Question about Power Acoustik TS1920-2 Car Audio Amplifier
Amp blows fuses "immediately"... HELP
I have had this amp installed for about 8 months working without a problem. Now all of a sudden it is blowing fuses as soon as I hook the power, Ground, and switch wire up Conneting no speakers.. it blows the inline 30a fuse. I have no clue what the problem could be, as I have never experienced this... I am taking it to a audio store today to have them test the amp. HELP..
  • James Peoples Apr 19, 2007
    I took the amp out and put it in another car and it blew the fuse there also. I am sending it back as the 1yr warranty is up next month. I do hear something rattling around inside.
  • James Peoples May 31, 2007
    this is a followup .. I sent the amp to power acoustik at a cost of $28... been 3 weeks and supposed to return any day now.. i did take it apart and noticed there was a screw rolling around inside (NOt GOOD)it was from some part in there. i could not screw it back in place because it goes under the board.. I think the scre touched some parts it was not supposed too.. I cant wait to get it back.. driving is torture without the bump in the back of my saabhttp://www.cardomain.com/ride/2289746
For this to cause a problem with amplifiers there is something internally wrong with it. Most of the time the mosfets take a shit from the hot...cold....hot....cold atmosphere its put in by all of us audio people. If it still has warrenty that would be the easiest route to go. Send it in to them and have them fix it for FREE lol!! well sorta. Hope this helps you understand why you are blowing fuses.
Posted on Apr 20, 2007
SOURCE:
Why does my 20 amp fuse blow when the engine is running, but work without issue when the engine is off?
Why fuses blow or how to find short circuits or drains !
fixkick.com/power-elect/blows-fuse.html
(the Park (tail-running) lamps go to up to 20+ places) ... The below covers shorts in the cab box, not the 50-100 amp engine bay fuse box that loves to rust out.
Nov 02, 2015 | 2013 RAM - 1500
How can i get a replacement 5 amp 125 volt fuse for a holmes twin widow fan
It's worth noting here that it's more about the physical size & shape of the Fuse thats needed to fit your Fan.
You don't have to use exactly a 5 amp @ 125v fuse.
Any fuse that Fits and is in the range of 5,6,7,8,10 Amp and even 230v is ok.
The fuse is like a piece of soft metal that will melt if too much current is being drawn by the device. The Amps & Volts only define approximately when the fuse link will melt (blow). But as the fan gets dirty and older the LOAD it draws might get slightly higher. Enough to cause the fuse to slowly melt. So a small to 6, 8, or 10 Amp should work just fine. A wiring short will still cause the 10 Amp fuse to blow thereby keeping things safe. The manufacturer uses a fuse that fits in the space he has allocated & allows the unit to run continuously without blowing on a slight load.
But it is only a safety device to protect the device from internal shorts.
It stops a shorted motor or shorted internal wiring from getting too hot and possibly causing a fire.
But a 20 or 30Amp fuse would still blow if it is shorted.
For example...If the 5 A fuse keeps blowing then you could try say an 8 or 10 Amp fuse. If that blows then their is definitely a problem with the circuit. Don't put anything larger than 10 Amp in.
It then needs to be looked at by a service technician.
The voltage rating on a household fuse isn't that critical.
It's actually the wattage it takes to melt the fuse link. It's based on the mathematics of Ohms Law (Watts =Volts x Amps)
But thats another story....
Cheers
Trevor
Jul 16, 2014 | Holmes Products Dryers
My Solara Dsc radio, which has worked well for several years, suddenly began blowingthe 2 amp fuse on the red power line whenever the transmit button was pushed on the mic. Why?
No worries here.
According to Uniden, the 6 amp fast blow fuse is the correct one.
Not entirely sure why there'd be a 2 amp with your old radio, but I suspect the radio is good.
-Steve
Uniden VHF radio fuse Google Search
Dec 04, 2013 | Uniden Solara DSC VHF Marine Radio
Suddenly blows fuse as soon as plugged in why?
Usually a fuse blowing immediately means there is a short in the amp somewhere.
Jan 04, 2013 | Koss KS2503 System
Brake light fuse keeps blowing in my 1997 Suburban only when towing trailers.
If the fuse blows on different trailers then it's all down to the vehicle. You either have incorrect wiring on the vehicle, a short OR the fuse is not of a high enough value to cope with the additional brake lights? You could try removing all the trailer bulbs EXCEPT the brake lights - e.g. if it's trying to power up the indicators too? That would stop the fuse blowing...... OR remove the brake bulbs from the vehicle & see if it operates the trailer without blowing...... Check the total wattage of ALL the brake lamps & see if the fuse is actually of a high enough rating? Be aware though that increasing the value of the fuse could cause damage elsewhere! As a rough guide a 25 watt bulb will pull around 2 amps at 12 volts - so 4 bulbs may pull up to 8 amps & clearly blow a 5 amp fuse! If in doubt take it to an auto electrician...... The wiring needs to be correctly protected!
Apr 02, 2017 | Cars & Trucks
Escort 55 1.8d van fuse 25 keeps blowing and cant start my van.circuit says wiper and washers and it wont let me install new fuse without blowing.i have work on monday !Help!
Unplug the wiper motor and replace the fuse. If it works the wiper motor is shorted out. It may also be the wiring rubbed thrue somewhere causing a short.
May 13, 2017 | Ford Escort Cars & Trucks
No wipers, blows fuse immediately after insertion.
bottom line is that you have a short to ground in the wiper circuit
these are some of the toughest to repair
first thing you want to do is follow ALL the wires from the wiper motor and switch
inspect for anything that looks like it has been rubbed raw!
there are some tools I have that you can buy at most pro-shops, most are called short-finders
they work by applying a small current on the suspected circuit and then use a "finder" to indicate where the short is located
another old school method is to install a bigger fuse and follow the smoke! not a good choice on anything since 1980
good luck and keep us posted
Mar 26, 2010 | 1994 Ford Probe
No Power on 32" Panasonic
A slow blow fuse is also known as an anti-surge fuse the idea being any sudden "spikes" in you mains electric when you switch on would blow a quick blow fuse. Anti surge fuses are designed to tolerate any sudden initial electric pulse.
Jun 22, 2009 | Panasonic CT-32SL14 32" TV
Fuse blows
Both 3 or 4 amp slow blow fuses are suitable replacements for the 3.125 amp subwoofer fuse.
It could be that the subwoofer is blowing the fuse because the one you installed was not slow blow.
But, more likely is the subwoofer has a short in the power supply which is causing the fuse to blow.
May 31, 2009 | JBL PB10 Subwoofer
40amp fuse blows
Measure the DC voltage across the B+ and ground terminals as well as across remote and ground. If you have less than 11 volts when the amp tries to power up, the amp could be shutting down due to low voltage.
If the voltage remains near or above 12v, disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down or blows the fuse when you apply remote voltage (turn the head unit on), the amp likely has blown output transistors.
Nov 24, 2007 | Rockford Fosgate P3001 Car Audio Amplifier
Power Acoustik TS1920-2 Car Audio Amplifier Logo
129 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Dalynn Turner
Marvin
Marvin
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
