Question about Beko 324250WN 28" TV
How do you use a beko 32" hd tv as a pc monitor?
Ive follow the instructions in the Beko manual and have come stuck.
The tv just displays "Out of Range".
Can someone help me, thank you.
  • 1 more comment
  • czam2007 Dec 26, 2008
    Its a vga to vga connection
    Its a desktop if that complicates things
    th tv has a max resolution as 768p
  • czam2007 Dec 31, 2008
    setting it worked on was 800x600 true color (32 bit) using the 2nd part of the solution
  • Steve Allison
    Steve Allison May 11, 2010
    You are lacking some important info for us;
    Which connections are you using on each end?
    If the set does not automatically recognize the input source, you will need to set it via the TV's menu to match the input you have connected.
    And, you may have to turn on the laptop's output since there are no standards concerning default settings.
  • Beko Master
  • 5,568 Answers
Thanks for the detail-
VGA connections are pretty uncomplicated so the only thing that might need setting is the PC's video settings which may be set for higher than the 768 line standard.
The TV may not be sending information to the computer for Plug and Play use but you could try this anyhow:
- Have the TV turned on. the PC off. - If not still connected, connect them. - Turn on your PC.
If the TV set is conforming, it should send a signal packet to the PC with information about itself. You will see early if it had; a Windows dialog box should tell you 'Found new device (or hardware), installing software'
If that or similar did not appear, then after the PC is booted, Open the Control Panel, then the Display folder, then click on the Settings tab. You will see a linear control for the resolution that will step from one standard to the other, up or down from the current setting. Unfortunately, it won't change anything until you click on OK or Apply but it pauses after clicking shows the result then asks if you want to keep that setting.
Posted on Dec 26, 2008
How do i tune in a beko 15LV450S tv
There are two ways of doing this. Hold down the MENU button on your remote of manual TV button and select the TV tuning menu. Run the auto tune feature and follow instructions.
Jan 23, 2015 | Beko Televison & Video
HOW CAN I CONNECT MY SATELLITE C660-10T TO MY TV?
Hi. You need a VGA cable, the same that is used for Desktops (from monitor to base unit). Connect it to your laptops VGA port (a square(ish) port with holes in it), the the other end to a similar port on your TV. Switch laptop and TV on, connect your TV to PC input (read your manual if you are unsure), then on your Laptop select Fn and F8 or F5 (look for the Function key with two square boxes - or a small laptop and a larger box). Pressing those keys together will push the image to your TV.
Apr 02, 2013 | Computers & Internet
I have just acquired a Beko TV set,and need an instruction book to operate it. May I have oneplease?
if you please visit the link below you can find the user manual for your TV ..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
http://www.beko.co.uk/Manuals.aspx
Jun 13, 2011 | Beko 17WLB450S 17 in. LCD TV
I need beko tv code for matsui URC 11-4241 all for one remote
One For All 5 Digit Codes for Beko TVs.11314,23341,22413,11322,
23313,31341
One For All 4 Digit Codes for Beko TVs. 0714,0035,0486,0370,0037,0418,
0556,0606,0715,0808
also try try 0514 (for v) or 0398,0065
If none of the above work, let me know, I assume you have the instruction book for the remote so you know how to enter the codes. Let me know how this works out.
Benjamin
Nov 18, 2009 | Televison & Video
32" beko TV stuck in standby
Ur power board is dead.U need a new one.
Jun 21, 2009 | Beko 324250WN 28" TV
Sky codes for beko 32' tv
on the sky remote press the following
TV
RED + SELECT (blinks twice)
TV
0125
press the volume button,if it works press SELECT if not press TV then VOLUME again repeat this process of TV then VOLUME until it works then press the SELECT button to save the code to your remote.
Enjoy
Littlle Dish Fitter
Dec 27, 2008 | Beko 324250WN 28" TV
Need an instruction manual
In your browser bar typein--beko user manual.
Then click on beko.co.ok- user support, and follow instructions.
Plz rate this solution.
Thanks.
Dec 27, 2008 | Washing Machines
Cant connect my tv to my pc
Out of range means the screen resolution cannot match the output from your PC. Reduce the resolution on your PC.
Nov 09, 2017 | Televison & Video
Tv is stuck on av channel
no-not the tv try buying another remote from the manufacturer and that will solve the problem
Jan 06, 2007 | Grundig GF70-600 TV
Beko 324250WN 28" TV Logo
639 people viewed this question
Top Beko Televison & Video Experts
Marvin
Marvin
NOEL
NOEL
Are you a Beko Televison and Video Expert? Answer questions, earn points and help others
