IBM T40 black screen
The computer will boot sometimes when you apply pressure around the keyboard. A friend of mine is pretty good with computers and could do the repairs if we know where to look. I am a computer novice at best.
Help, I can't afford a new one.
Thanks!
After changing out fan IBM think pad t40 screen goes black after windows xp screen finishes losding up
Wait Black Screen? AFTER you changed the fan... hmmm... I think I know what the problem is. Okay solution one; You might of hit a wire or cord in the computer when you changed out the fan. Two: You might have the virus 223, get it fixed and it should be going again! Hoped this helped! :D
Mar 25, 2013 | IBM ThinkPad T40 2373 Notebook
T40 hangs after boot up. Sometimes does not show anything on boot
it may be because of the cpu cooler is so full of dust that the fan cant go around and the cpu gets hot and the whole system freezes or something else is totaly screwed up
Jan 04, 2009 | IBM ThinkPad T40 2373 Notebook
Boot problem
check it on bios whether the hard drive is detecting or not, if detecting then recover OS using recovery Cd
Nov 15, 2008 | IBM ThinkPad T40 2379 Notebook
Ibm t40
Yap actually i greet you first
what your system is prompting you is that your Processor is getting Bad and you will need to replace it with a new ones ok
After that your system come back to life .
thanks
Rate this solution
Oct 20, 2008 | IBM ThinkPad T40 2373 Notebook
IBM T-40 Thinkpad Stopped Working
IBM's are famous for this ...that's why they've changed their keyboard configurations so frequently, because palm pressure would either a) prematurely damage the hard drive or b) cause problems with the AC/DC card (IBM's term, not mine).
My guess, since I used to repair IBM laptops for a living, is the AC/DC card. It directly controls video output to the LCD. You can probably find one "pulled" on eBay for around $50, and probably $50-100 for someone to install it for you.
Hope this helps - remember to rate! :)
Scott
Oct 01, 2008 | IBM ThinkPad T40 2373 Notebook
IBM Thinkpad t40 black screen
Chips DO get loose and what you're experiencing is a common problem with IBM T40's. The solder that holds the graphics processor to the motherboard is cracked and no longre consistantly makes a good connection. This problem can only permanently be resolved with a new motherboard, or reflowing the solder of the GPU chip on the old one with a heat gun. Do a search for "thinkpad solder reflow" in any search engine.
Good luck.
Mar 28, 2008 | IBM ThinkPad T40 2373 Notebook
T40 keeps losing video randomly
It's broken solder point or points on the GPU chip. It's very common with the thinkpad T40. This can only be repair permanently by replacing the motherboard or reflowing the solder on the GPU with a heat gun. There is a utube video demonstrating the reflow process.
You can confirm this is your issue by applying strong downward pressure on your laptop just above the left corner of your touchpad and turning the laptop on. If the laptop boots completely while holding this pressure, you can be sure your laptop has this issue.
Mar 04, 2008 | IBM ThinkPad T40 2373 Notebook
Computer Screen
Re-install the video drivers or download an update from IBM if theres any available.
check the setting also, right click on desktop, click properties, go to the far right tab and check that its set correctly.
Feb 20, 2008 | IBM ThinkPad T40 2373 Notebook
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
