Question about Dell Inspiron 2200 Notebook
My speakers do not work anymore in my inspiron 2200
I have performed after going through all the diagnostic tests in my computer I found that I might need new hardware as the analog sound playback test FAILED and the record/ playback test failed too. Can I solve this problem by purchasing an external sound card or do I have to replace the motherboard?
    Master:
  • 461 Answers
If you press Fn while powering the system on it should enter diagnostic mode. It will perform some memory tests and then present a video test screen at which point it plays sound through the speakers. If you here this sound, then your hardware is functioning and it is a software problem. There are USB sound cards available - note: you would need external speakers as well.
Posted on Jan 04, 2009
I got a laptop Dell Inspiron 2200...I turn the power on and all the four (4) green lights goes on then flashes a bit a wont turn on... ANY CAN HELP ME.... Thanks
If the the four lights on the computer come and then go off. Then these are the diagnostics lights telling that the motherboard has gone bad and needs a replacement
If they flash in some sequence . The the problem could be with one of the internal components.
For more information on the same you can visit www.support.dell.com
Thanks for using fixya
proton
Jul 28, 2010 | Dell Inspiron 2200 Notebook
Dell Inspiron 2200; Win XP pro; detect router but no connect
Have you change settings on your router? if not try to disconnect and reconnect your dell computer. if still not working. turn off both laptop, turn off the router and modem. wait for 10-20 seconds then turn on the modem first, and if the modem is stable, turn on the router, and if it is stable, turn on the dell computer and try to connect. If still fails, try to delete wireless profile adn recreate it. If still fails, check device manger if there is a problem in your wireless driver. If still cannot connect, perform system restore.
Apr 04, 2010 | Dell Inspiron 2200 Notebook
I have no sound on my dell xps m140 laptop
Check if the computer is on mute.
Then try to plug in a headphone check if it will
make any sound then if not update the audio driver.
If that's not working try to check if the right device is selected under the sound properties in control panel.
If that is still not working run the diagnostics in the computer, you can access that by f12 you will run into a first part of the test which may take aroun 10 mins then it will ask you to continue the remaining test press no then after that it will ask you to press any to boot to the partition then hit enter after that it
will ask you on what kind of diagnostics you want to run, select on custom test,. under custom test you will see all the items you have in your computer, select speakers or audio then it will perform a test
in your speakers if it make a sound then there is something wrong with your windows you might wanna back up your file, if it still does not make any sound you'll need to replace the speakers.
Hope this helps!
Feb 10, 2010 | Dell Inspiron XPS M140 Notebook
Dell Inspiron E1505 absolutely no sound anymore
1. remove all external peripherals.
2. use the internal speakers
3. uninstall / reinstall the audio drivers
4. reboot system
5. if still hearing the crackling sound check if cracking sound can be heard only inside windows of even in the bios.
6. check bios hdd if in acoustic mode performance if yes then set it to normal.
Oct 08, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron 2200 cant connect to internet
go to support.dell.com and download the modem driver to an external media (cd, thumb drive, etc.).
then right click 'my computer' and go to properties then device manager. you should be able to go to the modem and update the driver from a specific location and then point it to the external media you have downloaded the driver to.
Jul 11, 2009 | Dell Inspiron 2200 Notebook
Error code 1046: new hard drive, still problems
since the keyboard and dvd are on different controllers it may be the motherboard but then I have seen weird things when memory goes bad. I would download memtest on another computer and burn it to cd and run it from bootup and test the memory first. If not the memory then motherboard is a likely answer
Jun 29, 2009 | Dell Inspiron 2200 Notebook
Unable to reinstall xp on my inspiron 2200 laptop, cd drive hangs
it sounds as though you may have a bad sectors or clusters on the HDD the best solution is going to be to replace HDD
sorry i couldn't be of more assistance
May 05, 2009 | Dell Inspiron 2200 Notebook
No sound
Had this problem awhile back. I just had to re install the software program for my sound card. Then I had to turn on my speakers using my sound control pannel. Found out that my sound had been disconnected that way.
Mar 26, 2009 | Dell Inspiron 2200 Notebook
Z-2200, Left Channel Stopped Working
The exact same thing has happened to me,, the left channel just stopped working. I am in process of changing the audio amplifier chip for the left channel a TDA 7296. Its a fairly inexpensive gamble at less then 5 bucks for the chip. It is fairly complicated amplifier chip with a built in mute, standby and thermal shutdown protection features in the chip so it is possible any of that has gone haywire the chip would not output properly if so. Also found on the same channel a small choke a three turn coil that was dislodged when they added silicon to the board and it pulled the choke lead right off the board. I would presume this alone would not be the problem but could have lead to the amplifier going bad if it truly is.
Evertyhing else on the main board seems to test well and nothing is standing out as a problem. Rollin the dice. Waiting for a chip in the mail,,, time will tell.
Jan 20, 2009 | Logitech Z-2200 Computer Speakers
Dell Inspiron 2200 Notebook Logo
Alun Cox
