Question about GE DBXR463EBWW Electric Dryer
Burning smell Last night I threw a load of wet towels in the dryer and within five minutes my daughter reported a burning smell. The top corners of the inside of the drum were hot to the touch as was the top of the dryer in each of the corners beneath the control panel. The dryer had been used earlier that day and the day before with no problem except that extra large/heavy loads were sometimes slightly damp at the end of a cycle (not unusual). We turned off the dryer immediately and removed the towels. This morning I vacuumed under and around the dryer and removed the vent and vacuumed into the dryer from the back and into the vent that goes outside. There was some but not really much lint to be removed. Repair cannot come out until Monday the 29th. Is there anything else I can do to solve this problem?
  • dgroon Dec 26, 2008
    My circuit breaker did not go off when we smelled the burning. Doesn't this mean that the problem is not a short?
    I already ran the dryer empty with no problem so your answer definitely makes sense. I'll run small loads until the repair man can get here on Monday to replace the belt. Thank you!
  • GE Master
  • 13,433 Answers
It overheats Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat
If you don't clean out the lint trap frequently, your dryer may have small lint fires inside the cabinet. The smell from these fires can leave a strong odor in the clothes drum.
Also, if there are any solvents, paints, lacquers, etc. in use in the house, your dryer may alter and/or amplify the fumes to an odor unlike the natural fumes given by the solvent, paint, etc.
Here's what to do:
  • First, clean all of the lint from the inside cabinet and ductwork of your dryer.
  • Have a qualified appliance repair technician inspect the dryer for damage caused by any lint fire.
  • Move all containers of flammable liquids at least 50 feet away from the dryer. Gas dryers have a large flame when operating properly and can ignite the fumes of any flammable liquid or gas.
  • Then, try to clear the odor, by running a couple of loads of old rags or towels.
Posted on Dec 26, 2008
  • 15,935 Answers
Place 1 towel in, and see where you are. If the towel dries, the problem may be an overload of wet towels. Was the burning that of electrical, or rubber?
Motor was more than likely over-driven.
  • 700 Answers
Is it a gas drier or electric?
  • Todd Born
    Todd Born Dec 26, 2008
    is it a gas drier or electric?
    Genius:
  • 1,011 Answers
Sir,
check this link
also check this link
http://www.nwlink.com/~pkrogh/dvc.html
thanks
good luck
    Sergeant:
    Novelist:
  • 327 Answers
Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
ome dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub or even burn the clothes. You can't repair them. Just replace them when they're worn.
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
    Genius:
  • 1,550 Answers
Fan is not running properly or the air flow is blocked.
The heating element is damaged you need to replace it .
  • 679 Answers
No, it sounds like a belt is slipping from the weight of the wet towels, let the dryer cool down and try it empty, if it works at least you know what caused it
  • George Bill
    George Bill Dec 26, 2008
    You are very welcome, thanks for the rating, and have a great holiday,
  • 100 Answers
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then:
  • If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician.
  • If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Last load of towels finished and we smelled a slight burning odor.
If you overload a dryer, you can severely limit airflow. This can cause excessive heat. Most dryer appliances have built in thermal shut off devices to prevent accidental overheating. If your dryer allows the temperature to rise to the point that articles in it smell burnt - the dryer or thermal shut off device is probably not operating properly. You should check to make sure that the filter is cleaned before every load and that the exhaust vent is clean and unobstructed. If it persists, you should have the dryer and vent serviced.
May 06, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore 800 dryer burning smell and noise.
Access is from the front. Lint screen on top? 2 screws under screen, putty knife to release front clips between top and cabinet. Top folds back and 2 5/16 screws in top corners. Lean front towards you then lift up off lower hangers. Good luck.....
eric
Jun 06, 2009 | Kenmore Dryers
Washer makes a squeel and burning smell
belt which operates pump/motor/transmission pulleys
Apr 10, 2009 | Washing Machines
Dryer will not start
IT SOUNDS AS THOUGH YOUR MOTOR HAS LOCKED UP AND FAILED. THE BURNING SMELL IS THE VARNISH FROM THE WINDINGS OF THE MOTOR. REPLACE THE MOTOR. THEY CAN BE HAD FOR AROUND EIGHTY DOLLARS
Jan 27, 2009 | Whirlpool LER5636P Electric Dryer
Burning smell after hitting the reset button
the lint may have moved into the motor/ or other areas, clean the unit again and have another inspection, checking for burn't wire etc.
Jan 25, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Duet Gas Dryer- burning smell
first is first ,,, disconnect dryer from plug,, now open bottom panel 2 screws ,, now go and get youre vaccum,shop vac, anything ,, reason for burning smell ,, usually catching on fire ,, we recommend do this 1 as year,,, after cleaning , put about 2-3 fabric sheets inside dryer and let it runn for about 30 minutes to remive smoke from drum,,, thank you
Dec 29, 2008 | Dryers
Kenmore 80 series quit heating after burning smell..
Any kind of lint or cobwebs on the element would cause a hot spot and fry the element or pop the limit that is mounted on top of the chamber. What your hubby soulda done is take the machine down and vacuum it out after sitting up so long. The fuse is not blown because it still runs so it must be the small guy pictured. It mount up top of the heat element chamber.ff8b5e7.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 22, 2008 | Dryers
Burning smell
Sounds like your drier is over loaded. Belt slipping due to : to much weight in drier. The drier motor is an adjustable. Belt test: If you can twist belt more than a half a turn it is to lose. Replace belt.
Feb 10, 2018 | Kenmore Elite HE4 Electric Dryer
Whirlpool GC5SHEXN Side by Side Refrigerator burning smell
How long had it been plugged in when you started to smell the burn. What kind of burn do you smell, is it an electrical burning smell or a smoldering dust burning smell.
supertechks
Nov 21, 2007 | Whirlpool GC5SHEXN Side by Side...
GE DBXR463EBWW Electric Dryer Logo
Top GE Dryers Experts
John Tripp
John Tripp
vince
Marc Taylor
Are you a GE Dryer Expert? Answer questions, earn points and help others
