Question about Lanier Office Equipment & Supplies
Lanier ld145 duplex error
Hello I have a problem with our copier LD145 were trying to print duplex but it tells me reset duplex unit recovery error
    Scholar:
  • 78 Answers
The duplex is on the right hand side of the copier (external unit from the main print engine). You firstly need to check for a jam inside the unit, open the unit away from the copier and there will be a blue tab to access further beyond the black plates. Also make sure the unit is seated correctly and plugged in (Turn off unplug and plug back in, this will also reboot the machine). This is customer recoverable error so the reboot should fix it
Posted on Jan 03, 2009
How to reset fuser error code on lanier ld235?
Come into test mode, if it comes back the fuser service needed. -Carl
Oct 06, 2014 | Lanier Ld345 Ld335 Ld245 Ld235 Ld145 Upper...
How do you set the Lanier LD035 duplex unit?
Metal tab on right side of copier is bent and correctly touching the duplex unit interlock switch. Open the duplexer and notice the metal tab stick out. Put back to a 90 degree angle.
Jul 30, 2014 | Lanier Office Equipment & Supplies
How to replace used toner bottle on an LD245 and where is it located on the machine?
No bottle, it is inside the transfer belt unit that hangs on the inside of the right hand door. Dump it and put it back.
Jun 24, 2014 | Lanier Ld345 Ld335 Ld245 Ld235 Ld145 Upper...
When we try to copy something that is double sided the machine will stop and say "duplex unit is not set. Please set it." I'm not sure how to proceed.
Hi shiana,
On the right side of your copier is a "box" called the duplex unit.It really is a silly *** box LOL.Now....either it is not firmly latched to the copier .......OR....the metal tab on the main copier is bent so that even if you put the duplex unit firmly in place ........the little switch on the duplex unit is still not :satisfied: And we hate that. I bet ya got it fixed in a jif. take care :-)
Jan 06, 2011 | Lanier Office Equipment & Supplies
Ricoh Aficio 2035 wont duplex, displays error message error: Duplex unit is not set. Set it properly
there is a sw on the duplex unit that tells the copier it is closed my guess is that its broke
Nov 04, 2010 | Ricoh Aficio 2035 Copier
We can duplex copy but not duplex print on the KM Bizhub 250. When printing from the computer, in the Konica Document Properties Window on the Layout tab, when the Print Type pull down screen is activated...
Hello
See if you have selected weight paper from the tray in the duplex mode.
Weight paper is selected in duplex mode only from the bypass.
So you check that the paper in the tray 1 or tray 2 must be plain paper and in duplex mode it can print normally.
Jan 29, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
User tries to print double-sided but only the first page goes into the duplex unit and the printer says Processing duplex job but nothing else happens [except the odd clunk]. Switching off printer clears...
The error you have seems to be a memory error. Try some of the suggestions listed <a href="http://forums13.itrc.hp.com/service/forums/bizsupport/questionanswer.do?threadId=1083081&admit=109447627+1260869270520+28353475">here</a>
Dec 14, 2009 | Office Equipment & Supplies
Lanier copier ld145 locked up, code is sc546
Fuser warm up problem. Cause needs to be fixed and then code can be reset in service mode by a tech.
Jul 29, 2009 | Lanier Office Equipment & Supplies
Lanier 6725 need pm code or manual
A2 means something is wrong in the duplexer. Check all parts of the duplexer for jammed paper.
May 28, 2009 | Lanier Office Equipment & Supplies
I have a Lanier 5245. I am getting an error when
Your duplex is the big box on the right side of the machine push the back side shut against the machine and try again
May 08, 2009 | Lanier 5235 Printer
275 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
George Mclaughlin
Inky Fingers
Inky Fingers
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
