If your remote is not behaving properly, you can reset it. To do so, remove one of the batteries, hold down the All Off button, and reinsert the battery. A message will appear on the remote screen indicating that the remote has entered safe mode. Next, connect the remote to your computer and sync it. The remote should now be updated and functioning properly.
Update the firmware: - Launch thesoftware. - Connect the remote. - Click "Downloads" - Click "Firmware." - Update the remote. That will get the remote out of safe mode
3. There could be a stuck button on the remote causing the symptom. Remove the batteries from the remote. Push in, and massage each button ensuring it is not stuck down. Replace the batteries and Update the firmware. Update the configuration (update the remote).
4. Remove the batteries from the remote. Manually place the remote into `Safe Mode` by holding off and plug in the USB. Upgrade the firmware in the remote. Update the configuration (Update your Harmony remote).
Hey, try doing the following:
1. Remove the battery, press and hold the 'OFF' button, and re-insert the battery. The screen will display 'Safe Mode!', or the 'Activities' button will be lit. 2. Connect your remote to the computer. 3. Launch the Harmony Remote Software, and log in. 4. Click "Downloads" at the top and click "Firmware". 5. The remote will go through the firmware update. 6. Select "Yes", and click NEXT to update the remote. That fixed my 550 a couple of times. Seems that a firmware update will cure most ailments. Hope it helps.
Hi There,
To get out of safe mode, do a firmware update from your PC. This will install the latest firmware and your configuration. Safe mode is a bootstrap designed to recover from firmware corruption issues so about the only thing it knows how to do is reload firmware.
However, if the remote fails to communicate with the PC when it is stuck in Safe Mode, please try the following.
1. Remove the batteries from the remote & check for any stuck buttons especially the Power button that may be causing the remote to stay in this state.
2. If it still will not apply firmware to get out of safe mode, then still without batteries hold down the #2 button while plugging into USB, and it should exit Safe Mode, and say something similar to 'Firmware Upgrade Success'. Even though it says this, still perform the Firmware upgrade since it was stuck in Safe Mode to begin with.
You can try this solution to your Harmony 550 Safe mode problem:
Harmony 550 Safe Mode Fix
Safe
Mode is a diagnostic tool in the Remote used for troubleshooting
purposes. If the words "Safe Mode" or "Safe Mode Requested" appear on
the remote, complete the following steps:
1. Ensure the Remote is in "Safe Mode Requested" by taking out the batteries, and disconnecting the remote from the USB cable.
2. Hold down the Off button and plug the remote into the USB.
3. Continue holding down the Off button for another 10 seconds. The remote should then display the words "Safe Mode Requested".
4. With the unit in "Safe Mode Requested", re-install the firmware by clicking Support on your home page.
5. Click Firmware in the Downloads section and follow the online instructions to upgrade the firmware.
6. Once the firmware upgrade is complete, click Update My Remote.
7. Insert new batteries into the remote.
To get your 550 out of safe mode, follow these steps.
1. Remove the batteries.
2. Hold the '2' button down.
3. While still holding the '2' button down, replace the batteries.
4. The remote will boot into the normal functionality.
Note: If the 'Off' button is held down while inserting the batteries, the remote will boot into 'Safe Mode'.
Also here for manuals: http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=logitech
remove one battery. press and hold the #2 while replacing the battery. hold the #2 until you see "upgrade success". press activities and you're back in business.
1. Remove the battery for a solid 2 minutes, then reinsert and see if that fixes it.
if not
2. try updating the firmware with the remote in safe modeSafe
