Televison & Video Logo
Posted on Dec 26, 2008
No picture on the screen , but sound is good and I can not see the functions on the screen
We can see anything the screen is black is like the tv is off, but sound is good and I can not see the functions on the screen, but I can change the chanels, I can tell because the sound work good, the picture went off after we here a little explotion.?we can see anything the screen is black is like the tv is off, but sound is good and I can not see the functions on the screen, but I can change the chanels, I can tell because the sound work good, the picture went off after we here a little explotion.? tv plasma zenith z50xp2d
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 1 Answer
  • Posted on Jan 11, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
1808
Points
42"plasma tv sound no picture
  • peter goodchild Sep 15, 2013
    i dont see a solution just an ad from google?
I have a Toshiba 50L2300U TV which has sound, but the screen is black. I believe it's because the backlight inverter is not functioning. What part needs to be replaced?
Hi Anonymous, The link below is a YouTube video showing how to fix a Toshiba television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
https://www.youtube.com/watch?v=WtRuUBS9doE
Toshiba 55HT1U repair No Picture
Television stuck on black philips screen will not do anything except flash off and back on to same black philips screen.
Sounds like the media/main board is going out. You can change those out really easy with just a screw driver.
Check ebay with your part number off the board. Start with you tv model number and the the BOARD part number. Alot of board look alike but there aren't.
Also..
shopjimmy.com is a good place.
Good Luck.
My tv powers on good, but has no picture
I need some help, no picture, no sound either or what? Also was set doing anything unusual before it failed?
2answers
Sony KV34HS420
It sounds like you have tried changing imputs " usually the issue". The next step is to see if it is still under warranty and get an estimate of how much it will cost to fix. Invest in a good surge protector.
HCM4215W 42 in. Rear Projection Television
When the screen goes blank, hit any remote function that will show up on the screen-like volume bar. If the display is missing as well, then you have a tv problem. If the volume display is there when the tv picture is not, you may require a software upgrade.
Key on tv can't view anything only sound
Someone has locked out access to functions. Possible "parental key". Check menu settings for this. If user used a password, you will need it
13helpful
2answers
Black box on screen
CTPATS-THATBOX IS MOST LIKELY DUE TO THE TV HAVING THE CLOSED CAPTION TEXT FUNCTION ON,SIMPLY GO INTO YOUR MENU AND TURN THE CLOSED CAPTIONS OFF. JOE TV
Sanyo DS24425 24" TV has great sound and no picture(black screen)
if TV have black screen,increase screen control to see vert amp IC is defective if you see one horizontal line in picture tube screen,and if screen is white with lots of line acrose ,you can find open resister,on picture tube board,or in main board near HV transformer.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
