The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
SOURCE: industrial sewing machine top thread breaking
The brother DB 2 series of machines do not use a needle with a flat side. the needle system is DBX1 and are available from size 10 to size 20.
Try using the right needle for the machine and the right size for the thread you are using. this should make it better
SOURCE: needle thread does not pick up bobbin thread it
clean it using a can of air to make sure there is not any fabric or dust caught in the under area. the needle could be bent slighly just replace it.
these are the two things I look for when this happens with my machine. needle is the one most offten causing the problem.
SOURCE: Right needle skipping stitches Janome 4623LE
if you adjust that setting, check that the needle goes into the needle plate the exact same distance front to back on both the right and left side. Also, be careful not to change the height when changing the twist.
SOURCE: Singer Inspiration 4228 Automatic Threading Problems
The small hook that passes through the eye of the needle is bent or broken. If it is only bent it can be straightened with a small screw driver. If it is broken it will need to be replaced. Most dealers can get this part for you for about $5.00
sewman7
SOURCE: my 385.15516000 Kenmore sewing machine is skipping
have you tried a new needle? needle in correctly? threaded correctly?
