Question about Radio Controlled Models Fuel or Electric Super Bobcat 25 - 39.4" Nitro Gas Radio Remote Controlled
Rc car will not start
Fuel is in, glow plug warmer is charged, charging motor works fine, will not start
suggestions?
    President:
  • 2,110 Answers
There are two main factors in making an engine start. First, the glow plug must be working. This means that when 1.5 volt is applied, the filament will burn a bright orange. A bad glow plug will not generate enough heat to burn the fuel/air mixture in the cylinder. Second, the engine cylinder must have the correct fuel/air mixture when cranking the engine (via pull-start or bump start). If there is no fuel in the cylinder, the glow plug has nothing to ignite. And if there is too much fuel in the cylinder (i.e. flooding), even a new glow plug will not have the energy to burn the excess fuel.
Posted on Dec 26, 2008
Why dose my 2002 Volvo xc90 d5 not start in the mornings
I have similar problem different vehicle, my ignition was not connecting well and the glow plugs were not initially getting properly hot, not sure how to fix it/ I disconnected the battery entirely and unplugged what I could and switched # 1 for #3 plug and waited overnight and charged the battery out of the truck, next day put all back and attached battery and started right up right since , so try take out battery and charge better first.
Sep 16, 2016 | Volvo XC90 Cars & Trucks
Engine cuts off as soon as I take the glow plug warmer off new glow plug rc truck .18 engine
check the wiring on the switch as there appears to be a brake when you turn the key from start /glo to run which is turning the pump off.
Aug 10, 2014 | Cars & Trucks
I have a Jato 2.4 from traxxas and i cant get it to start and i charged my battery all night
you need to pull the glow plug out and see if its good visually; look at the coil in the hole in the bottom it should look like a spring unbroken. If you have a glow stick put it on the plug and see if it glows. If you can just replace the glow plug they go bad and it may still look fine.
you need to set your main carb needle to 3 turns out from closed.
Now with the glow plug out place a clean rag over the cylinder head where the plug came out of and use you starting wand to turn the motor over........the rag is there to keep fuel from spraying in your eyes. turn the motor for 5 seconds.
Next put the plug back in and gently tighten it down with an 8mm socket. Put your plug wire back on and try to start the engine for 3 seconds. If it starts up reves high then dies try this.
Put your finger over the exhaust and turn the motor over until you see gas go into the carb the remove your finger from the exhaust and continue to crank the motor for no more than 10 seconds.....she should start now. Adjust the carb according to the manual. Have fun.
Mar 25, 2014 | Traxxas 5507 Rc Jato 3.3 Nitro Stadium...
Have a nitro RC pursuit boat won't start glow plug
check to see if the engine has compression by taking glow plug out and putting finger over the hole and pull the pull start it should pull your finger you will be able to tell if it is without compression it wont be able to pull fuel in there for it wont run
Jan 24, 2012 | Boating
My revo is getting fuel light on start remote are on both motor and glow plug engine will just turn over but will not start up
Hi
You've checked the glow plug externally to see the wire get red? If so, as long as you've got fuel and fire then it has to start. My guess here is that you have either a bad glow plug, low batteries, fuel air leak or clogged pressure line. Put a charged battery into the starter. Remove the glow plug and try to start - fuel should spurt up through the glow plug opening. Now connect the glow plug and touch it to the engine. Try to start and you should see the glow plug wire glow red. (do this only for a second. Now disconnect the pressure tap from the muffler and try to start. All else fails, replace the fuel line to the carb and the pressure tap. Your carburetor can leak air through the rubber gasket . Also, Traxxas fuel tanks have a cracking problem. Good luck
Apr 14, 2010 | Traxxas Rc Revo Nitro Monster Truck
Ford focus 1.8 tdci MY 2003 terrible cold start
only takes one glow plug out of order to cause problems . check them for proper volatge and resistance
Mar 30, 2010 | 2003 Ford Focus
I have a 2.4L diesel Toyota Hilux. Its was -30 and the battery died. I have since jump started it and it drove fine (when the battery was dead and tried to start it in very cold, my husband thinks it could...
diesel engine have small starter helpers called glow plugs that heat the combustion air so that it can self ignite the diesel fuel
reasons for hard starting are
slow cranking speed---battery not charged enough or not big enough to do the job
injectors squirting and nit atomizing--- take the car to an accredited diesel pump/ injector repair shop for tip replacement and adjustment
the check engine light could be from faulty glow plugs
keep the fuel tank full ,especially in cold climate as there is hot return fuel from the injectors that causes condensation in the tank--water -- and that promotes the growth of a fungus which damages the pump and injectors
use diesel fuel condition on a regular basis to prevent that condition or keep the tank more that 3/4 full to stop condensation occuring
Apr 20, 2017 | Toyota Cars & Trucks
I have an Aprilia Mojito 50 2002. Won't start.
Hello. The interesting thing about these small motor cycles is that their charging system is not adequate to keep the battery fully charged. I recommend that you charge the battery fully and then start it. When the battery is totally dead, even a kick start will not start it. The charging process may also indicate that your battery needs to be replaced. If you are still using the original battery on a 2005 I would begin by having that battery tested at any auto parts store.
Nov 23, 2009 | 2005 Aprilia Mojito Custom 125
The thing you put on the back of the truck will not work only the motor lite comes on but i no its not the glow plug
Have you charged the battery in the EZ Start wand? If you have is the motor turning over at all? If the motor is turning over but not firing it could be the glow plug. If the motor trying to turn over but won't, the engine might be flooded. If it is flooded remove the glow plug and turn the truck upside down. Fuel will run out of the engine. If fuel runs out of the engine, put the truck back down on its wheels. Cover the engine head with a rag and turn the engine over with the EZ Start wand with the glow plug still out. This will remove all excess fuel from the engine. Reinstall glow plug and try to start again.
Oct 21, 2009 | Traxxas Rc Nitro Stampede Rtr 2wd Monster...
Won't Start & No glow Plug Light on Dash
I am with a similar problem...
After putting on a new sump i found that the starter motor would work cranking the engine but no power is going to the glow plugs. The light on the dash does not appear either.
The relay for the coils does click but that is the end of it. I have a suspission it is the imobiliser but after taking the battery on and off several times to reset... still nothing.
There is fuel, good battery (fully charged), fuel lines are clean pressurised...
Any ideas???
Feb 11, 2009 | 1991 Peugeot 405
Radio Controlled Models Fuel or Electric Super Bobcat 25 - 39.4" Nitro Gas Radio Remote Controlled Logo
48 people viewed this question
Top Radio Controlled Models Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Radio Controlled Models Toy Expert? Answer questions, earn points and help others
