Question about Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
Mpi monitor 422 heat problem
My mpi monitor 422 starts to heat after about 5 minute the burner status blinks and no fan operation
  • Gail Stansberry
    Gail Stansberry Jan 01, 2009
    My heater is doing the same thing, let me know if you get any good answers.
  • sl5wysocki Jan 01, 2009
    Mine just started doing this after 2 years of trouble-free use.
    I'd be glad to hear about solutions...
    swysocki
I had the same problem last night and this morning. Its in the manual. I had to take the fan off of the back and vaccuum out all of the dust/lint that built up and it was a lot. It is a safety feature. It's a overheating protection feature that usually triggers if there is build up in the fan, front vent or vent pipe to the outside. I hope this helps.
Posted on Jan 06, 2009
Your 422 most likely failed flame verification. This is not a "do-it-yourself" fix. Call your local service person. There are a lot of reasons this can happen.
Posted on Jan 18, 2009
    Novelist:
  • 126 Answers
Sleddog,
Your stove has probably never been serviced. There is a good chance the burner mat and burner ring need to be serviced. The mat lifts up on a corner and the ring warps, both of which make the flame not get onto the flame sensor. This causes the stove to light and then turn off. It quits way before the fan circuit calls for circulation, so no fan in the back. You will probably have to get a dealer to service your unit or do it yourself.
Tom Hawkins
hawkins111@gci.net
I have a Armstrong SX80 gas furnace, T-stat calls for heat, combustion fan starts, in 1 1/2 min burner lights,this month t-stat calls for heat, combustion fan starts no burner ignition,
Check pressure switch and hoses to it . check air filter is clean . check you have gas in the line . check connections on gas valve check flame sensor
Dec 05, 2017 | Heating & Cooling
No heat from furnace, Goodman GMPN080-4 Rev A. Cycle is solid red status light, then 3 flashes indicating open pressure switch because the inducer fan does not come on.
Jimbo, it sounds like you are aware of the operational sequence to suggest using a voltmeter to check the actual wires going TO the combustion air fan...if there is no voltage from the board, the board is bad. Just make sure one of the high temp limits are not open... one may be in the blower compartment on some and one will be near the top of the vestibule and a roll out switch should be near the burners. They should all be wired in series.
Always check the manual reset safty switches as the first step in troubleshooting.
Nov 21, 2015 | Goodman Heating & Cooling
Monitor 422 heater
Count the number of light flashes. This is a trouble code. There should be a troubleshooting guide that came with the heater which should tell you what the problem is.
Jan 04, 2018 | Heating & Cooling
Our Monitor MPI 41 model heater won't stay on. It flashes 88:88 in the time/temp window and the Burner status flashes high. When we shut it off (power down) and power it back on it works until it reaches...
Mine is getting fuel, but it still clicks off like the original post stated, and its clean. The only other thing .. that water in the tubing. We get a TON of watered fuel here in Alaska! Damn oil venders.
Dec 31, 2010 | Heating & Cooling
Model 21 ,start monitor and the fan starts and orange lights come on ,then the lights bounce to 100 % and then back to half and then back to 100% real quick and the fan qiuts and heater never gets the...
This sounds like it is going to be a circuit board issue. When you turn it on the blower should start and the igniter will begin preheating the burner. After 3 minutes the burn lights should come on and you should begin to see some flame with a few seconds. The heater should burn on low for about 10 minutes to allow it to become evenly heated before going to high.
Dec 10, 2010 | Heating & Cooling
I have a Monitor 30, it comes on and just runs, it will not lite until I lift the primer once or twice, then it heats fine. I checked the filter and made sure the tank was high enough for a 5 gallon...
Rob,
You have some kind of fuel problem. When you mention 5 gals of fuel, that leads me to think you need more fuel ( more pressure). If you have a large tank and only have 5 gals you may no have enough head pressure to push the fuel through the line and all the filters in the system. That being said the Monitor 30 is the oldest vented heater around. Parts have not been available for 15 years. The thing that scares me about the M30 is the flame safety circuit. I don't think it is adequate. If you rely on this heater to keep pipes thawed I would get a new Monitor or Toyo.
Tom Hawkins
hawkins111@gci.net
Mar 03, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
I have a Goodman furnace GMPN080-4 REV B. I had the blower motor take a dive, so I replaced it with another equivalent 115 VAC 60 Hz 1/2 HP motor. I replaced the 10.0 MFD +10% -5% capacitor with a 7.5 MFD...
limit switch is on the heat exchanger black plastic about 1and1/2 in. by 2 in. with 2 wires going to it , it has 2 screws holding it in take it out and check it with an ohm meter and you should not have a reading if it is good
Feb 01, 2009 | Goodman GMS90703BXA Heater
Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
6,969 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Hjalmer Lamminen
Hjalmer Lamminen
Craig Butler
Craig Butler
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
