Question about RCA HD52W59 HDTV Projection Television
RCA HDTV LOOKS LIKE THE PICTURES IN 3- D PLEASE HELP
LOOKES LIKE PICTURES BOWED IN THE MIDDLE
  • 3 more comments
  • gizmo180 Dec 26, 2008
    Doesnt appear we have the convergence option
    not seeing were to sautter
  • gizmo180 Dec 27, 2008
    Thanks Were still trying to fix it. We cant find were the sauder goes, or were it is
  • gizmo180 Dec 28, 2008
    So how would one make sure that all electricity has been discharged before working on it . Thanks you
  • big herm11 Feb 01, 2009
    looks 3d and picture bows in the middle
This is definitely the fix for this issue. You can order the fuse from digikey.com for .99 cents. I would order a few as it seems this happens somewhat frequently. I have done this procedure twice in 3 years. You DO NOT need anything else but the new fuse for fl231 and to resolder all the points of the flyback.
Good Luck!
Posted on Feb 01, 2009
  • 505 Answers
There are 3 small fuses that will blow if the solder connections on the flyback transformer crack. If you open the tv, unplugged of course, you will see the flyback on the left most board.. the big thing with the red wire coming out of it. the 3 fuses are small orange squares just to the right of it.. two are 400mA and one is 1.25mA i believe.. anyways youll need a multimeter to check them and see which is blown.. solder the connections on the bottom of the flyback and replace appropriate fuse to fix. If only one color is off place, try going into the convergence adjusments in the menu to resolve without repair (might get lucky).. if its all 3 colors bowed on all sides, this fuse/soldering should fix it right up. A repair center will charge maybe $200-250 to do the job
Posted on Dec 26, 2008
  • 1 more comment
  • thielectronick
    thielectronick Dec 26, 2008
    you have to go into the video or setup submenu to find it. its under some advanced options somewhere.. may be called alignment or something. usually there is a automatic alignment more, or manual.. not sure which models are what, some have it some don't but you should definately have something.
  • thielectronick
    the flyback transformer is the part that needs soldering. this will make sure the fuse doesn't blow again, but until you replace the fuse, the voltage won't go to the board and fix the picture. the flyback is the big transformer on the power board (left side from back) and it has the largest red wire coming out of it. on the bottom of the board, there will be like a C shape of solder points that go along with the curvature of the flyback, all the pins should be resoldered, but you need to get that fuse replaced too. you can't inspect visually, use an ohm meter to check both sides of the fuse from the bottom of the board. if its good it will check 1 ohm or something low, if its bad it will be infinite ohms or megaohms..
  • thielectronick
    thielectronick Dec 28, 2008
My RCS HD52W67 is showing three pictures on the screen. I have tried zooming, but it only makes all three pictures larger. I cannot get it to only show one screen. What can I do?
Your TV most likely has a convergence failure. You can get parts and instructions from www.tvrepairkits.com Here are some of the most common symptoms and example photos of a convergence problem Screen looks 3D Colors don't line up One or more colors can't be adjusted when using the convergence menu. Screen is bowed or warped.
Nov 22, 2012 | RCA HD52W59 HDTV Projection Television
Tv picture is bowed and looks like 3-D effect on sides
The 3 projection tubs need re-alingment you could try it your self but good luck!!!
Dec 31, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I had 3 pictures in 1 and a bowed 3d screen. I replaced the fuse and re soldered the flyback. The picture looks good now but I still have the 3 in 1 picture?
The problem in in the convergence circuit not the horizontal area. There should be 2 large black ICs inside marked STKxxx. These are the convergence ICs. Try resoldering the pins on these first. Should that not resolve the problem, replace the ICs.
Please keep us posted on your progress.
Dan
Jun 13, 2010 | RCA HD52W59 HDTV Projection Television
Picture bowed & Colors separted
Conversions are out....RCA>>>>>>>>>>>>>check
fuse by the flyback transformer
May 19, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My 52 inch rca hdtv comes on but it looks like the screen is bowed and the colour is off.do you know of any solutions to this problem.
My rca 52 inch hdtv picture looks bowed on the top and bottom of screen. And everything looks like it has a red shadow behind it.
May 12, 2010 | Televison & Video
Picture is blurred and bowed
ok you have a convergence problem. first check out the article the fl231 problem in the tips and tricks section it will tell you of a condition that might mean an easy repair. first check to see if you have the convergence options in the customer setup menu
Mar 15, 2009 | RCA HD52W59 HDTV Projection Television
Whole picture looks 3D.
This is a convergence problem. If you can solder, you can fix this yourself. Please let me know if you wish to attempt the repair and I will supply additional details and instructions. Also, please confirm your model number so I can list the correct parts.
Thanks,
Dan
Feb 26, 2009 | RCA HD52W59 HDTV Projection Television
Help
You need to have the convergence IC's replaced. A repair like this should run you about 300 bucks or so. In most places.
Apr 27, 2008 | Sony KP-46WT500 46" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
136 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
