Question about Weber Gas Go-Anywhere Grill
Have regulator need attachment to the burner for a go-anywhere
The regulator for the go-anywhere table top propane grill is missing the attachment for the burner. do u have one and do u have a picture of it??
  • 32 Answers
SOURCE: jenn air 32 in. 4 burner gas grill
HAVE YOU TRIED THE ORIIGONAL TANK? SOME COMPANIES HAVE SPECIFIC TOLERANCES FOR FITTINGS THAT MAY NOT WORK W/ OTHER ITEMS.
Posted on Apr 08, 2008
  • 3 Answers
SOURCE: coleman instastart propane stove regulator wanted
Check to see if Coleman has an attachment to replace the regulator, so that you can use a five gallon cylinder with your stove and your own regulator.
Posted on Jun 29, 2008
keemo68
  • 1263 Answers
SOURCE: regulator freezing up
did you replace the regulater with a manufatures replacement for you grill or did you use an after market one? the reason i ask is because propane is very cold in liquid form and if your regulater allows more of the liguid to go to your burners than it should the moisture in the air will contact the outside of your regulater and freeze up on it. excessive propane would not change the color of the flame, however the i would check the burners to make sure that there are no blocked holes this would cause this to happen as well you are still safe to use the grill but cleaning the burners is a good idea. also there is a rating on the regulater make sure it matches the old one you replaced it with........good luck
Posted on Aug 31, 2008
meBNme
  • 334 Answers
SOURCE: BBQ Galore Capt'n Cook 4 burner gas grill won't get hot.
You can buy a gas pressure guage from any HVAC supply house, and possibly at a gas utility office or the retailer that sold the grill.
It taps into the manifold, or gas valve.
For most LP systems you are looking for 11 to 14 PSI but double check with your system. You may can find it on the owners manual or on the data sticker.
Be shure to shut off the gas before you remove the plug and hook up the guage. Most plugs are either allen wrench or square head plugs.
Posted on Dec 06, 2008
gcken
  • 140 Answers
SOURCE: Kenmore Gas Grill 141.155401 issue with Propane tanks
Posted on Apr 14, 2009
Need a regulator for Thermos Grill 2 Go
I bought this to replace the regulator I lost for my Thermos Grill2Go. Little modification to the grill and it worked like a champ. Portable Propane Table Top Regulator 1 by 20 Female Throwaway Cylinder... need-regulator-thermos-grill-2-go-2i4ggwcr0e0sverpwaph0wvr-1-0.jpg
Aug 22, 2012 | Thermos Grill2Go Fire+Ice
No sound of gas
Tyrn off tank open conrtol knobs to burners , turn off burners turn tank on slowly see if gas comes out now , if not check burners are not blocked or injectors are not blocked
Jul 04, 2012 | Grilling
I have an endless summer 92000 table top propane heater. Lights fine, but the flame does not burn at the edge of the burner. Instead, it only burns in the very center of the burner... much like a Bunsen...
Actually, it's a gas pressure issue. But, it's fairly easy to solve. First, you need to be sure that your LP Tank has a sufficient amount of gas. If it does, turn the propane tank valve OFF. Disconnect the hose from the tank and wait 5 minutes. Then reconnect the hose to the tank and turn the valve ON VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open, light the burner as you normally do and turn the burner flames to HIGH. Has the burner flame returned to normal? If so, you solved the problem. Just remember to always turn the tank valve ON very, very slowly.
If it didn't solve the problem, you will need to replace the heater's hose/regulator assembly. Generally, i's the same type that a gas grill uses. So, it won't be hard to find one.
Hope this helped to troubleshoot and solve your problem. Please let me know.
Apr 30, 2011 | Endless Summer 92000 Table Top Patio...
First two burners work fine but when I turn on third burner (back) it cuts out the whole grill on the Weber genesis
This is very common with faulty regulators. The regulator is located on the hose (it is a metal silver disc located at the end of the hose where the hose attaches to the propane tank.)
To replace the hose and regulator, you need to detach the hose from the grill. Your local grill store should have replacement hose and regulators.
Hope this helps.
-Ben
Tanks 2 You Propane
propanetanks2you.com
Jan 27, 2011 | Weber Genesis Silver B Grill
When I light my grill only one side of the burner has a flame, on all 3 burners. I cleaned everything and even cleaned each hole in the burners. What's next?
This is a common problem with grills purchased after 2001. There is a new safety feature inside the regulator called a 'surge protector'. If you open your propane bottle valve too quickly or if you try attaching a tank with the tank valve in the 'open' position, the propane wants to 'surge' into the grill.
When the propane surges into the regulator (located on the grill hose) the 'surge protector' (inside the regulator) kicks on. When this happens you will not be able to get your grill lit, and if you do, it will be a small blue flame and the grill will not heat up.
So what to do if you trip the surge protector and can't get your grill to light or heat up?
Shut the tank off and shut the valves on the grill off. Disconnect the tank from the grill hose. When you disconnect the tank from the hose you will hear the excess pressure of propane release. This is an indication that you have re-set the regulator's surge protector.
Now that you have deactivated or reset the surge protector, reconnect the tank. Make sure the valve on the tank and the valves on the grill are in the closed and in the off position. After you reconnect the tank to the hose, SLOWLY open the tank valve (making sure the valves on the grill are in the OFF position).
Since you have slowly opened the valve on the tank, the propane did not surge into the regulator and the surge protector did not activate.
Now open 1 valve on the grill and light it. You should get a nice flame. If your grill has more than one valve, open each following valve in sequential order to extend the flames to the other burners.
Thanks for reading and I hope this helps.
Ben Gaetani
Tanks 2 You Propane
Tanks2youpropane@gmail.com
Mar 02, 2010 | Grilling
One burner barely lights; others don't light at all.
This is a common problem with grills purchased after 2001 or with a full propane tank with a lot of pressure in it. There is a new safety feature inside the regulator called a 'surge protector'. If you open your propane bottle valve too quickly or if you try attaching a tank with the tank valve in the 'open' position, the propane wants to 'surge' into the grill.
Ben Gaetani
Tanks 2 You Propane
Feb 23, 2010 | Weber Genesis Silver B Grill
Is not heating properly , the flame is not as strong as it used to be.
Ben Gaetani
Tanks 2 You Propane
Jan 18, 2010 | DCS BGB36BQARN (NG) Stainless All-in-One...
Propane flame is not blue but too high
A yellow or orange flame means (1) too much fuel, or (2) not enough air. Make sure the air ports where the regulator attaches are clear and that spiders or bugs haven't built a nest in the burner tube. If that's all clear, it's likely that the propane regulator has failed and is allowing too much fuel to enter the burner tube. The regulators are inexpensive and are not repairable; get a replacement unit.
Oct 08, 2009 | Weber Gas Go-Anywhere Grill
Attaching the regulator
The regulator is inserted into the end of the burner tube, which protrudes a couple of inches from the end of the lower grill tub, under one of the carrying handles. It is held in place by a "C"-shaped spring wire clip and can rotate freely. One can attach a disposable propane cylinder for portability or a hose from a bulk tank for back yard or base camp use. See photo below.
Jul 06, 2009 | Weber Gas Go-Anywhere Grill
Cannot conect regulator to small 16.4 oz propane tank
It must have some sort of packing spacer you need to remove from the hose to attach the tank. LOL
Apr 11, 2009 | Coleman Roadtrip Grill LXE 9949-750
Weber Gas Go-Anywhere Grill Logo
59 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
