Question about Pc Ware M748LMRT Motherboard
I need the pcchips m748lmrt audrio driver. - Pc Ware M748LMRT Motherboard
  • 22 Answers
Try this driver
if not I need to know what socket type the mobo is.
Hope it helps
Posted on Dec 26, 2008
Hi, i need update bios for m748lmrt moteherboard
Goto this site and scroll to midle there will be your driver update for bios,download it install it,restart
http://pcchipsusa.com/BIOS/7482K1220S.ZIP
Jul 26, 2010 | Pc Ware M748LMRT Motherboard
USB connector for PCChips M748LMRT motherboard
You can buy USB card and install it in your PC you can get it from any local shop the card will look like the image below...
Feb 15, 2010 | Pc Ware M748LMRT Motherboard
Motherboard PCCHIPS M748 MR multimedia audio controller driver need.....where can i download this driver?????????
hola amigo soy oriol y tengo el problema que mi maquina no tiene el driver de sonido la placa es M748Lmrt-Xcel 2000 y necesitaria bajarlo y no se de donde y como gracias
Mar 23, 2009 | Pc Ware PCCHIPS M748 MR Motherboard
Falta instalar " la controladora simple de comunicaciones PCI"
Fijate en esta página que tenes los drivers de las PCCHIPS viejitas. Tenés además, que controlar que el jumper JP3 que habilita la placa de red.
Jumper JP3: Enable/Disable Onboard LAN Use this 3-pin jumper to enable or disable the onboard network adapter.
Function
Jumper Setting
Enable Onboard LAN
Short Pins 1-2
Disable Onboard LAN
Short Pins 2-3
SUERTE!!!!
Dec 23, 2008 | Pc Ware M748LMRT Motherboard
I'd like to know if its possible to boot a m748lmrt board from usb port
if you mean an operating system then yes you can providing the bios is upated first, go here:
http://www.updrivers.com/bios/Motherboard/PCChips/M748LMRT-BIOS/11174.html
hope this helps
regards
Nov 22, 2008 | Pc Ware M748LMRT Motherboard
Need pinouts
I have an old pc chips M575 motherboard that also uses the J3 ATX Form card. I can only assume the pinouts are the same so here they are from the manual.
Pins 1-4 and 10- 13 are USB connectors
USB USB
Pin Description Pin Description
1 +5v 10 +5v
2 data- 11 data-
3 data+ 12 data+
4 ground 13 ground
Pins 5-6 and 15-16 are PS/2 Mouse Connector
Pin description
5 +5v
6 Mouse CLK
15 Mouse Data
16 ground
Pins 7-9 and 17-18 are Infrared connector
Pin description
7 Ground
8 Reserved
9 +5v
17 IR in
18 IR out
hope that helps
Nov 18, 2008 | Pc Ware M748LMRT Motherboard
M748LMRT
Here is a link to the PC Chips website, where you can download any of the needed drivers for your motherboard. You can also get manuals, etc, there too.
http://www.pcchipsusa.com/PCCWebSite/Downloads/ProductsDetail_Download.aspx?detailid=45&DetailName=Driver&DetailDesc=&CategoryID=1&MenuID=6&LanID=2
Cheers,
Nick
Nov 17, 2008 | Computers & Internet
Motherboard
what i would do is contact the manufacturer of the computer and see if they can send you one you might be able to burn one off of the internet but be carefull regards mike
Aug 20, 2008 | Intel Motherboard
Fredy
I used to own one of these motherboards many years ago, it was difficult to deal with mainly because neither PCChips nor ECS who used to make most of the branded PCChips motherboards provided a great deal of information on them. I usually had to due quite a bit of personal research and educated guesswork with dealing with any ECS made motherboard. If I were you before jumping to many guns I would investigate the ECS website for anything that looks like your motherboard ( it may not and probably doesn't share the same model # if my memory serves ). Be very careful of what your eyes see as ECS motherboards are notorious for being very similar between models but other then their apparent visual similarity, they are quite different. I.E. it could be quite easy to install a Bios update onto what you think is a particular motherboard due to its looks, but in reality the bios update would be for something quite different, which usually kills the motherboard of that age group.
However since you mention PCChips, this is their coverage of the related M748LT motherboard which is related but they seem to no longer cover the M748LMRT, which is why I suggested looking at the ECS site also.
http://www.pcchips.com.tw/PCCWebSite/Downloads/ProductsDetail_Download.aspx?detailid=45&DetailName=Driver&DetailDesc=M748LT%20%20(V3.x)&CategoryID=1&MenuID=82&LanID=0
I just checked on the ECS site and there no motherboards with similar model #s on their site. Do your best to use manufacturer website to get your drivers as many commerical ' driver finder ' sites are not near as good as they claim to be and can often lead to faulty information about drivers or chipsets used on your system, especially with these older motherboards.
I hope for you Good Luck as I suspect you will need it when dealing with an ECS or PCChips motherboard..
Jul 25, 2008 | Computers & Internet
Pc Ware M748LMRT Motherboard Logo
295 people viewed this question
Top Pc Ware Computers & Internet Experts
David Payne
David Payne
Are you a Pc Ware Computer and Internet Expert? Answer questions, earn points and help others
