Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Nikon D 40 flash pops up but does not flash.
There are no codes saying something is wrong, and if we use a add on flash it works fine.
  • timartin2244 Dec 29, 2008
    I have the exact same problem, the flash pops up but never works and all of my photo's are coming out blurry. I have tried changing the ISO settings to a lower setting and still not working.
    Does anyone have any advice??? HELP!
    Scholar:
  • 170 Answers
Is the flash on Off mode? Is the battery fully charged? If not, charge the battery and try again.
Posted on Feb 14, 2009
THE FLASH ON MY NIKON P500 IS NOT WORKING WHEN IT IS RAISED AND I SELECT FLASH ON IT SAYS RAISE FLASH HOW I CAN THIS
To be sure something could be wrong with your camera flash, please put the camera in automatic and try making a picture in a dark situation. The flash should be pop up and fire, when the camera is in focus, and you press the shutter button fully.
Perhaps you know there are situations, the flash does not fire, even when you open it yourself. In the P, S, A and M, it only can fire if the ISO setting is on auto. Some scenes you can select, also won't fire the flash, even when you put it up.
there are more things, to shooting with flash than jute putting it up.
But when you try it like I said above you schools see a flash icon on the display for a few seconds and the flash should fire. If not, I'm afraid you must contact the Nikon service centre close by you.
success.
Feb 01, 2014 | Nikon COOLPIX Cameras
Err popping up on top of bar when try to take a picture flash does not come up and also when looking in it also appears inside
When a Nikon camera says Err, something is wrong with the memory card. Perhaps it is not inserted correct. Or not a card inside at all. Perhaps you can't write to the card or it should be formatted.
When you have a Err, the camera won't do a thing, to avoid the user can think he is shooting pictures and the camera won't save one.
Dec 27, 2013 | Nikon D50 Digital Camera
Nikon D90 flash will not pop.
I suggest you take your camera to a Nikon camera repairer.
Apr 18, 2013 | Nikon DSLR D90 Digital Camera
My nikon D60 and the pop up flash dosent work
the flash pivot on the release side of the flash has a small cylinder that operates the flash up switch. If that cylinder is broken off or the pivot is pushed in so the switch doesn't close, then what you describe happens
pop up the flash and remove the two screws underneath, and you can pry off the cover - gently - to check the switch
Mar 16, 2013 | Nikon D60 Digital Camera
I'm trying to take pictures without the flash but
You can shoot at faster shutter speeds if you raise the ISO setting. Also, turning up the lights will help.
Jan 12, 2010 | Nikon D40x Digital Camera
My Nikon N65 flash leaves a dark spot on all my photos
tlguthrie,
I love that camera. There are several possiblities, If you are using the pop up built-in flash with a telephoto lens or a lens hood you'll get a shadow in your photos ususally at the bottom of landscape oriented shots. If you are using a flash unit attached it may have something interfering with the strobe possibly or it is turned. We have the same camera and have had the shadow issue in the past. The pop up just won't work if something is wrong with the "bulb" the only other thing is that is isn't going all the way up, check that also.
randy32osgi
Jan 13, 2009 | Nikon N65 35mm SLR Camera
Flash on Nikon D50 will not latch down
If you have a fine screwdriver, remove the two screws underneath the pop up flash housing and remove the upper housing. BE VERY CAREFUL OF THE 300V at wires under the cover. You can see where the latch catches on a disk with steps - rotate the disk to a lower step and it will catch. Otherwise, an independent repair shop can probably do it while you wait for less than $40 USD.
Nov 25, 2008 | Nikon D50 Digital Camera
D70 internal flash not firing
Check if something is preventing the flash to pop up 'fully'. Check for some dust or other particles trapped between the flash and the body. Does the screen say 'Subject is too dark'? If so, the flash has not popped up fully.
Nov 10, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Error 99 only when flash pops up
I know what you two are talking about. I ordered a Canon EOS 300d from a site called "Keh" and I had never used one before... so I get it in the mail on time. The camera works fine for a few minutes then I get an "error 99" and can't do jack with the camera. I researched online and even called keh ... I read and heard that it has to do with the lens... so I sen't the camera back and got my money.
Nov 26, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
73 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
