Question about Singer 3116 Simple
Singer 7444 won't wind my bobbin... please help...
The machine stops starts to beep and flashes on the stitch number window with 88 on it, the needle doesn't go in stop mode when my winder is pushed to the far right. I did everything by manual, it doesn't work, is my machine defective ? I just got it for christmas and yesterday was my first time winding the bobbin...
  • jrugs Jan 22, 2009
    I have the same problem.  Any answers?
  • Michaelle
    Michaelle May 11, 2010
    I need more info on the model # I cant find a 7444
    look here and tell me what model # it is.
    http://safemanuals.com/zearchres_826.php
2 Suggested Answers
nenndre
SOURCE: Singer 7444 won't wind the bobbin... please help...
I guess the machine was defective, i trade it to the new one, and the bobbin worked fine...
Posted on Dec 27, 2008
I buyed a new sewing machine curvy 8763 and when i start trheading the bobbin the needle stats working as well and it starts beeping
Consult your owner's manual. There is a handwheel release that, when loosened, will allow the bobbin to wind but stops the needlebar trying to stitch.
Oct 24, 2015 | Singer 8763 Curvy
Code 88 starts flashing as well as all the stitching lights on the panel when I try to thread the bobbin. I can sew, that is NOT the problem, threading the bobbin is. What is Code 88? I am not interested...
Turn your machine off and leave it off. Remove all bobbins - in the machine & from the pin. Remove all thread - from threaded machine and bobbin thread path. Clip the machine thread at the spool and pull the needle thread towards yourself. Clip bobbin thread at spool and close to bobbin, then pull towards you through thread guides. This keeps the tension where it belongs. Move the bobbin winding shaft from normal sewing back to winding bobbin a couple times. It should click in place when moved to the winding position. Check to see if there is any thread that has slipped under the bottom of the bobbin and wound itself around & under the bottom of the shaft. Carefully unwind to clear. If the shaft does not easily move back to the sewing position it is probably stuck in the winding position. Don't force it, but try to get it out of the winding position. Leave it to the left in the normal sewing position (unclicked). Check to see if there is any thread caught anywhere along the path from spool to the winding pin. Pay close attention to the first thread guide and the two discs the thread slips between that control tension. Hand wind the wheel on the right towards you to raise and lower the needle a couple of times. Stop with needle in highest position. Do NOT wind hand wheel backwards (away from you). Make sure the bobbin pin is not in the winding position. Now turn on your machine. Needle should jump to default position. Move the stitch length and stitch width guides to the far right, then far left, to attain the green lights. Press the reverse stitch button to raise lower and raise the needle. It will stop in the highest position. If you still have the error code - make sure the bobbin winding pin is NOT in the winding position. Remove the needle. Lower the presser foot and run the machine without any thread a bit. If the needle bar does not go up and down most likely the bobbin pin is stuck in the winding position. If the code has cleared use your manual to carefully wind a new bobbin. Make sure you are using a 15J bobbin which this machine requires. It will not work with just any bobbin. Next, raise the presser foot then carefully thread the machine. If you don't have a manual you can download one from the Singer website. You might consider cleaning the entire machine paying special attention to the hook area and feed dogs while the power is off. If you find a lot of lint do this more frequently to prevent buildup. Take special care when replacing the bobbin care. Hope this helps. If not call Singer. It may take some time but you should be able to reach someone to help you troubleshoot. If this is an older machine I recommend taking it for repair yourself instead of sending to Singer
reference: http://www.amazon.com/Singer-7466-Electronic-Sewing-Machine/forum/Fx3BSOY0VA78VQ4/-/1?_encoding=UTF8&asin=B000B91B3K
Mar 28, 2015 | Sewing Machines
I cannot thread my bobbin, I can sew. When I try to thread the bobbin, Code 88 starts flashing.
You said "trying to THREAD the bobbin." Did you mean it happens when you put an empty bobbin on and push the spindle to the right? Is your needle all the way up? If so, pull the buttonhole lever ALL the way down, then smack it up, and check to make sure the twin needle lever is not selected. Frankly, I'm not in love with that system anyway; you might think about purchasing an inexpensive Sidewinder for less than $20. You can order from WalMart online; if you pick it up at a WalMart or FedEx facility like Kinko's, shipping is free. Believe me, you'll do yourself a favor; many problems with these machines are actually caused by loosely wound and/or badly wound bobbins. Also, think about purchasing prewounds; they're actually cheaper than winding your own.
Jan 18, 2014 | Singer CE-200 Quantum Futura Computerized...
Singer 7444. Can't use button hole. I have
try changing the needle
clean under the needle plate and in the bobbin area
and make sure you use every thread guide
Aug 11, 2013 | Sewing Machines
My singer curvy starts beeping and lights flashing and won't sew
I just got mine to stop flashing lights and function again when I unplugged the cords from the machine and let it sit for a minute. You can always give that a try.
Dec 20, 2012 | Singer 8763 Curvy
Start sewing and starts beep say e2
try rethreading the machine top & bobbin
clean under the needle plate & in the bobbin area for loose threads or lint
May 20, 2012 | Singer 7422
Singer 7444 trouble winding bobbin
It sounds like you don't have any tension on the thread when winding the bobbin. Make sure that you are running the thread through the tension disc on the top of the machine before going to the bobbin winder.
Feb 28, 2009 | Singer 3116 Simple
Dec 26, 2008 | Singer 7444 Mechanical Sewing Machine
How can I get the bobbin to wind on my singer 7422?
Your machine could be defective. Take it back where it was purchased.
Apr 18, 2017 | Singer 7422
Singer 3116 Simple Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
