Question about Toshiba 65HDX82 65" Rear Projection HDTV-Ready Television
Toshiba 65h82 when i first turn on the tv it goes full green.approxitmitly 2.5 mins i have agreat picture, then the picture goes to full red, had a problem with the hyperboard,waivy lines.replaced al the caps, and two chips stk392-110.was told they woud go bad soon. any help figuring out why the screen goes from green to full red in about 5 minutes would be much appreaciated. i have all the service manuals, scops,generators, the avia disks. please give me some help on this before my wife shoots me Dan ORiordan
  • 3 more comments
  • Dan ORiordan
    Dan ORiordan Apr 18, 2007
    played with the service mode alittle, no help.
    did an aligment and a convergance
  • Dan ORiordan
    Dan ORiordan Apr 19, 2007
    Din't pull the gun boards, because after removing the front panel i could see all 3 guns firing.My high voltage probe is broke,working on another one to check the voltage coming from the flybacks. Here some pics.
  • Dan ORiordan
    2.5 minutes into the tv first turned on.
  • Dan ORiordan
    5 minutes after tv power up.
  • A L Apr 11, 2009
    ok so i started rebuilding a hyper module on thursday and when i was finished i had a red screen. i pulled the board and worked on it over night changing the remainder of the capacitors. fine.
    I went back the next day and still had a red screen so i moved on to my next job which also happened to be a hyper module rebuild. i put in  the board i had previously rebuilt and caused a red screen. so i rebuilt the new on and fixed the set.
    now i have a board i have no idea how to fix. going over my work to see how i could have caused the failure. will post when i have a solution. but i determined with certainty it is on the hyper board.
  • 81 Answers
Check the screen voltages goinfg to all three tubes. Another thing you could try is unplug the crt socket to the red and see if the other tubes stay lit . There ia a possiblity that the red tube could be over powering and shutting the others off or down.
Posted on Apr 19, 2007
Toshiba regaza 37rv635db wont turn on
seems like capacitor problem, chack them and if thay have exploded replace them.
Aug 25, 2013 | Toshiba 37RV635DB Regza 37-inch Widescreen...
65H82
Have you tried to contact ptscorp.com yet. Go to their web site and get their telephone number. They should be able to help you with a good hyper board. this might be your problem with what the set is doing now. Did you have this problem before you worked on the scan converter board?
Sep 08, 2007 | Toshiba 36HF72 36" TV
I have a Toshiba 65H82 and at first the picture was blurry but would clear up after about 10 mins now the picture just stays blurry. Can you tell me what the problem could be and if it is worth fixing it?...
Try adjusting the focus block this requires opening the back and front bezel of the TV. If it doesn't clear up after adjustment attempts then the liquid coolant inside each of the tubes need to be emptied and refilled with new coolant. Over time the coolant gets cloudy and can cause a blurry image with a white sheen. Contact me at the link below so I can help you further.....if this helps please rate:-)
Thank you:-)
http://tvtechwork.webs.com/
Oct 21, 2010 | Toshiba 65H82 65" Rear Projection...
My picture is jittery and goes all over can make out and picture
Ur tv have a convergence problems,it dead.U know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 01, 2010 | Toshiba 65H82 65" Rear Projection...
SONY TV PICTURE TURN GREEN WITHOUT RETRACE
Picture goes to high green with retrace lines that shows picture tube is defective and requires replacement.
Usually in above symptom, TV goes to standby mode and standby light blinks when green raster problem occurred.
New TV is better option because picture tube of KV-34XBR960 would not be available any more.
Thanks.
Aug 14, 2009 | Sony Televison & Video
Toshiba tv will not turn on
I have a toshiba tv and it will not turn on. There is a flashing green light that comes on, but there is no picture or sound.
Oct 31, 2008 | Toshiba DVD Recorder AND Series2 TiVo...
TOSHIBA 65H82
you need to replace your 2-convergence ic's #STK392-110 you need to replace both ,,they are attached to 2 big heat sinks and identified as q-751 & q-752 you can get the ic's you need plus free tec support and installation instructions including pictures at the link I gave you.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Toshiba 65H82 65" Rear Projection...
65H82
what you did forget you just tell what is your problem now clearly so i can help you in a systematic way.
Toshiba 65HDX82 65" Rear Projection HDTV-Ready Television Logo
135 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
