Question about Marvin 2060 Compact Heater
Need off-low-high switch for Marvin 2060 heater
My Marvin2060 heater would not come on. After checking the reset (OK), I opened the unit, and, with an electrical meter, I determined that the off-low-high switch is defective. This is a three position switch.
The switch looks like a square wafer (about 1"). On one side is stamped: 13A 120V. On the other side is stamped: Tower Mfg 6A 120V.
Can you help me find this switch?
    Problem Solver:
  • 18 Answers
As you probably know by know Marvin is no longer in business. The original supplier of the electrical switches was tower mfg. They will not sell to distributers or supplies due to chance of legal matters, they will only sell to oem's. We have looked extensively and have found one supplier at present, if you find on please let us know. The switches we have purchased are 120VAC 13A and have exact mounting, one tab one screw with press in wire connectors. The only difference is this switches' stem is 5mm shorter. This means the bottom outside of the original control knob must be shaved 1/4" this will make for a perfect fit and will make this knob the same thickness as thermostat knob. This switch sells for $6.95 plus postage and comes with directions for modifications.
Posted on Feb 28, 2009
  • Howard Eberhardt
    Howard Eberhardt Dec 31, 2014
    IIs this switch still available? If so I need one, please email me at howeird@pageamerica.net. Thank you, Howard Eberhardt
The rotary switch off/750/1500 is bad. Marvin 2060 quartz heater. any replacements?
replaced the rotary switch with a double poll single T. this makes the heater a 1500 watt with no 750 watt option.
Feb 05, 2010 | Marvin 2060 Compact Heater
Need Marvin quartz tubes
Marvin Replacement elements are available from Quartz Infrared Inc for $17.95. You can order them directly here:
http://www.quartzinfrared.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=Marvin
Dec 12, 2009 | Marvin 2060 Compact Heater
I need the replactment elements for a Marvin 2060 heater, where can I find them?"
Marvin replacement elements are available from Quartz Infrared, Inc for $17.95. You can order them directly here:
Nov 16, 2009 | Marvin 2060 Compact Heater
HEATER IS NOT WORKING MARVIN MODEL 3150
One of the techniques I found to "re-energize" an Quatrz elelment is to Remove the cool element (unit unplugged, of course) and try to smooth the ends with sandpaper (220 grit) and then do the smae for the contacts. Replace element and see if it lights up.
Rmember NOT TO TOUCH quartz element with Bare Hands!!
Oil from skin can react with elelment and cause it to explode.
Jan 19, 2009 | Marvin 2060 Compact Heater
Marvin 2060
Try going to www.onestopshopcatalog.com. I believe they actually have some in stock. I order some and we will see if I have any trouble.
Dec 10, 2008 | Marvin 2060 Compact Heater
Heater fan noise
trw www.sears.com the parts dept...have make and model ready!
Need Marvin Heater replacement element (model 2060)
Marvin replacement elements are available from Quartz Infrared for $17.95.
Nov 23, 2008 | Marvin 2060 Compact Heater
Marvin Quartz heater element
Very simple to install the replacement element. Insert one end of the element into the bottom receptacle on either side, press the element down (it's spring-loaded), then slide the top of the element into the center opening of the top receptacle, push to appropriate side (the side of receptacle, same as the bottom), then release. Then do the same with the other element (if both are out).
Mar 03, 2008 | Marvin 2060 Compact Heater
Intermittent heater control Marvin 2060
On Monday, 1/21/08, I returned the Marvin 2060 heater to the store I purchased in 02/07 since the freeze guard stop working. The owner left me a voice message at home and said he after doing some research, he discovered Marvin went out of business in 12/07.
And the heater is no longer covered under the warranty. The owner gave me a telephone number, 800.326.3690 which carry the parts for Marvin Heater. I have not called the number since I am looking for another heater with the freeze guard feature since it something I need quickly.
Jan 18, 2008 | Marvin 2060 Compact Heater
Marvin 2020 Heater
try this place - they have replacement quartz elements maybe you can find one here.
http://www.infraredheaters.com/quartz.htm
Dec 10, 2007 | Marvin 2060 Compact Heater
Marvin 2060 Compact Heater Logo
411 people viewed this question
Top Marvin Heating & Cooling Experts
Oloyede Monsuru
Tom Chichester
Thomas Woodburn
Thomas Woodburn
Are you a Marvin Heating and Cooling Expert? Answer questions, earn points and help others
