Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer freeze up
Where is defrost timer locate .Need replace model number is tfx20jrbk www. I want to no if it has a defrost timer and if it does were is it located the fridge is a ge
  • lpalmentera Jan 11, 2009
    I have replaced the heater 2x now and the element keeps frying like a burned out light bulb. I've been told that touching the glass on the heater may cause this problem but I'd like another opinion.
  • 1,543 Answers
Your model TFX20JRBKWWW uses a defrost timer part number WR9X489 located behind the light shield in the fresh foods compartment. (top back area). Just in case you need to know, the defrost heater is a part number WR51X10101 located behind the back wall of the freezer.
Posted on Dec 26, 2008
  • windowman71 May 11, 2011
    great info fixed mine myself today. part was 40.00 thanks that beats the 150 someone wanted 150.00 to come out.
  • windowman71 May 15, 2011
    still working like a champ! thanks again
AMANA G37025 need to defrost the frig evry three days
Replace the defrost heater,defrost thermostat and defrost timer.
Jul 17, 2011 | Refrigerators
GE Frig model TFX20JRBK ww with icing on freezer
I would suggest fixing it . You only have 2 parts in the defrost system . A timer , and the defrost heater which comes with the bimetal , pt . # WR51X10031 .Most probable , is the defrost heater . You will need to remove the rear inside freezer panel , and defrost the coils with a hair dryer . After defrosting , 2 screws hold each ( 2 ) heater on , ant the defrost thermostat , just clips onto the top of the coils .
Nov 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is not freezing
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Sep 21, 2009 | Refrigerators
Freezer doesnt freeze and red light at top came on
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
thumbs up
Aug 17, 2009 | Freezers
Freezer freezes, freg doent get cold
Aug 17, 2009 | Refrigerators
Freezer cold but not freezing
I you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Kenmore won't cool down.
Aug 15, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Refrigerator and freezer not working
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 15, 2009 | Whirlpool ED5FHEXMQ Side by Side...
The freezer is freezing to the extreme fridge not cooling at all
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model also check the termination switch inline with the elements
Aug 09, 2009 | Refrigerators
My refrigerator is not getting cold. The freezer freezes good and water is dripping from the inside of the refrigerator onto the shelves what is causing that?
That is condensate,. We need to see if your refrigerator is defrosting normally. Want you to find the defrost timer in photo below is a description and location. The #4 in photo is the defrost timer providing the model number above your post is correct. There should be a small round hole through the control panel to turn the defrost timer slowly clockwise until the compressor stop. When stopped this should put your refrigerator in defrost mode. Defrost should take about 25 minutes or little longer. If refrigerator does not restart turn the timer slowly again until the compressor restarts. If you need to restart this way the timer will need replaced. During defrost the freezer area will produce sounds of crackling and sizziling of water dripping down onto the defrost heater. If no sounds let me know the results and I will instruct you on what to do next. Sea breeze
Jun 24, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
419 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
