Question about LG WM-2277HW Front Load Washer
Loud squeaky Noise
I bought a LG WM2277HW washer/dryer combo from Best Buy about 4 years ago and have had no issues. We have cleaned the washer filter but basically have not done anything else other than wash clothes. We notice that during the beginning of the cycle that the washer makes an unpleasant squeaky noise. We dealt with it for a few loads and were ready to call a repairman when it suddenly stopped. My wife told me that she had just stuffed a large load into the washer and moved the drum around more than normal in the process of getting all the clothes in the unit. It appears to have stopped because of the adjustment of the drum. However, the noise is back and louder. In addition, my wife notice during the last washing that a "rubber like" substance was on the clothes after the wash. The noise only happens during times when the washer is filing up with water. During the spin and washer cycles where no water is entering the unit, it is as quiet as the day we bought it. I would appreciate any advise.
  • Anonymous Dec 01, 2007
    I have had several repairs done to combo unit that is less than 3 years old. The pump keeps giving out, impeller is stripped. I keep putting less and less clothes in and have spent about $1000 in the last year to keep unit, which is high water efficiency. Many wierd noises and too much time to wash and dry. Is it really worth it?
THEN AGAIN IT COULD SIMPLY BE THE FRONT DOOR BOOT. WHEN IT IS DRY, IT RUBS AGAINST A NOT SO PERFECTLY ROUND DRUM.(IN THE FRONT)AND THIS MAKES A HIGH PITCH SOUND.USE A CLOTH AND WIPE CAREFULLY BETWEEN BOOT AND DRUM. IT MAY ALLOW A GAP SUFFICIENT ENOUGH TO NOT RUB ON DRUM. IF IT WERE BEARINGS, ONE WOULD NOTICE WATER STARTING TO APPEAR ON THE FLOOR. IF THE NOISE GOES AWAY AT TIMES WHEN YOU FIDDLE IN THE FRONT, IT COULD SIMPLY BE THE BOOT.
Posted on Jul 26, 2007
One of two things: 1) you need to clean out your filter trap at the front lower left corner of your washer. Sometime items trapped here make funny noises. 2)The squeaky noise is caused by a secondary pump that is responsible puming water in and out of the washer. The part itself is $25 but labor to install it will be 5 times that amount.
Posted on Jul 12, 2007
    President:
  • 1,462 Answers
This is not 100% diagnosis as can't listen to noise but fault may be bearing lip seal disintegrating which is a serious fault and if im right then bearing will shortly go as well. reason it is noisy during start is that seal is dry and gets wet when full of water
Posted on Apr 19, 2007
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
Why is my LG TROMM frontloader dryer making a loud noise when running?
If the washer is making a loud noise the rear drum with bearing might need to be replaced. On this washer the bearing might not be sold separately, the entire rear drum might have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Sep 02, 2014 | LG 4925ER1015B 4924ER1010 Used Frontload...
I broke the intet hose filter on my LG WM2277HW washer. I have not been able to find a part number or a place to buy it from. Do you know anywhere that I can order this part from?
Most Ace hardware stores have these filters that fit into you washer hoses and are universal, you pull out your hose washer and install new screen and washer combo !
May 13, 2011 | LG WM2016C
Dryer making loud screeching noise LG Trom DLG5988S
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 03, 2011 | LG DLG5988 Gas Dryer
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
LG Wash WM2487H*MA- how to turn the tub clean feature on?
I have had this problem since I bought my washer. Some days the tub clean cycle will work....most days it won't. They have replaced the main board twice and it's still broken. I've had nothing but bad luck with LG appliances. Also bought a lemon fridge that took 4 repairman visits to fix. I will not buy another LG anything!!
Jan 17, 2010 | LG WM2487H Front Load Washer
Dryer makes a loud squeaky noise
probably a bad pulley or drum bearing
Aug 31, 2009 | GE DSXH47EGWW Electric Dryer
Dryer DLE5977W washer WM2277HW just bought used ones no operating manuals help need one for each piece where do i get them
Follow the links below with Internet Explorer ONLY, opening these files may require the free download of additional software for viewing:
WM2277W Then Click on English Manual
DLE5977W Then Click on English Manual
Aug 28, 2009 | LG DLE5977 Electric Dryer
My dryer is making a very loud squeaky noise. Is is the motor or something else?
Not the motor if it's still working. The noise is coming from the bushing that hold the drum in place.
Apr 05, 2009 | Maytag Dryers
LG WM-2277HW Front Load Washer Logo
702 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
