Introduction
AVS Video Converter
helps burning DVD to playback in your home DVD player from all modern
video formats. The integrated DVD burning engine and the widest range
of supported video formats make
AVS Video Converter a perfect tool to create personal DVD videos. Just follow these few steps listed below.
Step 1: Download and install AVS Video Converter
Click here to download it. After the download is finished, run the
AVSVideoConverter.exe file and follow the installation wizard instructions.
Step 2: Run AVS Video Converter and select your input video file
To select a video you would like to convert hit the
Browse... button next to the
Input File Name field. In the opened Windows Explorer window browse for the necessary video file:
Note:
when your input is a DVD disc, you will need to select the path to your
source file: X:\Video_TS\Video_TS.IFO. "X" stands for your DVD-ROM or
the hard disk drive folder where your DVD is stored. Please see the
online help section to find more on burning DVDs to other video formats.
Step 3: Set up the conversion parameters
Click the
To DVD button on the main panel. In the list of video disc types (
Profile) select one of the preset profiles.
You can edit the files for burning dvd. By clicking the
(+/-) buttons you can add or remove files from the list. Using the
Arrows you can change the sequence of files.
Step 4: Set up a proper video output file path
Click the
Output File Name field and select a location on your HDD for the output video file.
Note: when you select a location for your output video file, you should save the file to your personal computer HDD.
Step 5: Create a menu for burning DVD
In
case you convert your files into a DVD format, the program will let you
create a DVD menu so that you could navigate through your disc easily
using it. First of all you need to put the markers indicating the
beginning of the chapters of your DVD menu. To do it switch into the
editing mode using the
Edit button on the
AVS Video Converter main panel. The following window will be opened:
To add markers place the mouse cursor within the
Timeline where a chapter should start and click the
Add button located at the
Markers Panel.
If you want to delete some markers select the necessary one clicking it with the mouse. Then use the
Remove button from the
Markers Panel or right click this marker and select
Remove from the express menu. To delete all markers use the
Clear All button.
After all the markers are added click the
Ok button to save the changes you have made and close the
Edit Input File(s) window. After that you can start editing your DVD Menu.
Click the
Menu button on the
Switch to the main menu or a chapter tab and select one of the style
presets for your menu or assign your own picture by clicking the
Change Background button.
You can move the marker by dragging it along the
Timeline, add a new one or delete them using the appropriate button.
After you add all the chapters and when you are satisfied with the result, close the
Menu Editor window and start converting your video.
Step 6: Convert your DVD files
After you have set up all the conversion parameters, hit the
Convert Now! button to start conversion.
When process is over the following window will appear, where you should click
Burn to Disc...: for burning dvd
Step 7: Burning DVD onto a disc
Insert a blank DVD into your computer optical disc drive. Make sure that the disc is compatible with your drive.
You can select the necessary disc drive if you have several, refresh it and mark the
Verify disc check-box to make sure the disc is recorded correctly.
Now click the
Start burning!
button to begin the recording. Note, that if the disc is not empty you
will be offered to erase it. If you do not want to do that, you can
eject the disc and use another one instead.
After the burning dvd is over the disc will be ejected automatically. Note, if you checked the
Verify disc,
the recording will take a little longer depending on the size of the
output files as the program will need time to verify them.
Now you can watch your recorded home video DVD on your Home DVD Player!
How to create an Audio CD using CD Burner dvd? helps you to creat an Audio CD.
