Paper tore during removal small piece left in printer in area of printer heads
SOURCE: 'paper jam' error on canon pixma ip4300
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
SOURCE: Loose screw jamming paper in Canon Pixma MP530 printer
Go buy a magnetic retriever from your local hardware shop they are very cheap.
Make sure you get a slim version
Either that or turn the printer upside down and get someone to whack it on the bottom with the palm of their hand as you hold it
What goes in must come out
SOURCE: Printer is saying there is a paper jam in the paper output slot.
Pixma MX860. Got a "Paper output slot. The paper is jammed. Clear the paper and press OK" message. This happened out of the box new. The solution was the replacement of the printer. Cannon is sending a tested model and providing return postage to return the defective unit.
SOURCE: small paper jam
Unplug the power cord and open the cover and remove all the cartridge and try to look I inside around the roller and try to manually roll the roller and if you can see the paper try to pull is slowly.
Have a nice day and do not forget to rate please...!
The piece of paper is approximately 21/2" by 4" of the right leading edge of a 81/2" by 11" sheet. The paper must have curled because it backed up against the discharge slip. I removed the rest of the sheet but can not see the piece. The error code is C000. The ink cartridges block all view of the piece. Is there any way of getting this piece of paper out?.
