Question about Creative Labs ZEN V Plus MP3 Player
My creative zen v pluse dosent even turn on or charg or .....
It dosent do anything at all what can I do to fix it
exampel: open it and do somthing
ohhhhhh plz help !!!!
    Novelist:
  • 146 Answers
I had a similar problem with a Zen Xtra 30GB. I found that if I hooked up the charger to it and then plugged and unplugged it in to the wall socket several times (not from the player end of the charger) it shocked it back into charging again. It worked for me and a couple other people.
It's a 50-50 shot. It will either work or not.
It won't turn on cuz the battery is 100% dead and there is no power from the charger for whatever reason.
Cheers.
Posted on Dec 27, 2008
My creative zen won't turn on it's vision m 30 gb and when you plug it in all it dose is flash It doesn't pop up or even say anything in my computer PLEASE HELP
I am unable to reset my ZEN Vision M player. It will not even connect with my computer and the battery is completely dead. Is there a solution?
Jul 03, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative zen won't turn on
had same prob to the T...found this post and it fixed it...it's the computer not the zen...once I did the two steps my zen started charging and turned on...go figure...the flashing blue light doesn't mean it is charging.
posted on Feb 25, 2009 abeales
If you have windows set to do automatic updates, you most likely had a windows update installed that caused this conflict with Win Media Player 11. No fix has been posted by Microsoft yet, so the only workaround is to Uninstall/Rollback Windows Media Player 11. Goto <Control Panel<Add/Remove Programs and remove Windows Media Player 11. Follow prompts, restart computer when prompted to. Also uninstall Windows Media Player 11 Runtime application following same procedure above.
This will roll your Windows Media Player back to version 10 or 9, whichever you had installed prior to version 11. You will need to re-configure Windows Media Player again.
Your Zen should now be recognized by WMP and Creative software. You probably need to upgrade your firmware at this point, follow the instructions on upgrading your firmware, and you should be good to go.
This is a windows problem, not a creative problem. Dont blame Creative for the screwed up hotfixes that Microsoft puts out on a regular basi
May 28, 2009 | Creative Labs ZEN Vision:M Digital Media...
My creative zen player used to connect to pc now it dosent
my pc stopped detecting my zen. i tried and tried on all different pcs and nothing would pick it up. couldnt even get the battery sign on the zen. thought it was knacked. then one day i plugged it in again, got distracted and walked away. when i came back about two hours later, it was detected and charging. thought maybe that it was so flat that it had to charge a wee bit before it could display anything or the pc could find it. i dont know, dont know much about these things. just a thought
Apr 24, 2009 | Creative Labs ZEN V Plus MP3 Player
My creative zen v pluse dosent turn on at all dosent charg and...
http://support.creative.com/Products/Products.aspx?catid=213&catName=MP3+Players GO HERE. download a service manual or here I've had mine for 10 months, and the battery is dead. I did pry the Zen apart. There's 3 plastic pieces that hold it together. Just wedge a common screwdriver on the lower front piece first. Then remove the upper piece around the viewing screen;
http://i33.tinypic.com/2rnhhfm.jpg
The little monitor is held into position using double face tape. Gently pry it away from the circuit board. DO NOT REMOVE THE RIBBON CABLE. Let it hang by the cable. Then remove the two screws holding the board to back piece. The battery is mounted on the back side with double face tape pry it off and use a soldering iron to remove it from the circuit board.
http://i36.tinypic.com/8vqg61.jpg
http://i37.tinypic.com/20kspis.jpg. RICHARDM69
Dec 07, 2008 | Creative Labs ZEN V Plus MP3 Player
Zen Creative - How to get out of Recovery mode?
you should ask her for the disk then put it onto your computer then try to charge it...if it dosent work try to reset it.
Sep 09, 2008 | Creative Labs Zen Digital Media Player
Creative zen
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
Feb 11, 2008 | Creative Labs Zen Digital Media Player
Docked
Nov 04, 2007 | Creative Labs Zen V MP3 Player
Annoying Problem with my creative zen v
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
try downloading the
MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
By the way, before updating the firmware, let the battery have a full charge, ok?
I hope it won't keep freezing on you after the update.
Nov 03, 2007 | Creative Labs Zen V MP3 Player
Creative zen v plus
update to the latest firmware
Oct 28, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
29 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
