Question about GPS
Magellan Map 330 Flash memory corrupted - GPS
  • 2 more comments
  • remullen Dec 27, 2008
    Magellan Map 330 flash memory corrupted ****************
    With the Magellan Map 330 connected and power on presssing and holding esc, Go_to, Power buttons simultaneously does not bring up "software upload mode active" -- instead the screen says "Unit currently contains no maps -- initiating map upload" -- when unit is disconnected from computer and esc, Go_to, Power are presssed simultaneously the screen does not change. When power is turned on the same window ("Unit currently contains no maps -- initiating map upload") appears -- this is the only window that the unit -- will show -- To turn the unit off requires removing the batteries
    None of the buttons work -- to turn the GPS off I have to remove the batteries. After replacing the batteries the power button turns it on -- then none of the buttons have any effect. -- So then -- how do I reset the device? Additionally where do I get the lattest software update -- there is nothing on the Magellan website.
    I don't see a reset on the side --
  • remullen Jan 01, 2009
    The problem is solved -- the reset instructions did not work, but taking all the suggestions together and trial and error the upload software window appeared allowing me to upload the program and then upload the maps.
    Thanks
  • 916 Answers
Good to know you got the problem solved. If you need anymore help with the issue please post and we will help you the best we can.
Posted on Jan 01, 2009
  • 679 Answers
If you have accidentlly eraced the eprom from the unit it must go back to the factory to be reprogrammed
Posted on Dec 27, 2008
    Guru:
  • 829 Answers
The M- 330 also has another 8 megabytes of "flash" memory available for uploading detailed street maps, waypoints and routes from Magellan's new MapSend Streets CD-ROM (sold separately). If Your Flash card is corrupted you can either connect to a PC and reformat the Flash CArd , Details given below on how to setup the software after Format.
Instructions for Loading MAP330 Software NOTE: YOU MUST FOLLOW THE INSTRUCTIONS BELOW EXACTLY OTHERWISE YOU MAY CORRUPT YOUR UNIT’S FLASH MEMORY. YOU WILL LOSE ALL WAYPOINTS, ROUTES AND TRACK POINTS AFTER EXECUTING THE INSTRUCTIONS BELOW.
1.) First Locate the latest software for the M330 on the Magellan website. (If you know an update is available, but you do not find it listed, you may want to contact magellan by eMail. Or phone 1-909-394-5000.
2. Connect MAP 330 to the PC using the PC cable.
3. Make sure the unit has good batteries or is connected to external power.
4. On the unit, press and hold ESC, GOTO and Power keys simultaneously until “Software Upload Mode Active” comes up on screen.
5. On the PC, make sure to have unzipped the supplied file and all unzipped files are placed in the same directory. Type at the DOS prompt:
GEN4UPNB /COMy ZORROxxx.SRE
Where y after COM is the COM port number and xxx after ZORRO is the software version number.
6. Press Enter. The PC will show WAITING FOR UNIT RESPONSE for a few seconds and then erase status followed by programming status. Wait until programming status is 100% Complete. The unit will turn off automatically.
7. Press and hold MENU and Power keys simultaneously until the ‘Clear all memory?’ pop-up window appears. Select Yes and press Enter which turns off the unit and clears memory.
    Genius:
  • 1,011 Answers
Sir,
Check this pdf for more information
thanks
good luck
    Genius:
  • 1,239 Answers
Hi Full Reset to original factory status May cure many problems
1- Turn off unit.  2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
  • ABHISHEK.C
    ABHISHEK.C Jan 02, 2009
    see i am saying another time this solution worked for others
    1- Turn off unit.
    2- Press and hold the bottom right corner of the screen.
    3- While still pressing and holding bottom right corner, press and hold power button and
    continue holding both until a white screen appears (may take a couple minutes) with a
    black dot.
    4- Follow the on screen directions (pressing various dots that appear on the screen) and
  • ABHISHEK.C
    if it continues changing firmware is the best solution
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, have you tried a reset with the use of the reset switch on the side?
Good luck and Thank you for using FixYa.
    Sergeant:
    Novelist:
  • 327 Answers
U require the latest sotware update atleast to solve this problem.reset the device ,upload the latest software and it will bw back to work.
  • 13,433 Answers
Instructions for Loading MAP330 SoftwareNOTE:  YOU MUST FOLLOW THE INSTRUCTIONS BELOW EXACTLY OTHERWISE YOU MAY CORRUPT YOUR UNIT’S FLASH MEMORY.   YOU WILL LOSE ALL WAYPOINTS, ROUTES AND TRACK POINTS AFTER EXECUTING THE INSTRUCTIONS BELOW.
Posted on Dec 26, 2008
Hello, I want to download the latest map update for my Magellan Roadmate 3065, but unfortunately it's out of storage. Is there any way i can clear the memory?
Normally, it is done via a computer and loads and unzips it to the computer, then it over-writes the map data already on the device, so it doesn't need additional storage.
Did you load Content Manager and load from there?
http://support.magellangps.com/support/index.php?_m=downloads&_a=viewdownload&downloaditemid=272
RoadMate 3065 - Software Update - Magellan Support - Magellan GPS
support.magellangps.com/support/index.php?_m=downloads&_a...272
Aug 28, 2012 - Description. Magellan® RoadMate® 3065 Software Update - Installation Instructions. To install this software update you will need to install Content Manager. Content Manager is a computer application that syncs with your Magellan GPS navigator to deliver new map updates and product information.
Apr 16, 2018 | Magellan GPS
Maps not found
Reset the set.
And then try it.
Aug 20, 2008 | Magellan GPS
Magellan Exploris 200
you need to request for the maps and updates through mail to the company sir
Jul 31, 2008 | Magellan eXplorist 200 GPS Receiver
Why will my Magellan not go past the opening screen ??
There may be several reasons why the device does not move past the Magellan logo screen. Unfinished map/software update, corrupt file, or an issue with the device flash memory. Magellan supports several models by reloading the device software by sending you a link to wipe the device clean. Please contact them through chat at http://www.magellangps.com/support .
Nov 10, 2014 | Magellan RoadMate GPS
Manuel users map 330
Hi
Click HERE! to download the Magellan Map 330 Gps manual
Jan 21, 2011 | Magellan MAP 330 GPS Receiver
Mi gps ask me to inser sd card, not showing maps!!
On these units maps are definitely on the SD card. I presume you have the card? If so, then the card and map data may be corrupt. If you don't have the card, contact Magellan, and see if you talk them into a replacement for a small fee. Many Manufacturers consider SD Card replacement as a "map upgrade", and will therefore charge more. I hope you get it worked out. Thanks, Bill
Sep 01, 2010 | Magellan Maestro 3140 GPS Devices
Magellan RoadMate
The map software has become corrupted..
Please rate my help++++Thanks for using FIXYA
Oct 09, 2009 | Magellan Roadmate 760 GPS Receiver
Magellan 2000 map stuck on same Wy map, can't get to change.
I had the same problem. Push and hold the on/off button in for about 30 seconds and the gps may reset itself. It worked on my Magellan 2000.
Jul 15, 2009 | Magellan RoadMate 2000 GPS Receiver
Magellan Maestro 4250 2008/2009 Map Update will not update my GPS
I also had problems with a refurbished Magellan 4250. The paperwork inside said to install the 4.85 firmware update which I found would not work with Windows XP Home at least for me. I used my laptop which has Vista Ult 32 bit it updated with no problem that is so far the only solution I used.
Apr 21, 2009 | Magellan Maestro 4250 GPS
Help me please
I had the same problem caused by reformatting the internal memory and this is what I did which worked for me:
Make sure you remove any SD memory cards before trying this fix.
First: find the base maps (NA_BSMAP.mgi and NA_BSMAP.nlt)maps which are located in your computer in the Magellan Roadmate Manager (C:\ProgramFiles\Magellan\Magellan RoadMate Manager NA\Map\Basemaps)
Second: Connect your Roadmate with the USB cable to your computer.
Third: Plug in USB and power up your GPS. Cut and paste the two files mentioned above to your GPS (Devices with Removable Storage (example E:/). They are approximately 25 MB in size and will take a few minutes to copy.
Fourth: Unplug the USB cable and shut power off to the GPS.
Fifth: Power up the GPS and it should find the "base maps".
Good luck!!
Dec 26, 2007 | Magellan RoadMate 300 GPS Receiver
GPS Logo
259 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
