Question about Zenith C13A02D 13" TV
Zenith C13A02D v-chip disable
I bought this tv used from someone and the v-chip is enabled for anything above pg-13. Can anyone suggest how to beat this problem?
  • brad garland Apr 23, 2007
    that link didnt really take me anywhere that gave any information... but i did look through the zenith website and the manual that was closest on there didnt work for mine.
Good because he/she wanted to know as repairing a television Zenith Model Non C13A02D the flaw of this television it is that he/she doesn't have sound and the rest works correctly
Posted on May 01, 2007
  • 944 Answers
Here is the link for the user manuals from zenith - they dont have one for your exact model, but if you type in C13A03D you will get a manual - page 34 details all the v-chip settings and should be nearly identical to your model at least; http://www.zenithservice.com/gcsc/b2c/hpi/main?tc=owm.command.OwmCmd Hope this helps - please post again if not :)
Posted on Apr 18, 2007
Get into the menu of the tv with out original remote
Try a universal Remote they are $9.00 at walgreen's
Oct 27, 2012 | Zenith C13A02D 13" TV
Zenith tv. #model b19a23dc need new remote
Try website like Remotes.com to buy the tv original remote or a very close compatible one.
Aug 31, 2011 | Zenith C13A02D 13" TV
42 inch flat screen shows v-chip block tv-14 lsv what does that mean? tv fades tremendously turns blue then shuts off
V-chip Block
TV- 14 - this is a rating for movies and TV programs. Basically means PG-13 like the old movie theater rating.
lsv- means, language, ***, violence.
You TV can be set to block these programs.
In you menu look for a catagory called "locks" or "ratings"
there you will find the options of what can be veiwed and what will be blocked.
if you everything to be available, just disable all settings.
if you want to choose different things to be allowed, just click on the icons and they become blocked.
Apr 12, 2011 | Olevia LT42HVi 42 in. LCD Television
Need remote code for zenith tv model c13a02d
remote code don't go by model, you get a list of codes and you just try them one at a time until one works, here are the most up to date remote codes for a Zenith TV.here are the three digit codes
101, 142, 149, 177, 241, 345.
remember all universal remotes have code search, so if none of these seem to work do the code search function, it is outlined in the user manual of your remote.
Jan 28, 2010 | Zenith C13A02D 13" TV
Remote control(s) suddenly will not operate any function.
How do you KNOW the controller is Good??
There is a little Infra-red receiver behine that little glass window on the front of your TV. This has been known to go bad (assuming all those things are good that you said are good!)
Aug 18, 2009 | Zenith C13A02D 13" TV
Will not unlock for PG-13 and R rated movies
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Jul 26, 2009 | Mitsubishi LT-52144 52 in. LCD HDTV
Zenith sms1324s doesn't exist on universal remote codes pages
You can buy a suggested substitute (original no longer available) here:
Zenith substitute remote
I wish someone would bring a suit against any of these manufacturers using the term 'universal.'
At best, they are 'multibrand' and, with the proliferation of 'brands,' there never will be one that can rightfully claim to be 'universal.'
Dec 09, 2008 | Zenith C27A24T 27" TV
Zenith TV not programmed for home purpose
If you have a remote that can access menu and your remote has number buttons and an enter key, you can follow this instructions to go to installer menu. Note that the installer menu is slightly different for each model, eg. some options are not available.
I was able to go to installer menu using two universal remotes. The remotes that I used were Dish Network 3.0IR and RCA RCU300WBL. Both remotes programmed for Zenith H2531DT TV. The reason why I had to use two remotes is that Dish Network remote was only able to access menu. It did not have ENTER key but RCA remote had ENTER key but I wasn't able to go to menu with that.
To go to installer menu (different from regular menu):
- Hold MENU for 8 seconds.
- Press 9, 8, 7, 6 and ENTER in the sequence.
You should be in the installer menu now. There should be a line that looks something like this:
03 VERT POS 13
Use SELECT button to scroll through each option, and ADJ button to adjust the values for each option. For example, to enable the front panel buttons on your tv, set KEY DEFEAT to 0. Other options that you might want to check:
CHAN LOCK which locks your TV to a single channel and wont let you change (set 0 to turn off)
START CH/VOL will set your tv to a specified channel when you turn on tv. (set 255 to disable)
You will have to look in the menu for some of the options because they are different for different TV series. A good place to find manual is on www.zenith.com or http://safemanuals.com/
I work in an old hotel and it took me few hours to figure out how to disable start channel lock. It drove me nuts. I hope someone finds this useful.
May 26, 2008 | Zenith SC652 Remote Control
V-chip code
Try a code of 000 or 0000, unless the previous owner has changed the code to something else the ones I have seen were all zero's for the access code.
Feb 18, 2008 | Televison & Video
13" Zenith TVSB1320 TV/VCR combo
any tv repair shop in the yellow pages or ebay
Feb 17, 2008 | Zenith TVBR1322 13 in. Combo
Zenith C13A02D 13" TV Logo
180 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
