Question about Philips Magnavox 51MP392H Rear Projection Television
Tv has a the blue tint that won't line up.
Well the top right and bottom left of the tv the blue I guess tint will not line up. I tried to fix it with the remote but does not want to line back up. What can be the problem and is it expensive to fix?
Thanks
  • sly05ster Jan 29, 2009
    I have an older Phillips 42" Flat Panel TV and the original remote. My problem is I just moved the TV and now every thing that should have the color blue is green! On the remote it will not let me access the tint, I can change contrast, sharpness but nothing to do with the color??? Any ideas?? It has had great color in the past and it is set for HD TV!!! It is drving me crazy!
  • Philips Master
  • 3,459 Answers
You may have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Posted on Jan 30, 2009
  • 185 Answers
The problem is with the convergence, 1 or more chips could be faulty. replacement is the oly option if faulty stk-xxx-xxx
Posted on Dec 26, 2008
I can't seem to correct a tint problem. The tv turns on and the tint doesn't change. A friend says it could be a vidoe card?
Go to menue on controller, then Picture, then adjust Color and Tint to you taste. The color ajusts Blue and Green move left more blue move the slider right more green. The Tint controlls red. More red move right less left. Also chech Color temp setting.
Nov 08, 2009 | Akai PDP4225M 42 in. Plasma Television
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Mar 30, 2009 | Televison & Video
Blue "shadows" on my picture?
if you take the front bottom panel off, you will see 6 little nobs, look like this ::: the midle 2 should be blue, middle top is the focus, middle botton is intencity, turn the middle bottom nob down about a quarter to half turn, should solve prob
Jan 08, 2009 | Samsung HCM4215W 42" Rear Projection...
Red is out of alignment
when i go to convergence and align the white cross with the blue its ok ,but when i try the red it doesnt line up and if l get it close enough it get misaligned only with the red ,green and blue fine
Nov 15, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Top left and bottom right images/letters distorted.
I can fix it for $325? 213 880 1795
It was a convergence problem, both chips goes bad bad also look for bad resistors around the circuit? This is not an easy repair for non skilled person? You need to realign it after replacing the chips? Don't be cheap pay someone to do it right?
Oct 02, 2008 | Sony KP-53XBR45 53" Rear Projection...
Corner tints and white lines
it can be a picture tube problem. moreover, check if your tv is dusty inside it . clear it with blower and try again.
regards,
Jul 31, 2008 | JVC AV-32120 32" TV
Blue vertical line running down my 42" Plasma TV (42PF9631D/37)
I was not sure if the line was going from top to bottom or left to right. the X driver board is for left to right and the Y board is for top to bottom . The Y driver board is a common issue with these sets there is a Y main board and a upper and lower buffer board for the Y axis
Jun 12, 2008 | Philips 42PF9630A 42 in. Plasma Television
Got a blue vertical line on me plasma
I had the same problem, a vertical blue line from top to bottom on my samsung TV.
Try this download this http://www.jscreenfix.com/video.php i burned it to a dvd and it fixed it within a minute.
Nov 07, 2007 | Samsung HPN5039 50 in. Plasma HDTV
Picture then fades to blue.
Please post me on this as well. My Sony just turned 4 yrs this Jan and just last week it started having the same problem. -Thanks!
Mar 02, 2007 | Sony KP-65WS500 65" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
103 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
