Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Computer does not recognize my book 160 gig
I've had this my book for a while and was previously hooked up to my pc and it workeed fine. I disconnected it last year and stored it. I lost my ac adaptor and had to get a new one..I hooked it up again, it's running and everything but my computer is not even uploading or reading that it's hooked up.........I've followed all add hardware steps on the control panel but it still does not work.........what can I do...
  • 3 Answers
I am making some assumptions:
1) You've got the correct power adaptor and the MyBook has not been physically damaged (they are pretty rugged).
2) You are trying to connect it to a PC running XP or Vista.
So it's time to see what your PC sees: It may be that the PC knows there's 'something' connected via USB but it hasn't been mounted. One simple way to check this is to go to the lower right portion of your MenuBar and left click on the "Safely Remove Hardware" icon. In XP it looks like a small gray thing with a small green arrow. In Vista it looks like a little plug. If it shows that something is connected to your PC via a USB or firewire port, when you left click on the icon there is a small description along with a LETTER, i.e. your main hard drive is almost always C:, this will not show up when you click on the icon I'm talking about because your C: drive is always there, a part of your desktop, likewise your onboard CD or DVD drives, but when youplug in a thumb drive or an external hard drive like your My Book, it gets assigned its own letter E:, F:, etcetera. It might be that the desktop has used that drive in the past and gave it a letter identification, but in the time you didn't use it you used other drives, and they were given the same letter. Now that you've 'returned' the new external drive to the desktop, it is a bit confused. So, back to that little "Safely Remove Hardware" icon. If is 'sees' your hard drive and it is mounted, it will show up as a small line saying something like "USB mounted drive F:" If it 'sees' your hard drive and it is NOT mounted it will say "USB mounted drive" with NO letter. Now you should go onto your desktop and select in sequence:
Settings
Control Panel
Administrative Tools
Computer Management
Storage
Disk Management
When you get to Disk Management there should be a vertical array of horizontal bars, showing all your computer recognized memory.
WARNING: You can screw up your computer if you are careless, so pay attention to the messages the computer is giving you. You want to find your external drive. The computer should be able to see it as a connected 'something' but if there is confusion as to the identification of the drive, it will not have it allocated by letter. So look to see if your My Book shows up as 160GB of something. If it is not there, check your physical connections, power down the My Book, plug it into a different USB port, change out the USB cord (sometimes a USB 1.0 cord is accidentally used in a USB 2.0 port and it might be a problem). If the computer does see the MyBook as a drive but it doesn't have a letter, you can click on it and SELECT a letter. This might solve the problem right away, just make sure you pick a letter not being used by anything else. Resist any invitations to FORMAT. This will lose you all your data on the drive.
Posted on Dec 27, 2008
Windows 7 running slow after memory upgrade
If it's Windows 7 32bit it has limits on the amount of ram it can use.
Google it and see.
Jan 31, 2012 | Dell Precision Workstation 670 PC Desktop
I installed two new 1 gigabyte memory sticks into a Dell Inspiron 6000, which previously only had 2 256 megabyte memory sticks installed. When I first installed the 2 gigs of new memory, the laptop turned...
Once you installed the memory, did you enter into the System BIOS Setup screen? Do this and verify that the system recognizes the newly installed 2GB RAM. This should let the system access the new memory once you boot.
Jan 01, 2011 | Dell Inspiron 6000 Notebook
Macbook wont recognize 500 gig My Book
Having tried 2 cables you should now try it on a different computer. Chances are there is a failure inside the enclosure but you will know for sure if it also fails to recognize on another PC.
Once you're tried that, if it does work on the other computer the problem is corruption in your Mac, archive and re-install the Mac, if it doesn't work on the other computer then take it to your local PC shop or parts vendor and have them move the drive into a different enclosure for testing.
If it works in the new enclosure, buy it and your on your way. If it fails to work even in the new enclosure then you will need the help of a pro to get at the files, if that is the case, reply back with your Country, State and city and I will direct you to an appropriate pro.
Hope this helps FixYa,
Chris
Aug 26, 2009 | Western Digital 500GB My Book World...
250 gig WD EHD
try to right click on "My Computer"->Manage-> Disk Mng.
Then try to see if you can recognize you this disk.
maybe you just need to change the letter or format it.
Apr 05, 2008 | Western Digital My Book Essential Edition...
Canon ZR850
I was told by Best Buy I could use the USB to transfer video which is not the case, you have to get the firewire cable. To get the computer to recognize the camera (for still images not video) you have to have the memory card in the camera then hook up the USB.
Nov 19, 2007 | Canon ZR850 Mini DV Digital Camcorder
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
395 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
