Question about HTC PPC-6800 Smartphone
The keys do not light up in the dark on my keyboard in the dark
When I slide out my keyboard in the dark the lights should light up for my keys and they dont , I am left in the dark
I had the same question a month ago (with the Verizon version) and found that the actual problem was that I had the brightness turned all the way down. When I turned the brightness up to the second notch from the left, the keys lit up again. Although, I do not have it set to only turn on the keyboard backlight on in the dark. I have it set to always turn on when I slide out the keyboard. I also noticed that when I had the brightness turned all the way down, the lights on the front (aside from the touchscreen) i.e. the internet explorer button, would not light up either. That helped me a little with troubleshooting. Hope this helps!
Posted on Jan 07, 2009
How do I turn up the keyboard lights in my dell inspiron laptop with windows 7?
What is the model number? Has the laptop got the correct keyboard driver installed? Has it got keyboard lights?
Jan 06, 2015 | Dell Inspiron Computers & Internet
Want to turn on back lights for keyboard to see while typing in dark
I do not believe the Probook 4440s has LED lighting for the keyboard. The key combinations Fn+F2 and Fn+F3 keys at the top of the keyboard control the monitor brightness (backlight). The keyboard is spill-resistant.
You need to attach an external keyboard with backlighting or a USB light to see your keyboard in a dim environment.
I wish that I could be of more help.
Dec 25, 2012 | HP 4440s Probook
Some letters of the keyboard wont function especially the backspace.
Try this.
It stumped myself and some true experts once. We were having problems with the keyboard in a darkened room.
There is a Function ( "F" or "FN") key on the lower left of the keyboard. It's labeling is often blue in color. In low light conditions, you cannot see the blue coloring. It is used to turn a section of the keyboard into a calculator. That section will have dark blue numbers written on the keys that change function. For example the K may have a dark blue number 2 written on it. In other words, When you type the Alphabet you come up with some numbers substituted for letters and not all of the keys may function. Give it try.
Best Regards,
Mark
Dec 26, 2010 | Computers & Internet
MY LCD IS DARK VIEW BUT WHEN I CONNECT THE CHARGER IT BECOME OK. PLZ HELP ME
hi
One of your keyboard keys should show you a picture of what looks like a light one for brighter and one for darker
my laptop is a acer so my keys are on the bottom left of my keyboard if you press the Fn key usually has blue writing on it and the key that looks like the brighter light ( Press them together )
it should brighten up your screen
Hope this helps
Oct 29, 2010 | Computers & Internet
I have a problem with my Nokia 6600 slide. The key pad light does not work. It makes no difference if it is light or dark. How do I turn it on?
open up your phone you'll need phone screw here.than you can check keypad connector,clean up with an pencils eraser(its safety) usually keypad or keypad light problem because off dirty connector.good luck.
May 21, 2010 | Nokia 6600 slide Cellular Phone
I had not used the calculator in a year. I replaced the batteries. The calculator will not turn on.
Here are some quick tests.
  1. Verify batteries are correctly inserted (I have to rule this out) and that the polarity diagrams are respected.
  2. Try to turn the calculator ON with the TI-Nspire keyboard and with the TI84Plus keyboard.
  3. With the TI84Plus keyboard in place, try to adjust the contrast of the screen by
  • pressing the [2nd] key and releasing it.
  • Then press [UpArrow] to darken the screen if it is too light OR the DownArrow if screen is too dark.
If you fail to get any meaningful response from the calculator, put the TI-Nspire keyboard in place/ Make sure you do not press the ON key (put the slide cover to protect screen and keyboard) and press the RESET button on the back of the calculator. For that, use a straightened paper clip.
If all fails, I suggest you reinstall the Operating system. The procedure is detailed in this article.
Feb 09, 2010 | Texas Instruments TI-Nspire Graphic...
Keyboard lights not working
are you referring about the keybaord back lights? please check bios version. turn on computer then keep tapping f2 to enter bios. compare it with from the bios from he support site..if all fails then ask dell support tech to have keyboard replaced.
Oct 03, 2009 | Dell Studio 1737 Laptop
How do I turn on my backlit keyboard on my dell with windows vista?
Sorry for the last answer. The expert probably didn't understand your question.
If you have purchased the optional backlit keyboard, the right-arrow key will have the backlit keyboard icon on it. The backlit keyboard provides visibility in dark environments by illuminating all symbols on the keys. The settings for this keyboard can be personalized by using
Dell QuickSet.
Backlit Keyboard Brightness Settings – Press <Fn> + right-arrow key to toggle between the three lighting states (in the given order).
The three lighting states are:
a. full keyboard/touch pad brightness
b. half keyboard/touch pad brightness
c. no lighting
Hope this helps. If you need the manual for this computer, it is located here:
http://support.dell.com/support/edocs/systems/studio1737/en/SG/F174HA01MR.pdf
Thanks for using FixYa.
Jul 21, 2009 | Dell Studio 1737 Laptop
My palm centro kayboard light wont come on.
Have you tried the option key + menu key? It turns dims the screen and toggles the keyboard backlight on and off.
Dec 04, 2008 | Palm Treo 500 Centro
Itronix ix250 keyboard backlight / possible IrDA question
no once a light burs out in a key board, then you can get a new key board, or ignore it.
yes Irda can be installed on your go book.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/stephen_171aeeebef53a898
Oct 31, 2007 | Itronix GoBook IX250 Notebook
HTC PPC-6800 Smartphone Logo
181 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
