Question about Edu-Science (10166) Telescope
Obscured view through telescope
It appears that the focus mirror is being seen in the center of the view. We have focused a very bright star - but have a cross in the middle of it - and no it is not the Finder we are looking through, and it is not simply crosshairs. There is a specific obstruction. It is visible with both with the eyepiece and without.
Any idea what we could be seeing? And how to fix the issue?
  • 3,186 Answers
You are seeing the "spider" holding the secondary mirror-- the scope is not in focus--
Practice focusing during the daytime on a distant object at least 100 yards away-- use the lowest power eyepiece-- which is the one with the LARGEST number on it.
Posted on Jan 04, 2009
When using telescope for the first time (looking at venus) it would not focus, also the cross at the front of the tube was most prominent.
Do stars appear as small pinpoints in your scope? If not then it sounds like you have not adjusted the focus properly. I recommend you take your telescope outside in the daytime and point it toward a building or tree or hilltop that is somewhat distant from you. The exact distance is not important, but it should a block or more.
With the telescope pointed at the distant object, focus the telescope until the object is sharp and clear. The object might appear upside down -- that's normal for many astronomical telescopes. When you have achieved a sharp focus, leave the focus control alone until you are outside at night under the stars.
The focus should now be fairly close for viewing stars and planets. Small adjustments of the focus control may still be necessary for the sharpest view.
Venus is sometimes a difficult object. It is often fairly low in the sky where the atmosphere is most likely to blur the view. Find a bright star and focus it to a pinpoint, then swing your scope toward Venus.
- Jeff
Dec 27, 2016 | Celestron Optics
Why can I not see the difference from the sky and a star even when I allign my laser well?
It sounds like you have not adjusted the focus properly. I recommend you take your telescope outside in the daytime and point it toward a building or tree or hilltop that is somewhat distant from you. The exact distance is not important, but it should a block or more.
- Jeff
Jun 08, 2014 | Celestron NexStar 4 SE Telescope
I dontknow how to look through it andfocus on a star,or moon
Hi Joe, I'm Mark.
The small scope on top of your big scope is called the "finder" scope. Probably 2X or 4X. It should have cross hairs in the view. Find the moon with it. It will also require focusing but since the moon is bright, you can get an idea where it is in the lens by that.
Next. Find the LOWEST power eyepiece to insert into the lens holder. And rotate the focus knob.
Hopefully, you will see some bright blurry thing and then you can focus on it.
After you get it in focus, put on a more powerful lens and look at the craters on the moon.
Note: You will need to adjust your telescope to the earth's rotation. Your scope should have
instructions for accomplishing this.
Hope this helps,
Best, Mark
Dec 28, 2010 | Tasco 200x50mm Refractor Telescope
I used the collimation eyepiece to collimate my telescope.But I dont know if it's properly aligned. The knobs on the bottom of the tube are turned fully clockwise, and the black dot in the eyepiece is...
Before you do anything else, take the scope outside on a good night, find a semi- bright star (Polaris will do). Let the scope cool down! (about 45 minutes) use your highest power eyepiece and put the star in focus.
Now take the star out of focus (inner focus or outer focus) you should see a dark circle in the center with symmetrical rings around it (airy rings). If the dark circle is in the center and the airy rings are symmetrical, your telescope is collimated
Check both inner and outer focus, they should be close to the same. If not you should re-collimate.
Best done with fainter stars but for now stick to the brighter ones.
Because I own 3 scopes, I use a Hotech laser collimator. its quick and easy. Worth it if you travel with your scopes to dark sites
A good guide on how to collimate
http://www.skyandtelescope.com/howto/diy/3306876.html
Oct 16, 2010 | Celestron NexStar 130SLT (31145) (306 x...
When viewing venus or other stars there a black spot in the center of the object. It appears to be the 2nd mirror refleting to the main miror. what have I done incorrect?
You are NOT in focus. Turn the focus knob a little until you see a perfect "disk" for the planet. Stars are always POINTS of light, with a telescope or without a telescope.
Aug 28, 2010 | Celestron NexStar 114GT (269 x 114mm)...
Having a clear sky last night i took my new scope out and started to view the night sky, but focusing on a star ! i found that when viewing it at magnification a could clearly see the the area infront of...
Stars are ALWAYS pinpoints of light when the scope is focused no matter how much magnification is applied.
You are NOT focused properly -- when you are you cannot see the secondary mirror or the "spider" bracket that holds the mirror.
You will NEVER see a star as a disk, only as a pinpoint light. If you are seeing what looks like a donut with a dark center you are not focused.
May 07, 2010 | Celestron PowerSeeker 114 EQ Telescope
Like others, I have trouble seeing stars. There is an obstruction, an image of the secondary mirror which obscures most of the star. Is this the spider? Others have asked the same question, but I haven't...
Yes, you are not focusing the telescope properly. When in focus you cannot see the spider.
Put the eyepiece with the largest number written on it into the telescope. Go outside during the day and practice focusing on a distant object.
Oct 18, 2009 | Bushnell NorthStar® 78-8846 (675 x 114mm)...
Ditto
You bought what we call a toy "department store telescope". Put the eyepiece with the largest number written on it into the scope. DO NOT use any 2x barlow which might have been included.
Go outside during the daytime and practice focusing on a distant object. AND---- no you will not get 450 magnification from that telescope, even though it was written in bold letters on the box.
Sep 21, 2009 | Bushnell NorthStar 78-8831 (525 x 76mm)...
You can slow down dew forming on the mirror by NOT pointing the telescope toward the sky during cool-down-- just leave it parallel to the ground. Same goes for your eyepieces -- leave them covered, or inside a case.
Dec 26, 2008 | Celestron AstroMaster 130EQ Telescope
Fuzzy bright stars with my Celestron CPC 1100 XLT
The image shows that the optics are not centered properly. The secondary may be tilted slightly to the 2 o'clock position. When not centered, a focused star will have an astigmatic shape, and not come to a full focus. Also check the mirror and corrector plate for dewing, that will also affect the views.
Nov 02, 2008 | Optics
Edu-Science (10166) Telescope Logo
120 people viewed this question
Top Edu-Science Optics Experts
Craig Butler
Craig Butler
john cordey
john cordey
Geoff White
Geoff White
Are you an Edu-Science Optic Expert? Answer questions, earn points and help others
