Question about Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Other way to sync the yp-z5 withought windows media player
I was wondering if you coud sync the yp-z5 with another program or it has to be windows media player. if you know any other way to sync the yp-z5 please answer?
You can go to start, my computer, and click on your device then you can drag your songs onto their and it will download it to your mp3. Hope this helps!!
Posted on Jan 25, 2009
Hi, I recently spoke to the tchnicians from Samsung who put me onto the Samsung website where you can download the Samsung media Player. That also allows you to sync the unit. Thanks
Posted on Apr 25, 2007
  • 944 Answers
Here is the user manual for your player if you need it; http://downloadcenter.samsung.com/content/UM/200601/20060124115711375_YPZ5-USA-ENGLISH-0.0.pdf Page 18 states that you can only sync with wmp 10, there is no alternative software that will do the job. Hope this helps :)
Posted on Apr 18, 2007
SOURCE:
I need a replacement usb cable to connect my samsung YP-Z5 MP3 player to my computer
You can purchase a replacement USB cable for Samsung YP-Z5 MP3 Player from amazon >>LINK
Oct 23, 2011 | Samsung YP-Z5 MP3 Player
My Samsung YP-Z5 player wont respond to charging. Tried plugging into several USB ports on different computers but wont charge. Its constantly displaying .... Low Battery & USB Disabled. I was...
Yes, they only last two to three years.
A search of eBay, a place i look to check availability gives a number available.
Search "Samsung YP-Z5 battery"
If you are able to open up the case You could cut off the existing battery leads close to the battery and join the two wires. Soldering is preferred if you have an insulated tip soldering iron.
Otherwise twisting the wires together is probably good enough.
Tape the joins to strengthen and insulate them.
Feb 08, 2011 | Samsung YP-Z5 MP3 Player
YP-Z5
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Jun 25, 2008 | Samsung YP-K3 MP3 Player
Music Files
try to connect it to another computer see wat happens if it recognises it format it
Apr 19, 2008 | Samsung YP-Z5 MP3 Player
Samsung YP-Z5
Vista = not compatible with this player
Apr 18, 2008 | Samsung YP-K3 MP3 Player
Playlist??
right click your playlist, add to sync list.
Mar 21, 2008 | Samsung YP-Z5 MP3 Player
Mtp sync problem
Try formatting the device
Nov 21, 2007 | Samsung YP-Z5 MP3 Player
I can't connect my samsung yp-z5 to the computer!!!
Try installing the Samsung Media package supplied with the player. Then restart your PC - all programs should then recognise the YP-Z5
Jan 16, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Sync with windows media player
I have the same issue where my pc won't recognise my mp3, or only occassionally does, and then locks up. The problem with media player is it eats up so much memory while trying to synch files / delete / add etc and brings your pc to a grinding halt. So the solution I'm told is the MS Synch Tool, download off MS site and use it rather than the player to switch your files. I'm trying it now.
Dec 09, 2006 | Samsung Yepp YP-Z5QB MP3 Player
Open Questions:
Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player Logo
222 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
