU > SETTINGS > CONNECTION > BLUETOOTH LINK > HANDS-FREE > LOOK FOR DEVICES. The phone lists all bluetooth devices it finds.
  7. Select Motorola H500.
  8. Press OK or YES to pair the headset with your phone.
  9. Enter the passkey 0000.
  10. Press OK.
Oct 08, 2009 | Motorola Mobility H500 Headset
My iPhone 3G does not discover my Motorola H500.
Try this link. It solved my issue www.scribd.com/doc/280088/motorola-h500-bluetooth-earpiece-manual. Basically what you need to do is power the earpiece off. Make sure that your IPhone is not currently attempting to discover bluetooth devices (i.e. Bluetooth is OFF). Hold the On button on your earpiece (it has the symbol of a phone on it) for 6-10 seconds. The light on the earpiece remains lit. Now your earpiece is in discovery mode. On your IPhone, go to Settings, General, Bluetooth. Turn Bluetooth ON. Now your phone and your earpiece are both in discovery mode. When you see "Headset" listed, select it and enter the password "0000". Your IPhone is now paired with your H500 headset.
Mar 24, 2009 | Motorola Mobility H500 Wireless Headset
How do I use motorola bluetooth H500 with razor phone?
On your bluetooth headset, hold down the power button until the light stays on steady. (it will blink when you initially power it on, but continue to hold for another few seconds for the steady light!) Your headset is now in pairing mode.
On your RAZR, press Menu > Settings and Tools > Connections > Bluetooth > Handsfree > Look for devices. Your phone will then scan for any bluetooth devices that are in pairing mode. When your bluetooth headset pops up on the list, highlight it and press ok to connect.
your cell will then ask permission to bond with the phone, select yes. It will then ask your for a pin. The pin will be 0000.
Dec 26, 2008 | Motorola Mobility H500 Headset
H-700 motorolla bluetooth
1. Bluetooth enabled?
Hold down the connect button on headset until steady purple light comes on, then open the boom.
Search for Bluetooth devices on the phone. When asked for a pin, use "0000". Now the H700 will show up in the Bluetooth device list, but it will not connect. Put the headset in pairing mode again, this time go to the h700 listed on the phone and select connect. Now the devices will work as normal. When you open the boom on the h700, it will connect to the phone.
Dec 19, 2008 | Motorola Mobility H500 Wireless Headset
H500 Headset Problem
This is the same headset I have.
I believe you have to hold the power button in until the light starts to blink, then tell your phone to look for the device. Don't forget to remove the device in your blackberry if you are still using it.
Nov 04, 2008 | Motorola Mobility H500 Headset
Pairing H500
You need to get the device, to communicate with your bluetooth.
To do this, put the devices to be connected close together.
while the phone et,c is searching for the device. press any buttons on it. i.e vol up/down on/off.
so that the receiving device can locate its signal.
this is known as pairing, it,s already been paired. to a different device.
you need it to find yours.
Mike @ Compurepair.
Sep 16, 2008 | Motorola Mobility H500 Wireless Headset
Moto Razr V3 + H500 bt 'unable to connect'
have the firmware downgraded on the phone and that should fix the phone.
Mar 04, 2008 | Motorola Mobility RAZR V3
How do you connect a Motorola H500 Headset to a motorola razor v3m
On your RAZR, press Menu > Settings and Tools > Connections > Bluetooth > Handsfree > Look for devices. Your phone will then scan for any bluetooth devices that are in pairing mode. When your headset pops up on the list, highlight it and press ok to connect.
If the device asks permission to bond with the phone, select yes. It will then prompt you for a pin code. The pin will be 0000 .
Enjoy!
Jan 14, 2008 | Motorola Mobility H500 Headset
Motorola Mobility H500 Wireless Headset Logo
59 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
