Question about Dryers
I have a whirlpool 6 cycle infinite temp electric dryer. It is blowing cold air only. Is there a reset button of any type to reset after a power outage
  • 640 Answers
You mostly blow thermal fuse...
Posted on Dec 26, 2008
WHIRLPOOL LE7800XSN1 SUPERCAPACITY IMPERIAL 6 CYCLE INFINITE TEMP ELECTRIC DRYER NOT TUMBLING. HAVE HEAT. BELT ISSUE? BELT PART #? GETTING CONFLICTING ANSWERS FOR PARTS.
Go to www.repairclinic.com and enter LE7800XSN1. With luck, you will be presented with a list of common replacement parts (including the belt) and may be able to get troubleshooting information.
Sep 30, 2017 | Whirlpool Dryers
How do I know when the thermal fuse for my whirlpool deut electric dryer is bad?
Take it out. check it with a multimeter set on ohms. Get a hair dryer turn it on hotest setting. with meter leads on each end of the thermal fuse have someone hold the hair dryer blowing hot air on fuse. It should show continuity through it when cold. After heat is applied it should show 0 or infinity. If its working properly move on to over temp switch.
Sep 02, 2014 | Whirlpool GEW9250 Electric Dryer
Inglis Dryer by Whirlpool blows only cold air
check your thermal fuse and your heating element. You'll have to open the back of the dryer, but it's pretty easy to fix.
Dec 19, 2012 | Inglis 6.5 Cu. Ft. 5-Cycle Electric Dryer...
Kenmore dryer blows cold air. I replaced heat element still no luck? model 96263800
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The heating circuit is not just composed solely by the heating element, it is composed by the thermal cut-off, high-limit thermostat, cycling thermostat, motor centrifugal switch, and the timer. The first thing to look at when an electric dryer stops heating is the thermal cut-off. It cuts power to the heating element when it blows most likely due to the failure of the high-limit thermostat. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Kenmore Dryers
My kenmore dryer is blowing out cold air
Make sure that both poles of your circuit are live - An electric dryer uses 220 volts to the heating element, but taps into only one pole (110 volt) for the motor that spins the drum. Check your circuit breaker to make sure that neither pole has tripped.
Jun 26, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Electric Dryer wont turn on
Try this;
In your browser bar type in youtube.com
In the search box type in repairing whirlpool dryers
Then click on the apprpiate video.
This should help you.
Plz rate my solution.
Thanks.
Dec 30, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer doesn't dry
no but are you sure your replacement parts are correct the cycle stat is usally running about 140 - 160 temps did you switch the high one and the cycling wires or parts?
May 12, 2008 | Dryers
Dryer reset?
NO RESET BUTTON, BUT THERE IS A THERMAL FUSE LOCATED ON THE BACK NEAR THE EXHAUST DUCT. IT IS A SMALL WHITE ITEM WITH TWO WIRES ATTACHED TO IT. CHECK FOR 120 VOLTS AT THE TWO TERMINALS. IF YOU HAVE 120 VOLTS THERE, THE THERMAL FUSE IS BAD. REPLACE FUSE AND CHECK FOR RESTRICTION IN THE AIR FLOW. ALSO, IF YOU HAVE A THERMOMETER THAT CAN MEASURE TEMPS BETWEEN 100 AND 200 DEGREES, CHECK THE TEMP AT THE EXHAUST ONCE THE DRYER IS OPERATING AGAIN. IT SHOULD CYCLE OFF SOMEWHERE AROUND 170 DEGREES. IF IT GOES OVER 200 DEGREES, REPLACE THE CYCLING THERMOSTAT.
Apr 09, 2008 | Whirlpool GGW9200L Gas Dryer
Dryers Logo
119 people viewed this question
Top Dryers Experts
Marvin
Marvin
