Question about Bissell 5770 Healthy Home Bagless Upright Cyclonic Vacuum
Burning smell when vacuuming, not belt
Our healthyhome bissel 5770 when used smells very bad, like something is burning, we checked the belt, cleaned and replaced airfilters, it might be the thing that is on the end of the roller, can't figure anything out, need help carpet looking pretty bad!
  • lv_777 Jan 06, 2009
    My vacuum makes that smell too. The belts turns although it doesnt sound smooth when it rotates (if that makes any sense). Also, there is one point on the roller where it is quite warm to the touch. I am currently trying to figure out how to remove the bottom plate.
  • 548 Answers
Try turning the vacuum on and hold the base up so you can see if the roller is turning. Odds are it is not and what you smell is the belt burning (not literally). If the roller is not turning, look for anything that is binding it - after you have unplugged the power cord. Probably the roller head is not fully aligned with the retention lugs that hold it in place or the belt is not properly placed on the roller itself, or if it is a used model, hair and twine can get tangled in the roller and cause it to stop turning.
Posted on Dec 26, 2008
My bissell powersteamer "pro" smell like something
mine has the same problem and i found it was the belt, which broke due to age
Oct 15, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
The bar that the belt sits on wont spin and smells like its burning when you turn it on. Is the motor out?
No, it is not the motor, it is a bad belt or something is jammed causing the belt to slip...
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 26, 2010 | Bissell 1699 ProHeat Clear View Upright...
Vacuum smells like something is burning
Ok...Check the brush roll is free not sticky..Next is the belt okay, not jamming on the brush roll making the burning smell...You could take off the roll and run motor on its own ..finding out if its the motor..
Apr 13, 2010 | Bissell Healthy Home HEPA Bagless Upright...
Last time I used my Bissell Pet Hair Remover vacuum it smelled like something was burning and it left a black mark on the carpet. What should I do?
When you smell burning like that it usually indicates that the belt is worn and slipping on the motor shaft. You probably need to change the belt. You can get the belts for your model here:
Bissell Pet Hair Eraser Belts
Nov 11, 2009 | Bissell Upright Vacuum - The Pet Hair...
My vacuum makes a really loud noise when I turn it on. It was working and now it smells like something is burning. I check the belt- it looks ok.
The belt may look okay but it still can be stretched or worn and can be slipping on the motor shaft and thats why you have the burning smell. I would try changing the belt. Here is a link to the manual and a link to the belt you need:
Bissell Momentum User Guide (PDF)
Bissell Momentum Replacement Belts
Oct 31, 2009 | Bissell Vacuum - Momentum Cyclonic 1 ea...
Burning smell, but belt okay
The burning smell is caused by the heat generated from friction. Belts stretch and thus are worn out and must be replaced. When you do it (it is very easy) you have to remove the roller brush completely, anyway, clean it at the ends of the shaft of any pet hair and/or carpet threads. Also clean the area in the housing where the shafts rest. This will keep it rotating smoothly and your cleaner will operate more efficiently.
Jul 16, 2009 | Bissell 5770 Healthy Home Bagless Upright...
My bissel 7901 won't spray water out of the bottom or hose to clean the carpet. I did smell a burning smell and shut it off. Is the pump gone?
Depends, if the the smell was like rubber, then it may be the pump belt. If it is ok, then the pump could be bad, altho the pump wouldn't have had a burning smell. The main motor would if it was an electrical smell.
Apr 14, 2008 | Vacuums
Bissell Cleanwell II Bagless uprighht vacuum
Hi Pmob20,
Remove the brush and clean all the string or whatever may be trapped at the end edges of the brush.  This is usually the case with Bissel vacs, that string or fiber gets trapped at the ends of the brush assembly.
Oct 10, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell 5770 Healthy Home Bagless Upright Cyclonic Vacuum Logo
418 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
