Question about Ricoh AC205 All-In-One Laser Printer
Savin AC205 when I try to network scan or just fax a document the LCD displays function impossible scanner locked I have tried to power off/on reload drivers nothing any suggestions
In the print output tray there is a green lever that locks the scan bed in place. Move this lever and the problem should be resolved.
Posted on Mar 28, 2009
Do I need a new scanner bulb?
It sounds very much as if the scanner is faulty/failed. The warming-up phase is to ensure that the scanner lamps output is steady, making for consistent scans. Usually this is just a simple timing circuit.
Having once tried to fix a broken flatbed scanner myself, I found that obtaining the correct replacement lamp for it was impossible - I think inkjet printers and scanners are considered "consumable". You may be better off buying a new printer. Alternatively, if it keeps producing good prints, consider buying a separate scanner. HTH
May 27, 2014 | Canon PIXMA MP780 All-In-One InkJet...
My SAVIN 2820 SCAN FUNCTION does not connect to my home network.
If you have updated your OS to Vista, Win 7 or Win 8, update the firmware
Oct 15, 2012 | Savin Office Equipment & Supplies
I HAVE THE X47850 SCANER HOW DO I SET THE SCANER CODE SO I CAN SCAN?
Hello.
You don't need a scanner code (pin ?) to scan. Here are the steps from Lexmark Support:
Step Action 1 Make sure the printer is configured to scan over a network. 2 Load an original document face down on the scanner glass. 3
From the control panel, press pattlnk_1182007_1150-uparrow.gif or pattlnk_1182007_1146-downarrow.gif repeatedly until Scan is highlighted. 4
Press pattlnk_1182007_1151-selectbutton.gif. 5
Press pattlnk_1182007_1150-uparrow.gif or pattlnk_1182007_1146-downarrow.gif repeatedly until the computer you want to scan to is highlighted. 6
Press pattlnk_1182007_1151-selectbutton.gif. 7
If you set a PIN during network setup and are being prompted for it:
  1. Enter the PIN using pattlnk_1182007_1151-leftarrow.gif and pattlnk_1182007_1152-rightarrow.gif to select a digit location and using pattlnk_1182007_1150-uparrow.gif and pattlnk_1182007_1146-downarrow.gif to select a value for that digit.
  2. Press pattlnk_1182007_1151-selectbutton.gif.
8
Wait until the printer has finished downloading the scan applications list. 9
Make your selections using the control panel buttons. 10
Press the green Start button (pattlnk_1182007_1144-scan%20start%20small.gif).
Hope this helps.
May 27, 2011 | Lexmark X4270 All-In-One InkJet Printer
The scanner keeps jamming. i try to scan form the document feeder &the papers keep getting stuck. It will not complete a scan!what do i do?
In summary: * Very unintuitive, convoluted and unpleasant to use (same on Win2K as XP) - sometimes the SW hangs during scan and needs a reboot - sometimes the SW crashes with a dialogue "try reinstalling HP software", and needs a reboot - sometimes it scans and after conversion to pdf
Advantages: I cannot see any advantages with this product
Disadvantages: Software is convoluted and unreliable, paper jams are difficult to clear
function showHideReviewText( sType ) { if ( sType == 'more' ) { document.getElementById( 'review_text_full' ).style.display = 'block'; document.getElementById( 'review_text_short' ).style.display = 'none'; document.getElementById( 'review_title_link' ).onclick = function() { showHideReviewText('less'); }; } else { document.getElementById( 'review_text_full' ).style.display = 'none'; document.getElementById( 'review_text_short' ).style.display = 'block'; document.getElementById( 'review_title_link' ).onclick = function() { showHideReviewText('more'); }; } } ...with a dialogue "try reinstalling HP software", and needs a reboot
- sometimes it scans and after conversion to pdf every page is blank
- very occasionally it scans a document properly
*If the sheet-feeder jams is says to refer to the documentation to clear it, which doesn't exist. There is no way to clear the jam except to pull hard & hope. No levers to release it like one would expect.
*Frequently has error ...
...cycled to work again.
Everything has to be started by pressing a button on an application called "HP Director". There are 4 apps started from this:
1) Scan Picture
2) Scan Document
3) Make Copies
4) View & Print
also Help
also Settings (which are used in conjunction with settings found in (1) and (2)!)
- Each application has to be exited to return to "HP Director"
its a worst scanner
and prone to jamming problem
Jun 09, 2010 | HP Scanjet 5590 Flatbed Scanner
Scanning the document
I'm confused? The listed product is a Fax/Modem, not an all-in-one. It doesn't have a scan function. To send a document via a fax, you will need to scan it with a scanner (separate hardware) and then fax it. In Windows 7, a program called Windows Fax and Scan is included. If the devices are installed with the correct drivers, you can do the two steps in one program. Open the program, click on New Fax. Select Insert > Pages from Scanner (only available if the scanner was on and connected when Fax and Scan was started). Scan the document; fill in the contact information for the receipient and send. The Contact information may take a few steps since it is a Windows Contact page.
I hope this helps.
Apr 09, 2010 | Hiro V.92 56K PCI DATA FAX VOICE MODEM...
After the scan, the program cannot save the file.
Alright, Open the "paint " program from all program/accessories/paint".
click on the file and click on the option scanner and camera wizard after that you will get a option for "scan" please click on scan to make and change and once when scan get complete. click on file and click on the save as to save the document.
good luck.
Nov 13, 2009 | HP PSC 2355 All-In-One InkJet Printer
Have a savin 8035e need to activate fax and scanning
This is the same as the Ricoh MP3500. You can find all the manuals here..
MP3500 manuals
Sep 10, 2009 | Savin Office Equipment & Supplies
Trying to get my Ricoh Aficio 1035 networkable
This is all you need to upgrade your copier to a network printer/scanner and fax.
Good Luck.
32MB Memory Unit Type B 400516
Postscript 3 kit type 1045 410713
64MB Memory Unit Type B 400517
Fax Function Upgrade Type 185 410284
Print Unit Type 1045 410706
Printer/Scanner Unit Type 1045 410699
Network Interface Board Type 1045 410714
Fax Option Type 1045 410680
Fax Stamp Marker Type 30 334049
Jul 08, 2009 | Ricoh Aficio 1035 Copier
I CAN`T SEND A FAX
Fax machines are sorta like printers, sorta like scanners, and sorta like dial up modems all wrapped into one expensive box.
1. First thing to make sure of is that you are hooked to a phone line. most fax machines have a phone handset that you can make calls from. Call someone and make sure that works. If So, you are able to connect to phone networks, and should have no trouble sending or receiving data. If you have a dead line or no sound, check the line and check the power. (its always the easy stuff that is overlooked, just check it and make sure).
2. If this fax machine has computer interface, (usb port or parallel cable port), see if you can scan with it. Drop a document into the scan area and see if the computer can scan an image from the scanner. If the scanner works, you can scan images into the fax machine to be sent to the fax number. (If your fax machine does not have a scan to computer feature, skip this.)
3. if your fax machine has a print from pc feature, try to print a document to it from your computer. If you can print, then the printer works, and you can receive faxes. (if your fax machine does not have a pc printing feature, skip this)
4. Here is how a typical fax machine works. You place the document or image into the scanner feed area. You press a big button that usually says "fax" and then, a screen pops up saying to dial the number. You dial the number and press SEND. once you press Send, the machine will scan the document, dial the number and sing a little dial up modem song awaiting a response from the receiving machine. the receiving machine acknowledges the fax, and the singing is no longer audible (but it continues because the modem song is actually data transmission/reception). after about 20-60 seconds, the fax completes and the call ends. As for the particular model you have, the functions should be about the same, though the buttons and arrangements may be different. FYI, you can send a fax straight from the PC too, if you have a dial-up fax/modem card.
Jul 03, 2009 | Brother Multi-Function Center MFC-665CW...
Scanner not recognizing software
try opening the scanner from the START-ALL PROGRAMS-HP-ALL IN ONE
Jan 11, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Ricoh AC205 All-In-One Laser Printer Logo
320 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
