Question about Sony PlayStation 2 (PS2) Console
Disk not spinning but laser is lit
My ps2 SCPH 70004 stoped reading disks when i checked it i found the disk was not spinning but the laser was scanning the disk so when i restart the disk the laser went off and always came to main screen that is browser and system confing screen is it possible to fix this problem
Try to adjust the lens by turning the white cog wheel slightly to the right. if it doesn't work try to turn it again its trial and error until it runs perfectly.
Posted on May 07, 2007
    Problem Solver:
  • 8 Answers
I had this same problem countless times, the problem is the laser what you have to do is open it up get a bud and some ethanol(becareful some ethanols are made oily to prevent child consumption avid these one) then gently wipe the lens and clean out the rest of the console with a hairdryer and VOILA
Posted on Apr 20, 2007
SOURCE:
PS2 Modchip and Laser Fix installation Failure ...
I bough ps2 with cracked after 3-4 days not working dvds are not read.
sometime it's working some dvds..
so plz solve my problem...
May 28, 2012 | Sony PlayStation 2 Slimline Console
PS2 Modded Trouble Reading DVDr's
Your DVD potentiometer pot on the back of the PS2 laser lens needs to be readjusted. Some people will try to tell you it's out of alignment but if that was the case it would not read CD's. Some people will try to tell you the laser lens is bad. If that was the case it would not read CD's. On the back of the laser lens are two potentiometer pots. In english? Two lil screws that are turnable. One controls the power of the DVD laser one controls the power of the CD laser.
http://www.cyber-mag.com/station/laserV9.htm
That link will give you pretty lil pictures of what i'm talking about :)
In a nut shell the story goes like this folks. If your PS2 won't read certain game DVD's that are of a certain color or if it all of a sudden mysteriously fails to read games it once read but will play cd's just fine, the voltage of the laser for DVD's is not set correctly. (this does needs manual tweeking from time to time if you take your ps2 and move it around alot or if you take it over to friends houses etc etc. Basicly alot of movment in general can take this out of alignment. Even keeping the PS2 on it's side could theoreticly (just my opinion) based on gravitational pull, unbalance the potentiometer.
RESOLUTION:
Step 1 identify your PS2 version:
Version 1 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U1"
Version 2 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U0"
Version 3 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U2"
Version 4 - SCPH-30000, 30001, 35001, 30002, 35002, 30003, 35003, 30004, or 35004, 8 screws on bottom of case
NOTE: Version 4 has 2 varieties of motherboard: Gap/No Gap, the difference between v4 "Gap" and v4 "No Gap" is the "Gap" is there's a spot in the center of bios chip where each side lacks solder points.
Version 5 - SCPH-30000R, 30001R, 30002R, 30003R, 30004R, or 30006R. Also, some SCPH-30000, 30001, 30002, 30003, and 30004 models have a V5/V6
NOTE: Version 5 & 6 - the difference between these two versions is one of the connectors in the corner.
Version 7 - SCPH-39000, 39001, 39002, 39003, 39004, 39008 or 37000
Version 8 - Only in Japanese consoles. SCPH-39000, or, SCPH-39006 (GH-022 BIOS 090)
Version 9 - if you have SCPH-50000, 50001, 50002, 50003, 50004, 50006, or 50007 you have a v9 or v10 board.
Version 10 - SCPH-5000x, with date code "3D" to the right and below the serial number on the back of the console. (GH-026 board)
NOTE: To know if its a v9/v10 start up PS2 with no game in it ,press triangle and check dvd driver version dvd ver 3.00 = v9 & dvd ver 3.02 = v10.
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find a small ''a'' under the SCPH number or have DATECODE "3C" you have a V9 PS2 main board. (GH-026 board).
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find DATE CODE "3D" as shown below, you have a V10 PS2 main board. (GH-026 board).
Version 12 - The new slimline PS2 consoles are referred to as PSTwo here, but elsewhere they are also known as "v12" units... their numbers are SCPH-70011/SCPH-70012, and also SCPH-70004 CB (Belgium).
Step 2 use either google or the link above. If you're using google your keyword search will be something like "ps2 v12 laser lens adjustment" *replace v12 with your ps2 model.
In either case navigate to the site and follow instructions to set the pots back to their factory default settings.
Oct 11, 2008 | Sony PlayStation 2 (PS2) Console
Clicking noise, PLEASE HELP!!! PLEASE!!!
That happend to me. All i did was move the piece that holds the laser right down by the part that holds the disc and it worked fine then..
Jul 12, 2008 | Sony PlayStation 2 Slimline Console
PS2 model # SCPH-70012
You have to have take your station apart and clean the eye... If u need to know how to do it without messing it up email me bak...
Mar 14, 2008 | Sony PlayStation 2 (PS2) Console
Disk read error on slim ps2 scph 75003
hello pauldonp...if this is an early version of the slimline they had a problem with over voltage which inturn took out the laser.your only option may be to replace the laser . sony did bring out a mod for this..i preferr the real old version of the ps2 as they had all separate boards and if one went faulty you didnot have to replace the lot ,also the lasers were a lot cheaper than the later models .in the slim lines the lasers are not all that expensive .they do take a bit of setting up as you have to know the ohms setting on the laser for each model..hope this helps
Feb 08, 2008 | Sony PlayStation 2 Slimline Console
Sonyplaystation2 model scph 70002
Check you 1st posting and please check Solved on this one. The solution I placed on your first posting will work. You gave me a Almost there vote on the last posting and it cut my rating. You cannot change it. By Clicking solved on this one will counter your almost there vote.
Nov 09, 2007 | Sony PlayStation 2 Slimline Console
Disk wont spin
First of all the new laser lens will not allow your Slim to read NTSC UC games if you have a PAL european Console.
There is no reason the New laser should have not read the disc unless it Came to you damaged. It sounds like you know how to replace a laser.
Sep 13, 2007 | Sony PlayStation 2 Slimline Console
Ps2 discs are not spining
Don't bother changing the lens. If i understand you correctly you have damaged the motor or some circuitry leading to it. I hope this helps! good luck on finding a new one, they are abundant right now!
Jul 21, 2007 | Sony PlayStation 2 Slimline Console
Disk is not spining
Ps2 disc wont spin
try loosening the screw to the left of the laser i believe its a torx bit.( i just used a very small flathead). on my broken scph 30001 i used to have to manuallly spin the disk for it to read games so i loosened that screw and lubricated all the tracks with wheel bearing grease(white lithium would be better but i work on cars so it's what i had.
Jul 05, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
248 people viewed this question
Top Sony Video Game Consoles & Games Experts
juanmireles1
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
