FixYa.com
Tags:
Mach Speed Motherboard
Viper MSNV-939 ATX Socket 939
posted by KEONI on Apr 18, 2007
Hey i recently purchased a Viper MSNV-939 ATX Socket 939 mobo and i cannot even load in the BIOS. I dont have a intergrated graphics card so i purchased a brand new X1300 PRO Radeon card. The screen is left black, no beeps from the mobo, but RAM [2gig] is brand new too.... I just need a way to boot up and load in the BIOS.
Comment by KEONI, posted on Apr 25, 2007
thanks Sandrew but even with your checklist, my motherboard still fails to start. One thing left to do that i can think of is swap graphics card.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Apr 18, 2007
Helpful (85)
sandrew
Rank:Wiz Wiz
Rating: 83%, 4622 votes
I assume you have tried with only one stick of ram individually at a time if you are using two to check it's not the ram as one faulty can cause the system to stop.
Also assuming you bought the ram from the same place and is compatible with the board.
Sometimes people also forget that the processor in some cases has to be powered by the 4 pin plug from the PSU and not just from the ZIF socket that older processors use to power up, so double check the manual.
The other main common cause of the this problem is when you are putting together all the hardware onto the board, if you don't protect it underneath it may have overflexed the board and shorted or damaged the circuitry or the bios chip.
That's not to say that the motherboard was'nt faulty in the first place.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jan 14, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Make sure you've connected a power connector to the video card.
Can you Help with these Motherboards problems?
Motherboards
VGA Port not giving output
My Monitor on Desktop is... Answer This...
Motherboards
carte mere adequat ? mon...
j'ai boitier du mdele... Answer This...
Motherboards
My camera is not working,
My LG KU990 camera is not... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
