Question about ASUS P5QL-E Motherboard, LGA775, Intel P43 + ICH10R, Dual DDR2, PCIe x16, SATAII, RAID, eSATA, Gigab
Bios changes good day i just bought this motherboard + intel E8400 ,4gb kingston DDR2, saphire radeon HD4830 and when i want to change bios PC do restart and dont come up again only after bios reset dont u know any solution pls? without changing i have already instaled XP sp3 and all tests are ok thx for help
  • 5 more comments
  • michalm15 Dec 27, 2008
    i have intel p5ql pro bios 1,1,0 but every time i want to change anything in bios even boot device computer restarts and dont come up again ,procesor intel E8400,Saphire radeon HD4830,4gb compatible kingston dd2 800mhz ram. OS is working normaly all tests are fine but i just cant chane bios o 1 more thing i have old power source 300W and it have 4 pins on biger conector mising but friend told me its just for some kind of beter power sources and it doesnt mater .
    *4 pins are missing
  • michalm15 Dec 28, 2008
    never mind what i changing it do if i change every thing in bios even boot device or disable flopy or every thing else i just cant save changed bios it look like damaged bios memory
    im using 32 bit XP sp3. OS it works propertly even 3d mark was ok and that bios problem was before OS was instaled (hardisk was clean no boot dvd present) its not OS problem something bat with bios maybe motherbord and i afraid to changing bios becouse it look like bios writing memory is bad so i dont want to destroy it
    i already checked CLRTC jumper its on good position i will try to change batery thx for advice.
  • MW1961 May 11, 2010
    Also, what motherboard do you have?
    Please give additional information regarding what settings you are attempting to change and to what values. Based on what your changing and how high the values are could be causing your BIOS to reset.
    Problem Solver:
  • 9 Answers
Does the computer fail to boot with default BIOS settings? or only when you modify something? If it fails to boot at default settings:
What OS are you running? and is it 32 or 64.
32 bit OS will not run 4Gig of RAM. 3 is max! so try removing 1 or 2 of the RAM sticks, set BIOS to default values and try again.
If your computer still wont POST then I'd consider RMA the motherboard.
Posted on Dec 28, 2008
  • MW1961 Dec 28, 2008
    Ok, now I think I understand what your saying. Everything works properly, but you cant save any changes to the BIOS..and thats it?
    One other thing you might check is the CLRTC jumper. I think yours should be on #2 & 3. Check your manual for proper CLRTC jumper placement, and if all else fails contact ASUS support.
    make sure your saving the changes to the BIOS (F10) and try replacing the CMOS battery. Often, new boards arrive with weak or dead batteries. One of mine did.
  • 146 Answers
What are you changing? The motherboard or one of the peripherals such as memory or video card or drive controller may not like the setting or may be incompatible with certain options causing the problem. You may also want to see if there is a bios update to address the issue.
Good luck.
Posted on Dec 27, 2008
2 GB DDR2 Kingston 533 mhz
no need to update.. check the bus speed should be the same..
Sep 14, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
1GB seen as 512Mb
I think you are right, you have to update your BIOS, or try to change your Kingston to Super Talent or other compatible with your motherboard ram. Good luck!
Sep 12, 2009 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
ASUS P5VD2-MX SE recognizes only up to 2500MB RAM
Actually you are doing better than you think, According to your MB specs it is only supposed to hold a max of 2GB (1GB per slot). The updated BIOS may be allowing for the additional 500MB.
If you would like to verify, here is a link to the manual for your MB:
P5VD2-MX SE Manual
See page viii.
Thanks for using Fixya.
Sep 09, 2009 | ASUS P5VD2-MX SE Motherboard
Sony Driver
Without the model number the above is meaningless.
Jul 30, 2009 | Sony Computers & Internet
You dont need any driver since your PC is configured as x64 bit processor so all you got to do is get hold of the XP OS which is meant for x64 compatible PC's. The one normally used is 32 bit named as x86. I hope u wont face any difficulty in getting hold of x64 based OS(XP)......sodeep
Jul 30, 2009 | Computers & Internet
MSI P6N V2 motherboard doesnt work with Core2Duo E8400
ur motherboard goes dead now only one solution have that u must change ur board . coz by overclocking ur motherboard vg chip gone burn and no one can change that chip .thanx enjoy good luck plz vote for my comments
Apr 20, 2009 | Computers & Internet
M2A-VM random reboot
there is no windows xp sp3.all sp3 are made by hackers which used to hack the systems please change ur operating system and also uncheck the My computer(right click)->properties->advanced->startup and recovery,uncheck the automatically restary.
ur problem may be solved.
Jan 10, 2009 | ASUS M2A-VM (0610839149438) Motherboard
Well I'm one of you guys so you can bet I was confused, this is a computer problem installing XP SP3 on my PC.
clean install ............. floppy... fdisk deleting all partitions first.... and then making a partition of the whole disk.. then formatting.... then do the install and of course ntfs.... and see how that goes
Sep 01, 2008 | Intel Motherboard
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Jun 25, 2008 | Intel D102GGC2 Motherboard
ASUS P5QL-E Motherboard, LGA775, Intel P43 + ICH10R, Dual DDR2, PCIe x16, SATAII, RAID, eSATA, Gigab Logo
192 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
