Question about Sun X6168A Internal DVD Drive
DVD Drive won't stay closed
I have to use a pin to open the CD/DVD drive on my machine, and when I insert a CD the drive closes then comes right back open again. Just started doing this.
    Novelist:
    Scholar:
  • 158 Answers
I would sugest getting it repaired if it's in warrenty if not then get a new one the prices are low enough for replacement drive. good luck on this one
Posted on Aug 15, 2007
Dvd drive always says
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jul 22, 2012 | Computers & Internet
My compaq presario cq40 again n again tell(there is no disk in the drive. please insert a disk in to drive) n i not have a cd rom driver plz tell me how is soul
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Aug 15, 2011 | Compaq (120192-B21) CD-ROM Drive
I have a lg gh22ns50 internal drive.when i insert a cd it works perfectly but when i insert a dvd my dvd-ram drive turns into cd drive.opening it it says insert the disc.pls help
that seems odd if it reads cd's it should read dvd's
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try:
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps:
Jul 11, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
When i insert any DVd my acer aspire 4710 laptop showing there is no Cd in the drive and the Cd automatically comes out of the drive
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jun 16, 2011 | Acer (KV.16X04.007) DVD Drive
Cd drive will not open
if the drive is just stuck then
Look at the front of your CD drive you should see a small hole like this:
straighten a paperclip and insert the end in to the hole it will open the cd drive up
If this is a reoccurring problem the drive motor might be going bad or it is sticks frequently then there is somthing protruding or something knocking the cd out of alignment and jamming the drive closed.
Apr 18, 2011 | E-Machines emachines (emachinees) CD-ROM...
Dvd won't eject. It lights up flashing like wants to open. I tried to eject dvd every way possible ie., computer link, etc
All CD / DVD drives have a Eject Pin Hole. The only thing we need is a paper clip to use it
All we have to do is bend it at the first curve 180 degrees (straitening it out). Then take the second curve and bend it 90 degrees. Now we need to locate the Eject Pin Hole.
Laptop - Notebook CD / DVD drives:
The trays on laptops/notebooks are spring loaded, so all that is needed is to release the locking mechanism. You do not have to insert the paper clip as far as with a desktop CD / DVD drive, as you are not connecting to the gearing under the tray. Gently insert the paper clip into the Eject Pin Hole. Once you feel it make contact, gently push in and the tray will eject immediately. Once done, gently push the tray back inward until it locks back into place.
Desktop CD / DVD drives:
Gently insert the modified paper clip into the Eject Pin Hole until you feel it make contact with the gear underneath the tray. Firmly pressing inward, you will notice the tray to start to move out. Press inward until you have enough room to get your finger under the tray and then pull it out the rest of the way. If you can only get a small portion of the tray out, you can use the other end of the paper clip to gently pry open the tray enough to get your finger under it. Once done, gently push back the tray to the closed position. It will close firmly when the system is powered up.
Mar 14, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
Cd dvd door wont open.i push the button to put in cd and nothing happens.i do see a little cd on screen ,then it goes away.
On the front of most CD or DVD drives there is a small pin hole that you can use to open the drive if it gets stuck. Grab yourself a strong paper clip, straighten one end, insert the straight bit into the hole and push firmly once you feel some resistance.
This will partly open the drive tray to either allow you to remove a cd or insert a new cd or dvd.
Question, Is there a light lit on the front of the drive when you are:
a. trying to eject (instead of using the front button on the drive try using the "Right Click and then Eject" option when selecting the dvd drive in My Computer), If not the drive may be stuffed (broken) or perhaps the 4 pin power connection lead at the rear of the dvd drive has fallen out.
b. is the drive tray sticky when opening or closing? (get a new drive...very easy and very cheap to buy and replace)
Good luck,
Steve (Melbourne,Australia)
May 14, 2010 | E-Machines eMachines Desktop PC
DVD drive doesn't open. DVD is inside.
Switch off the pc. Look closely on the CD tray face plate. You will see a small pin hole. Insert a needle or pin through it and press. The tray will open.
Feb 08, 2010 | LG (GDR8163BB) (gdr8163bb 10pk) Internal...
Cd/dvd drive doesn't work. Won't open with eject button, How can I determine if it is a driver or hardware problem?
Look at the drive there should be a tiny pin hole near the eject button, insert a needle (safety pin, sewing, etc.) into the pin hole and push this opens the drive.
You can also try opening my computer and right clicking the DVD drive and select eject. After you do this close the drive and try the button again it may just be stuck if it still won't eject you can try and pop off the front of the drive (very simple it locks back on easily) and find the place where the button connects to the drive to eject and push it, If it still won't open it is your hardware.
Jan 18, 2010 | Dell (3410160) Plug-In Module DVD Drive
CD/DVD drive stuck CLOSED and NO pin hole
Use my computer and select the drive (eg drive E:). From pull down menu "File" select "eject". While the disk door attempts to open (hear slight movement of tray) massage the door with your fingers. This is done by smoothing out the across front door panel with your finger tips and pushing in and releasing pressure from door. Door should slide open partially and close again. Repeat. The eject button nearside the disc tray doesn't seem to work as well as selecting "File" and "Eject" from the menu. Something to do with the door cycle is less with the direct eject button.
Jan 28, 2009 | Zenith Data Systems Zenith (OP-260-74501)...
Sun X6168A Internal DVD Drive Logo
88 people viewed this question
Top Sun Computers & Internet Experts
Rob Hill
Rob Hill
k24674
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
