Question about Philips SA3125\02 MP3 Player
Can not start mp player error genarate memory is full
Memory is full connect the pc devise manager and repair player such error generate so please give me soluation
  • 8,596 Answers
Your mp3 player is so full that it does not even have enough space to run a Repair. Connect the Philips to the computer, double-click My Computer, right click the Philips icon, and select Format --> Fat32 (or whatever is appropriate for your computer). Normally, I would not reccomend this type of formatting for a Philips, but it is probably our only chance at this point. After conducting the format, try the Repair in Philips Device Manager again.
Warning: All of your songs/files will be erased.
-Tha Mp3 Doctor
Posted on Jan 17, 2009
Hi, I have Moser Baer MP3 player, model number is MP 582-2G. Its not working. Whenever I connect it to computer, I get a error message saying USB Device not recognized/no drivers are installed. Please...
Try this on another PC to confirm if the memory is recognized and detected. If not the player needs to be reset or there are faults within the processor/memory which needs to be estimated with a consensus.
Dec 12, 2011 | Audio Players & Recorders
Hi team,i am facing problem with philips go gear 2GB player, Problem is :when ever i switch it on,"please connect to Pc and use device manager to repair" please help me in this scenario,explain...
I'm not a team member, but
1. Select your GoGear 2GB player from this list:
http://www.search.philips.com/search/search?q=GoGear+2GB&s=all&l=global&h=all&o=
2. When not having the program Philips Device Manager installed on your computer yet: Look under Software and Drivers, select the Device/Firmware Manager for your player.
2.1 Run the execute file Device Manager for installing the Device Manager toolbox.
3. Run Philips Device Manager:
  1. Having launched Philips Device Manager at Start -> Programs -> Philips Digital Audio Player -> SA2XXX -> Philips SA2XXX Device Manager on your PC
  2. Connect your player to the PC
  3. Device Manager should acknowledges your player and automatically goes into recovery mode.
  4. Follow the instruction of the Device Manager.
  5. After the player has been repaired, remove it from your PC and re-start.
If this was helpful I'd appreciate your answer.
When needing more help, just add a comment in this thread.
Feb 21, 2010 | Philips Audio Players & Recorders
How can i get my coby mp-610 stop saying file system error???
View MP-610:
http://www.cobyusa.com/?p=prod&prod_num_id=212&pcat_id=1001
Manual:
http://www.cobyusa.com/files/manuals/MP610_MN.pdf
Quick setup guide:
http://www.cobyusa.com/files/setupguide/MP610_SG.pdf
File system error refers to incomplete startup often due to low battery, faulty firmware or not matching files in the player.
When the startup failed try point 1.Resetting and 2.Charging:
1. Try to reset using the reset button hole on the backside (8).
299c492.jpg 2. Make a connection with the computer and have the device charging for a long period, full load needs 8 hours. Make connection directly to the USB of the computer preferred at the backside of the computer.
When using a laptop see to it that the USB is powered: laptops often switch the USB off going to sleep op hibernate mode.
When this didn't solve the problem, perform a format and reinstall of the firmware, point 4 - 8:
4. Connect the player to the computer and backup your data to the computer using the Windows explorer: copy MUSIC, MOVIE, PHOTO and TEXT directory to a location on the computer.
5. Format the removable disc of the player in Windows explorer.
Check your removable disk having its full memory capacity free after format.
6. Download the firmware for the player: firmware download for MP-610 ( zip file ):
http://www.cobyusa.com/files/software/MP610_Firmware.zip
7. Unzip the file: once unzipped there's a pdf instruction added in the zip file how to perform the firmware update.
8. After the firmware reinstallation the player is ready for transferring
data again. Remember the requirements for the format of files that is put on the player.
Sep 23, 2009 | Coby MP-610 MP3 Player
My player displays a message
Connect player to pc and power, restart player while holding the volume + key, as soon as the player shuts off, press and hold the volume - key, your device manager will pop up and tell you the player needs repair, let it do so.
Jul 18, 2009 | Philips GoGear HDD6330 MP3 Player
I have COBY MP-C7085, Pc picks up mp3 but can't view files
hey, when it comes up in my computer as a media player, just hold down the menu button and it will change to removeable disk in about 2 or 3 seconds, hope that helps
Apr 29, 2009 | Coby MP-C7085 MP3 Player
Mp3 player
please help my player to work again
Jun 05, 2008 | Philips GoGear HDD6330 MP3 Player
Memory full but noting on it
try formatting the internal memory
Feb 27, 2008 | iLO MP3 Player
Go gear not working
Install and run Device Manager from the product CD.
Select the repair option, and follow the on-screen prompts.
NOTE: ALL FILES LOADED ON TO THE PLAYER WILL BE LOST.
If this doesn't work then it may be that the hard disk is faulty. There is an easy way to find out. The following procedure allows the player to connect to the PC as a removable drive. If the Pc reads the drive, then the drive is ok.
Connect the HDD1630 to the mains adaptor and the PC.
Before the computer has a chance to recognise the player, press "Power" and "Vol +" to reset the player.
As soon as the player resets (screen goes blank) press and hold "Vol -" until the PC recognises the player as a removable drive.
Try to access the player through "My Computer" as you would the main hard disk.
Feb 07, 2008 | Philips HDD1630 MP3 Player
MPMan MP-F40 Manager Bug
I'm guessing the full error is "System Error &H8007007E (-214024770). The specified module could not be found." Its missing some file. I suggest you try installing it again http://www.mpmaneurope.com/download.aspx?file_id=192 it wasn't update in a while, but you can try. could be that its not compatible with sp1, or at least part of it. can you live without it? ;]
Jan 04, 2006 | MPMan MP-F40 MP3 Player
Philips SA3125\02 MP3 Player Logo
207 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
