Re: change secundary screen wallpaper for a SGH-E215...
If you mean the little screen on the front of the phone, you can't. It just says the time/date, etc... I've tried and nothing in the manual or online says you can.
To change the wallpaper on your Android phone, follow the steps below:
1.Tap and hold on the "Home screen" to open the "Add to Home" menu.
2.Select "Wallpapers" and choose the type of wallpaper you want to implement. Three options may be available: Gallery, Live wallpapers, and Wallpapers. Note: Live Wallpaper may not be an option on some phones. This is due to the limitations of the hardware of the smart phone itself.
Gallery allows you to set one of your own pictures as wallpaper. Tap "Gallery" and select your preferred picture. You can crop the part of the picture you want to use as wallpaper. Then, tap "Save" to set the picture as your background.
Live Wallpapers provides you with a set of animated backgrounds. Tap "Live Wallpapers" and select the live wallpaper you wish to use. Next, tap "Set wallpaper" to set the live wallpaper as your background.
Wallpapers are a collection of pre-installed wallpapers. Tap "Wallpapers" and select the one you prefer. Next, tap "Set wallpaper" to set the picture as your background.
Reinstall again your Automatic Wallpaper change. This might be the problem is your wallpaper changer, check the setting if it is TILE, CENTER or STRETCH, only this 3 options are available on wallpaper, aside from resolution if only for viewing purposes.
YES YOU CAN CHANGE THE MAIN SCREENS WALLPAPER. sIMPLY TRANSFER ANY BMP OR JPG FILE INTO YOUR IMAGES, THEN SIMPLY SELECT MENU, MY FILES, IMAGES, TOUCH THE IMAGE YOU WANT TO USE, SELECT OPTIONS, SET AS, WALLPAPER. OR GO INTO THE SETTINGS CHOOSE 'DISPLAY AND LIGHT SETTINGS', 'DISPLAY SETTINGS', 'WALLPAPER', 'IMAGES', THEN JUST SELECT THE IMAGE YOU WANT AS YOUR WALLPAPER.
