Question about GE GSH25JSRSS Stainless Steel Side by Side Refrigerator
GE GSH25KGMCCC not making ice
Ice makier not making ice and don't know what to do. Doesn't look like it is getting any water.
  • 700 Answers
Whats is the temperature that you are running your refrigerator at, should be -2 or eblow, also is there ice built up inside of the fill tube? if there is that will have to be thawed out.
Posted on Dec 26, 2008
My GE Side by Side refrigerator stopped making ice and dispensing water.
Check out the solenoids and power to the water solenoids for ice maker and door water.
Aug 22, 2017 | Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
My ice maker isn't getting water in to make ice. I can manually pour water into the maker, let it freeze, and get the maker to get the ice out, but no water comes in. GE model GSHS5KGX. Side by side...
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 26, 2011 | General Refrigerators
The ice machine stopped making ice
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Jun 26, 2010 | GE Profile PSW26P Stainless Steel Side by...
My freezer will not make ice after changing the
Jun 02, 2010 | GE Profile CustomStyle PSC23NGT Side by...
Doesn bring water to ice maker
If you have water at the door, the most likely problem is that the metal bar that shuts the ice maker off has been moved to the off position. Check to see if the metal bar is in the up or down position. If it is up, move it down and vice versa and give it an hour to see if it begins making ice again.
May 29, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Profile ice maker stopped making ice
ice maker for ge profile wont' make ice.Unplugged elect supply from both waterin the door coil and ice maker coil.Plugged water in the door elect to ice maker valve coil and pressed water in the door input sw out front and got water to ice maker so this let me know it wasn't the solonoid valve.Got another ice maker unit plugged in and mounted waited several days still no ice.
Sep 27, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE side by side; model # TFX25JRYD Serial #
So the dispenser is getting water. Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
If the valves clicks but water doesn't get to ice maker the fill tube can be stopped up with ice.The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Jul 12, 2009 | GE GSS25JEM Side by Side Refrigerator
Ice maker not working
have you felt water in the ice maker or ice cubes thats the only way you know for sure.. just cause water in doors works doesnt mean icemaker getting water.. got different valves giving water to different places Is your freezer temp. right.. has to be right temp for icemaker to work.. check back wall in freezer make sure no frost buildup and if fan working
Sep 02, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE GSH25JSRSS Stainless Steel Side by Side Refrigerator Logo
80 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
