Question about Minolta Freedom Zoom 90 Date 35mm Point and Shoot Camera
Camera problem After switching on camera lense comes out but when we try to do something else like adjust the lense or click the photo then all indicators on to the lcd diskplay get blinks and camera get hang.
0 characters
1 Points
Canon prima flashing E
First reaction, when your camera acts strange, is to switch it off. Then when the memory access light stops burning, or flashing, you can remove the battery (Batteries) Give it a few seconds, and then reinsert the battery. Now the camera will start from scratch. So if the problem was caused by a software problem, it should be solved.
Only when after switching on, the error reoccurs, you have a bigger problem, that perhaps only can be solved in a photo store, or at the service centre, closest to you.
Jan 26, 2014 | Point and Shoot Film Cameras
Hi. A friend gave me a weathermatic dual 35 camera and said that it may need some work. I replaced the aaa batteries and turned it on, the lens moves, the red light comes on but it will not take a photo....
Your camera very likely has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the manufacturer's service department in your country to find out about a free repair [EDIT: this option definitely will not apply to your camera as it's too old and Minolta no longer exist]. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
Good luck, I hope you manage to use this information to fix your camera, or at least are able to use the information to help decide whether to buy another camera. If you do decide that you have to throw your camera away then don't forget to remove the battery as it can be used in other devices. Please take a moment to rate the free answer I have provided for you.
Jun 15, 2011 | Minolta Vectis Weathermatic Dual 35mm...
I got my pentax k2 camera lens cleaned for it has got fungus. Now the lens has been completely ruined and I am not being able to use the camera at all. Could anybody tell me where can I get lens for the...
Cleaning a lense for fungus is an iffy if not impossible procedure most of the time as the fungus attacks the material of the lense itself and parts of the lense have to be removed to remove the fungus.
But, the good news is any dealer of new or used equipment will have K-mount lenses. You can find both new and used lenses from B&H, KEH, Adorama, Calumet, and others - though those are some of the most reputable online/mail-order dealers of used and new equipment. You can find almost any kind of lense you'd desire.
Oct 01, 2010 | Pentax K2 Film Camera
The shutter button does not appear to click down and the lense does not open so no picture is taken. Usually it makes a sound and you know the picture has taken. HELP MEEE????
I had a similar problem with another brand of this type of camera. I would click the shutter and hear it open but it would not go through the series of four lens exposures unless I manually turned the film advance wheel . I think it may be because the motor isn't strong enough to draw the film across and trigger the shots. cheap plastic, ya know. I never got the film developed but im interested to see if it got anything at all.
Oct 28, 2009 | Lomo Action Sampler 35mm Point and Shoot...
Camera wont eject photo when picture is taken.
This is due to an old photo pack as they're all past the use by date now: the battery built in to it had just enough power to eject the protection sheet and take a photo, but then went flat. There's nothing you can do to remedy this unless you fit an external battery pack. There are no kits to do this with, you have to rig something up on a DIY basis but it is fairly simple with a few basic tools and a little ingenuity. The original batteries were 6v and the camera works at 4.5v; the higher voltage gives a bit of leeway as the battery slowly discharges whilst the film pack is stored and unused.
Jun 18, 2009 | Polaroid 600 Film Camera
Error message L1 and L2
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
May 31, 2008 | Leica Minilux Zoom Date 35mm Point and...
Instructions for operating leica vario-elmar minilux zoom
I don't have a C1, but in all probability it's the EV (exposure value) compensation adjustment, and should be variable between about +2 and -2. Usually the middle/zero/auto/normal (whatever they call it) setting is fine, but sometimes you want to overrule your automatic exposure settings, which are intended for an average-brightness scene. For example, a photo of a dazzling white snow-covered field will probably come out a soft, easy-on-the-eyes light gray unless you kick up the exposure a notch or two. Try taking your camera to an unusually bright/dim location (a beach, inside an old church) and take the same shot five times, with EVs from -2 through 0 to +2. Then look at the resulting photos and decide whether the effects are pleasing/useful or not (warning--sometimes automatic photo processors will try to reset the picture to average when they print the photo, so you may still end up with minimal differences in the shots). A good beginner-level explanation of EV compensation is at <>.
Feb 18, 2008 | Leica C1 35mm Point and Shoot Camera
Olympus Stylus Zoom 140 All Weather 35 mm
Make sure the flash is coming up all the way. If it gets stuck even slightly down from fully raised, it will do what you describe.
I agree, digital P&S won't work as well as your Olympus. Plus all your shots will have to be stored on a hard drive-
Jan 01, 2008 | Olympus Stylus Zoom 140 35mm Point and...
No picture
it seems that the flex ribbion cable from the camera body to the lense assembly is damaged. A good repairer can replace it.
Oct 28, 2006 | Samsung Maxima 120Ti 35mm Point and Shoot...
Minolta Freedom Zoom 90 Date 35mm Point and Shoot Camera Logo
18 people viewed this question
Top Minolta Point and Shoot Film Cameras Experts
David Payne
David Payne
Tony Parsons
Tony Parsons
Are you a Minolta Point and Shoot Film Camera Expert? Answer questions, earn points and help others
