Question about HP Officejet 4315v All-In-One InkJet Printer
Trying to install get part way then says detected problem i had new hadr drived installed
  • 300 Answers
I would suggest removing all the software that came with the printer through Add/Remove programs in the Control Panel. After that is finished make sure that you disconnect the usb cable from the printer. Then, using the directions below you can download the latest drivers.
To download the drivers you can go here. When the page opens you will need to choose your operating system. Then, from the Drivers section I would choose the full feature driver.
Once you click that, you will see a Install Now button that will allow you to immediately install the software and/or a Download Only button that will allow you to download the file for later installation. Either option will have a link below them that says View Directions which can be used to get step by step instructions for installation of the drivers.
Hope this helps. Please remember to rate this information.
Thanks
Posted on Jan 04, 2009
My MX6214 Laptop will not start windows XP, a series of white vertical lines comes on in the bottom of the screen and after they all turn solid windows screen comes on but never starts, I tried a new hadr...
THERE SHOULD BE PROBLEM WITH THE RAM. PLS CHANGE THE RAM AND TRY. OR IF YOU HAVE 2 RAMS INSTALLED TRY REMOVING 1 AND TRY. THE RAMS ARE GENERALLY PRESENT IN THE CENTRE IN THE BOTTOM SIDE OF THE LAPTOP. PLS REPLY OR COMMENT. THANKS
May 15, 2011 | Gateway MX6214 Notebook
I have a Toshiaba laptop which had a hard drive failure , so I installed a new Western Digital Scorpio WD1600BEVS 160 GB hard-drive. When I tried to install Windows OS, the installation failed to detect...
You can install the windows to follow this step.
Make sure that the CD drive is on first boot. When you turn on your laptop you need to press the delete key fast, to access the BIOS. Once you have change the BIOS settings you need to save it. After you save once the laptop detecting the windows CD press the enter key fast also to boot from CD.
Jul 27, 2010 | Western Digital Scorpio WD1600BEVS 160 GB...
Sir i am xp install but blue screen show to my
it`s possible that your hadr drive to be a serial ata( SATA) drive and *********** board does not support try to moddify your bootable cd with winxpiso builder and include your hdd drivers in to it if you need more help please contact me
Mar 15, 2010 | Computers & Internet
I am not able to instal OS in my home PC. Asking me to install scsi drive. my hard disk seagate. where download this flopply disk bios drive software
hi
Checked the Bios Setting and check whether the Hard drive is recognizing or not -
Check the Boot sequence
Check Boot from the CD Drive
Format the Hard drive
it will work
Feb 23, 2010 | Seagate 500GB Maxtor Diamondmax21 SATA2...
I do not see sp3 read hadr drive
Try to take out the HDD and reconnect it. If that doesn't work, try to get yourself another HDD (borrow from a friend or something) and test if your PS3 will detect that HDD. If its doesn't detect the HDD then your PS3 has a problem. Call Sony and have them fix it.
- HotRatchet
Jan 24, 2010 | Sony Playstation 3 (PS3) Console
Dear sir compacq presario v3700 xp not installed why hdd not dit
if u have 4gb ram u culd not load xp. so install sp-3. i think when u start to down loadxp u should get blue screen and hdd and ram error. first take out hadr drive and format it another computer then u can get install xp.(nepal)
Jan 27, 2009 | Compaq Presario C700T Notebook
I just replaced my hard drive and everytime i boot up it says found no operating system but when i try to install the operating system it wont let me
New hard drives don't have an O/S installed, so they just be prepped and the O/S reinstalled, along with your applications.
Does your computer "see" the new drive? If the drive was properly connected, a modern computer will automatically detect it, and you shouldn't need to do much if anything in BIOS.
There is a key sequence to get into the BIOS setup, differs from computer to computer.
Assuming the computer detects the drive, the O/S install should partition, format, and install. Some SATA machines may not install Win XP without some additional work. Do you have the CD(s)/DVD(s) that came with your computer? If so, they should have all the proper drivers (including for SATA interfaced drives).
Hopefully this will help.
Dec 23, 2008 | Gateway (M520HD80G) Hard Drive
My sata hard hard drive is not detected in linux
Check in your BIOS settings that SATA drives can be seen as "ATA"
Install Linux, and then , after everithing went OK, change BIOS to SATA again.
Aug 04, 2008 | Computers & Internet
I put a new samsung hard drive in my laptop but it won't detect the new drive I dont have the software that came with laptop I was told to install the drive control first but how do I INSTALL it when...
it properly have something to do with the bios.
try to check if the bios detects the harddrive.
if not reset the bios.
hope that if can help you further.
CS
May 16, 2008 | Computers & Internet
New hard drive 160 GB ATA can't be partitioned
why dont you try 40000 in the first partitioned..if doesn't work.. try fix your hard drive using a seatools, a bootable disk, that can detect and repair a bad sector for a hard drive..
Feb 26, 2008 | Computers & Internet
HP Officejet 4315v All-In-One InkJet Printer Logo
19 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
