Question about Kohler K-3360-G Revival One-Piece Toilet With 12" Rough-In, Seat, Cover, Br
Toilet tank fill valve sprays water towards lid
My kohler fill valve in tank sprays water towards the tank lid. This only started after I had turned off the water supply line for a day while making a different repair. I assume I have to replace the valve, but would this all of a sudden happen?
  • 1 more comment
  • Anonymous Jan 30, 2009
    I have the same problem and some times the fill valve will not shut off the fill supply.
    Thanks for any help.
    A manual would also help.
    Cheers
    Tom West
  • twest771 Jan 30, 2009
    I have the same problem.
    Sometimes the flow valve will not shut off the supply.
    A manual would help.
  • Anonymous Mar 12, 2014
    where to get toilet tank lid replacement in Canada
    Scholar:
  • 68 Answers
Hi bpmorr1,
It may be that the fill tube has come disconnected . It runs from the top of the fill valve to the overflow. The overflow is the tube that runs up the middle of the tank. The fill tube runs from the top of the fill valve to the top of the overflow tube. Kohler has a little clip that can sometimes come undone and cause spraying.
If that doesn't do it, turn the water off to the toilet and take off the tank lid. Partially open valve ( Slowly). Locate where spray is coming from. If it is in the area on top of the fill valve then yes, buy anew one. ( Fluidmaster )
Please rate this response and good luck, Phil
Posted on Dec 27, 2008
The toilet flushes but it won't fill. I can turn the water supply off and then back on, then it fills normally.When the tank is full, I can push the float down and no new water enters. when I flush,...
Hi!please kindly check your fill valve if it is working correctly.I thought the problem is in your fill valve.Kindly adjust the floater of your fill valve.
Aug 24, 2011 | Kohler Home
Water spits out of toilet bowl when toilet is flushed
If your referring to the tank, take the lid off and make sure the small tube is connected from the filler valve to the top of the overflow tube. If that's connected properly, flush the toilet with the tank top off and locate the source of the spray. A small crack in the fill valve can cause a significant spray.
Jul 09, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
Water squirts from tank while filling
Take lid off and check that the fill tube is in place. If so flush with lid off to see were the water is squirting from, be prepared to clean up water...If you can, do a slight flush. If there is water coming from any where but the bottom of fill valve and the fill tube you may need to replace the fill valve. In my experience, the fill tube is dissconected.
For Diagram
http://www.askmehelpdesk.com/attachments/plumbing/19906d1242687133-shut-off-valve-under-toilet-doesnt-work-fluidmaster-20ballcock.gif
Jul 06, 2010 | Kohler K-3386-0 Rialto one-piece...
I just installed a kohler toilet fresh from the crate. The fill valve runs every few seconds for just a few seconds. I suspect a leak but can't find any water drops in or around the toilet. Can you...
possibly the flapper valve not seating properly..
open lid of tank, check if chain to flapper is too tight, then check if something blocking flapper from seating properly
Jun 13, 2010 | Kohler Home
After the tank fills water contiues to flow thru
The fill valve needs replacement unless you can take the top off snd find out what is keeping it from closing. I had one I took apart for the same reason and found a piece of plastic in the valve seat. Good Luck, Ned
Nov 01, 2009 | Kohler K-11465-0 White Cimarron Comfort...
I have 2 K3466 model Kohler toilets and just had a
There is a volume control screw on the valves usually a plastic thumbscrew on side of valve turn clockwise until they quiet up the plumber should have adjusted that these are very tempermental toilets but when adjusted properly are excellent toilets I have 2 in my own home
Oct 26, 2009 | Kohler K-3466-95 San Raphael one-piece...
New water valve makes ahigh pitched whistling
I had exactly the same problem. Just turn down the water pressure @ the valve on the water inlet line. While you have the toilet lid off, you may want to remove the fill valve (1/2 turn counterclockwise on the plastic nut attached to the water-in line), and clean the rubber diaphrams (there are 2). They will sometimes get gritty and this will cause some fill noises and leaking.
Oct 25, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
K3367 one pice toilet harmonic vibration
check your water preasure. it sounds like it's to high and you should adjust your prv
Sep 13, 2009 | Kohler Toilet - One Piece with Ingenium...
Running toilet
Mine does that also, here's what I found.; I am on a well and occasionaly sand gets caught in the valve thingy... Take the tank lid off, turn the arm that attaches to the float assy. 1/4 turn towards the back of the tank and take it out. Rinse off the gasket and pin as well as inside the hole. Reassemble and it should solve your problem.
Jun 01, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Kohler K-3360-G Revival One-Piece Toilet With 12" Rough-In, Seat, Cover, Br Logo
7,687 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
