Question about LG LFX25960ST Stainless Steel French Door Refrigerator
LFX25960ST control pad does not stay lit
The Control Pad on the door of fridge used to have green lights that were lit all of the time. Now the lights only light up when you open the door or touch the pad. What happened?
I sounds as if you fridge is in power save mode as described on Page 19 of the manual. If you press the freezer and Ice Plus buttons simultaneously and hold them for 5 seconds you should hear a ding sound. The diplay operation should return to normal.
Posted on Feb 13, 2009
  • Denispekel Apr 26, 2011
    I did it but nothing happened
The unit is displaying a sequence of 5 flashes with the amber light. When I try to open the door, it will only go forward and backward aprrox. 1 ft. Any suggestions on what I should do?
Craftsmsman 1/2 HP opener indicator light blinks five times ...
? 0:29
https://www.youtube.com/watch?v=AvXJd-tYCJ0
Apr 28, 2012 - Uploaded by bship452
Then showing the amber indicator light blinking 5 five times, stops ... push remote to operate opener, you hear a clicking sound from the unit. ... Show more .... blink 5 times (looks almost alike) If I forced the garage door closed, ...Missing: sequence
Sears Garage door opener problem - Home Forums
ths.gardenweb.com > Home Forums > Garages/Workshops
Jun 27, 2006 - Now, I cannot get the light in the sensor at the door to come on. ... the green LED went OUT about 1/2 way up the door opening sequence. .... other is working (I don't recall if it's green or amber, but know that it is lit.) ... Their is also a green LEDflashing 2 times every 5 seconds or so at control center of unit.
Craftsman Garage Door Opener Problem - Home Forums
Jan 05, 2016 | Building Materials
LG gn253sqa electro cool- temp. control lights in fridge keep flashing and fridge not cooling so good, help?
This has happened to me a couple of times.The problem is that when the fridge door is opened too may times the warm air of summer will block the cold outlets in the fridge with ice.The cold air comes direct from the freezer and the chamber connecting to the fridge clogs up with ice.What one has to do is completely empty the fridge and freezer,leave open both doors so the the ice build-up can melt.Then after about at least 4-5 hours (very important to stick by this time-frame as I tried a less time,but it did not work.),close both the freezer and fridge doors and switch it on.After about 1/2 hour replace your goods in the fridge.The down-side of this is that you will need the kindness of a neighbor or two to use their fridge to store your food whilst this fix is underway..
Feb 28, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
Good Morning My name is Raj. I have a CRAFTSMAN Garage Door Opener 1/2 HP, model# 139.53635SRA (OR) T as the last letter. Issues: I cannot CLOSE Garage Door either with remotes or with key pad by...
If the main light flashes 10 times when the door reverses to the open position it is your door sensors. Make sure the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Sep 30, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door will close with the wall pad but when the remove or key pad is used the door reopens. How is this fixed?
If the main light flashes 10 times when the door reverses to the open position it is your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have a bad sensor.
Mar 01, 2011 | Sears Craftsman LiftMaster Chamberlain...
Door won't close, with out hold down on button.
If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit and not blinking.
Sep 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't open.
The most common cause of this problem is the door sensors have been bumped and misaligned. They each have a small light that should be lit and not flickering. Tweak them until they are pointed at one another and the lights are lit.
Jun 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
The wall button has a green light that is blinking and the car remote will not operate the garage door but the wall button works
this just happened to us today as well. the wall pad has three buttons: one large back-lit button pad to open it and a lock button and a light button. the open button was blinking quickly and would open the door, but the car remotes did not work. I found that by pushing both the "lock" and "light" button at the same time for about 3 or 4 seconds, the back-lit "open" pad stopped blinking and went to steady green. I went back to the cars and checked the remotes there. both opened the door.
hope this helps someone out there
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Control pad flashing temp and all lights continuously and ice door continually cycles open and closed
With the problems it is presenting, I would say it's very likely.
However it may take a bit of detective work to find which board is defective.
Check a part suppliers link Here for price comparison so you have some ideas.
Jun 26, 2008 | Kenmore TRIO 77314 Side by Side Bottom...
INSIDE LIGHT
I'd say the door switch is bad. Jiggle it. Spray some WD40 into it. But ultimately, remove it and test it for continuity. If there is no continuity in the door-open position, replace it.
But be careful. Some refrigerators have a second door switch with opposite function. It turns the fan OFF when the door is opened.
Jun 05, 2008 | Candy CPCA270FFK Bottom Freezer...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
270 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
