Question about Microsoft Xbox 360 Console
No audio no video
Checked all cables wires evreything working but blank screen
  • titanfrompso Dec 26, 2008
    I was playing Oblivion when the picture went crazy. Everything went fuzzy like an old TV. I turned off my 360 and turned it back on hoping it would fix the problem and the sound works and I can hear the menu popping up but there is no picture displayed on the screen. I tried everything from trying it on a different TV to using a new set of AV cables and nothing worked.
  • Anonymous Apr 12, 2009
    yo man did urs get fixed because mine is the exact same problem
    Sergeant:
    Champion:
  • 378 Answers
Its the same as the 3 red light error GPU solder . It will need to be serviced if not under warranty we do offer a fix if you are interested xbox360fixer@verizon.net
Thanks
Posted on Dec 26, 2008
Tv doesn't connect though coaxial hook up
Most of these TVs show a blank screen unless they are receiving a sinal?
Jan 28, 2014 | Hitachi 50HDA39 50 in. Plasma HDTV
Power comes on but it only shows a blank screen. screen shows nothing at all no menu, nothing. tv works fine.
Make sure the video/audio cable is plugged in correctly. Red cable into red socket, yellow into yellow and white into white. It is easy to put these cables in the wrong socket by accident and will cause no image to appear on your screen.
Jun 12, 2011 | Video Game Consoles & Games
Snes console scart wires blank screen
Troubleshooting - Video
Quick Tip! If you already have your system connected using AV cables and you are getting a blank screen, it is likely all you need to find is your input select, Check out our Input Select Locator
Blank Screen
Scrambled Graphics/Other
Blank Screen
Make sure your system is hooked up correctly. This is the number one reason for a blank screen. To ensure all hookup connections are firm and correct, remove the AV cables and reinsert them with a slight twisting motion (this will help fully seat the connections). For more information about connecting the system, check the following hookup steps:
Audio/Video Cable to a TV
Audio/Video Cable to a VCR
Make sure you are using all licensed accessories with your system. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly.
Make sure the system has power. If not, go to the No Power Light instructions.
Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to ensure it is locked in place. Slide the Power Switch on the Control Deck to the ON position.
Important Note: Inserting the game with the Power ON may result in a blank screen. Always turn your system OFF before inserting or removing Game Paks
There may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (where to buy). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.
If the above troubleshooting doesn't fix the problem, click here.
Other Screen Problems
Make sure you are using only licensed accessories with your system.
We find that video problems occur most when an unlicensed RF switch is used. Make sure the name "Nintendo" is molded onto the RF switch, as opposed to "for use with Nintendo." Unlicensed products are not fully compatible with our systems and may not work correctly.
Check all of the system connections to verify that they are firm and correct.
For AV connections
Remove the AV cables and reinsert them with a slight twisting motion
For RF connections
Make sure the channel switch on the TV and system are set to the same channel (either CH3 or CH4)
Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to make sure it is locked in place.
Important Note: Removing the Game Pak with the power ON will cause the Game Pak image to freeze on the screen. Press Reset to correct the problem. Always turn your system OFF before inserting or removing Game Paks.
If the above troubleshooting doesn't fix the problem, see below.
What to do if Troubleshooting Doesn't Help
Due to the age of the system, we no longer offer factory repairs directly from Nintendo. Please click here to find out what options are available for repair or replacement of your product. If you simply need to order parts or accessories, you may want to check out our Online Store. Nintendo's Online Store still carries many parts and accessories for our older products.
Mar 30, 2011 | Nintendo Super NES Console
My super turns on but i dont get any audio or video but the screen isnt black or nuthin its grey, what should i do?
Feb 21, 2011 | Nintendo Super NES Console
I havent played my super nintendo in a couple years and everytime i try and play it now i just get a blank screen...ive tried rehooking up everything multiple times but the screen is still dark....any...
Blank Screen
Dec 12, 2010 | Nintendo Super NES Console
No input from cable connection
Sounds likely you have a bad tuner. If you have a cable box with your cable service and it is upgraded for video and audio rca jacks output you can run red white and yellow wires to tv input where the DVD is connected or additional jacks if available. This bypasses the tuner
Jan 01, 2008 | Televison & Video
Dead screen
1 CHECK FOR VIDEO INPUT CABLE 2 CHECK BRIGTNESS,CONTRAST CONTROL FOR OPEN 3 IF IT IS CONNECTED WITH DVD CHECK FOR LEADS CONECTION REST NEXT TIME THANKS
Dec 27, 2005 | Emerson MT-1561 5.6 in. Car Monitor
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
