Question about Samsung PCJ522R 52" Rear Projection Television
Blue lens works, but has a weak projection compared to the green and red lens
Hi, My Samsung rear projection television screen has been showing a yellowish hue, and the blues often look green. I tried adjusting the manual convergence. The red works fine, but when I try to adjust the blue, nothing seems to happen. I opened it up and cleaned off the lenses and mirror. I turned the power on, and all three lenses light up, but the blue has a very weak projection in comparison to the other two. Is it possible to fix this repair without buying a replacement part? If not, how much would the replacement part cost? If anyone has any info or advise to fix this problem, I would greatly appreciate it. Thanks, Ryan
    President:
  • 1,284 Answers
The most common problem I have seen with these Samsung projo units is the blue CRT (picture tube) failing. They usually form algae on the face of the CRT which means replacement of the CRT or rebuilding it by a CRT rebuilding company. I wouldn't suggest the novice to pull the CRT out because if the wrong mouting screws are pulled you will spill out the cooling fluid within the face of the CRT and that will cause more problems.
Posted on Apr 18, 2007
What is the perfect amount of red,blue,and yellow hue for the screen
that's got t o do with personnel preference and room lighting , but as a general rule adjust color hue's till the edges of a white color object on screen has just lost its primary color edge
the older projection TV's actually have voltage numbers for the service tech to adjust them too , but im not remembering seeing any in the LCD manuals
Mar 29, 2016 | Element Electronics FLX3210 32 in. LCD TV
What causes the yellowish hue in the centre of the screen
There are several different types of projection sets: some use 3 picture tubes, red,green,blue--if this kind of set is what you have the coolant used in the blue tube is bad-----this type of problem leaves red and green which = yellow.
Most common in Samsung, Philips, Magnavox type sets.
If it is a newer set without picture tubes (a dlp style set) yellow in the middle of the screen would denote a damaged optical light engine.
Let me know brand, model number, date made----all are on back of set.
SD TECH
Feb 25, 2011 | Televison & Video
My screen has little dots appearing sometimes red sometimes blues behind the picture i just replaced the lamp bulb as i thought it would cure the problem
the projection tube needs to be adjust for color alignment, each tube (red, green, blue) must be aligned so you there would be no color smear appear on screen. if it is aligned try to set up the color balance, hue etc.
Feb 06, 2011 | Samsung Televison & Video
I have this blob discoloration that is in the center of my screen. what could this be its a yellowish green color
Yellowish green colour is usually caused by a burnt blue LCD Panel or the light engine requires servicing.
Jan 15, 2011 | Zenith E44W46LCD 44" Rear Projection...
The screen has a yellowish color tinting the entire surface. No blurring, just poor color. I'm thinking the 3 tubes(red, green, blue) may be toast?
Hi,thats could from your convergence color ic call stk
;you may need to replaced before looking for the tube thats may just an ajustement on tube screen control beware for high voltage
that is depend how old is the tv and the number of hour it play a day....
hope that will help
May 04, 2010 | Samsung HCL4715W 47" Rear Projection...
Picture is yellowish and dim hard to see during daylight
you will have to change the coolant under the blue and maybe the red crt lens
Apr 18, 2010 | Samsung PCL545R 54" Rear Projection...
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
Toshiba 65H80 has yellow hue.
Check you HD inputs or source. Sounds like the red stream is missing; maybe a loose cable.
Nov 17, 2008 | Toshiba 65H80 65" Rear Projection...
RCA 52" big screen tv
sounds like one of your tubes got weak, im thinking the red tube, needs to be adjusted manually
Dec 26, 2007 | RCA P52937 52" Rear Projection Television
Samsung PCJ522R 52" Rear Projection Television Logo
178 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
