Question about Asko W6761 Front Load Washer
Fault Indication - "Over Flow"
Yesterday I was running high temp water through my empty machine - I find this keeps the drain hose clear. However, after 20 minutes the machine display flashed "Fault Indication - Over Flow" and water leaked from the bottom of the machine. I have checked the pin trap and cleaned out the soap dispenser. The machine won't move on from here. Any ideas what to do or what can be wrong?
  • 2 more comments
  • Anonymous Jun 01, 2008
    When the wash cycle is full and it starts to aggitate the water starts comming out the bottom.
    I have cleaned out the clean out.
    When I run a small load (1/2 water) it will drain properly
  • Di Nan Apr 28, 2009
    Everytime I wash towels I get the same fault - reason??
  • Anonymous Mar 29, 2014
    It seems that water is not getting through the hose for the 3rd compartement in the soap dispenser. I have checked the hose, no problem, when I disconnect it there is no water coming through, but it comes through on the first two hoses... what can the problem be?
    Hose going into soap dispenser no 3 is not taking in any water
    President:
  • 1,294 Answers
Does manual say to clear drain by running high temp water to clear drain; i dont think so. Now you have to unscrew the back to see where the leak comes from - by pouring plain water into the machine (where u put clothes). Unplug all electrical connections, ie disconnect the machine from the wall socket. Pl post back
Posted on Apr 19, 2007
  • prem mathew Apr 03, 2009
    Open the back of machine to observe where the leak comes from. You only have to tighten one of the clamps that have come loose, or replace any torn hose. Check out filter.
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
GWL11 washer not draining
That fault code is 37.
Disconnect from power & Bail out all the water you can before removing pump.
Here is some info on fault 37
37. (00100101) Pump Blocked Error (No change in the water level)
While draining, the water level reading from the pressure sensor has not changed for over 3
minutes. There are three likely reasons for this fault. One is that the drain hose or the
pressure switch hose has been squashed or kinked and the pump out rate has been
dramatically reduced. The second possibility is that the pump is partially or fully blocked.
The third is that the pump is not operating due to Motor Control Module, wiring or pump
failure. This fault could also appear if the machine is pumping to an unusually high head of
drain hose or into an extended length of drain hose. The fourth possibility is a diverter
valve fault or blockage, water level is not altering as the diverter is stuck in the recirculation
mode, giving the module the appearance the pump is not lowering the water level.
Primary Source: Pump System.
Action: 1) Check that the drain hose has not been kinked.
2) Check the length of the drain hose and try to reduce the length if
excessively long. A 1-metre extension hose of the same diameter
fitted to the existing drain hose is the maximum allowable length.
3) Check for open circuit windings in the pump. (Note: Pumps are
fitted with a thermal cut-out, which will reset on cooling.)
4) If the bowl is empty of water, remove the pump from the pump
housing and check that it is not blocked. Also check the drain
hose is not blocked.
5) If the bowl contains water, then service the pump from the top of
the machine by removing the top deck and inner bowl. Bail out the
water, remove the pump cap and hood and clear the restriction.
Secondary Source: Wiring.
Action: 1) Check the pump harness is connected correctly to the pump.
2) Check continuity of the pump harness.
Tertiary Source: Motor Control Module.
Action: Activate the pump by operating the machine in spin mode. Check the
pump is rotating. If it is not operating, and Primary and Secondary
checks have been performed, then replace the Motor Control Module.
Jul 26, 2012 | Fisher and Paykel Washing Machines
What does E20 mean
The E20 error code indicates a problem with water drainage. Inspect the drainage hose for kinks that could impede the drainage flow. This frequently occurs when the machine is pushed up against the wall without allowing room for the hoses. If there are no kinks, the hose is probably clogged. Carefully detach the hose from the machine, and use a garden hose to force water through it. If the water doesn't pass through, use a plumber's snake to clear the clog. If there is no clog, inspect the drain pump for clogs. Unplug the machine, and open the small rectangular door towards the bottom of the front of the machine. Drain the pump through the emptying hose into a container until the water flow stops, and rotate the pump impeller to clear any foreign objects. Close the pump and restart the cycle. If the problem persists, contact a service center.
May 18, 2012 | Zanussi ZWF1430W Front Load Washer
Stops in cycle and says f 02
F02 error is related to drain pump block.If the drain pump gets blocked or the drain hose is blocked the error comes up,this is indication of cleaning the drain pump and drain hose.If the drain pump and drain hose checked ok then its faulty drain pump,its not draining the water so the error f-02 is showing up. error F-02 is a slow drain problem. Remove the wide tapering pipe from the drum to the pump. Inside there is a non return ball valve. Clean this and see if that helps. Take the front bottom panel off and open the drain trap,and see if there is any thing got stuck up,like coins,nails,socks or any small cloth etc etc.--------------While removing the drain pump and drain hose for cleaning,please keep thick towel with you.As you disconnect the drain pump from its connection,lot of water will flow towards you,if your machine is filled with water.So keeping this towel with you will help to control this water flow towards you.This should help.Thanks.Helpmech.
Jan 19, 2011 | Washing Machines
Had blocked drain so water from sink backed up into d.washer. Drain clear but d.washer keeps emptying and won't fill
Make sure drain hose from dishwasher is higher than water inlet if not it will do just like a washing machine if the drain hose is lower than water level it will empty while filling.
Jan 19, 2010 | Dishwashers
Water left in machine, not emptying, light flashing
you may have an inefficient or partially blocked water pump remove drain hose and check if there is an obstruction if so clear it and re attach hose try draining machine listen to water flow if strong ok if not you still have an obstruction or faulty pump if no flow at all pump or control failed on final drain hope this assist you
Nov 05, 2009 | Bauknecht 24 in. GSX7551 Built-in...
Washer won't drain.
hi, to empty water manualy, lift the hose from the stand pipe, keep it above the water level, place a bowl on the floor and lower the hose into it, the water should drain out, to stop the water flow lift the hose above the drum and empty bowl, continue until empty, hope this help, thanks for using fixya
Feb 14, 2009 | GE WBSR3140DW Top Load Washer
F20 keeps appearing on our Whirlpool Duet Steam Washing machine. We cannot finish a load of laundry.
ck to see if fill hoses are connected correctly and you have good water flow through BOTH hoses to washer connection..if control senses slow fill it will f20..do not try to use cold water onlyauto temp will try to use hot to adj prest temps and will fault if no water flow detected if ok ckd screens in washer end to be sure they are clean ..also ck to see if drain hose is proper height and not in stand pipe too tight ..water may be siphoning out and washer will not fill in allowed time
Sep 17, 2008 | Whirlpool Washing Machines
W640 - Water Outlet Fault
I solved this problem this morning, after several months with intermittent "water outlet fault" error messages.
Our pin trap was cleared many times over the months. The propellor turned freely. However, the problem persisted.
So I unplugged the machine, removed the back panel (8 or so hex screws) and located the point where the drainage hose meets the water draining pump. I then separated the hose from the pump and found 2 United States 10-cent pieces lodged together with gunk that effectively blocked the drainage hose. 10-cent pieces ("dimes") are the perfect diameter to get stuck there and not appear in the pin trap where you could easily see and remove them.
Three loads later, the machine is working according to spec. Hope this helps.
Apr 09, 2008 | Asko W640
problem may be to with using very hot water which has dislodged sludge. fault may cure itself.at top of machine is a usually round device with 3 to 7 wires to it depending on type used. also connected is a small diameter hose. trace this hose to bottom of machine and it is connected into an air chamber. check air chamber is not clogged with sludge and if it is, clean it. remove small diameter hose and check not clogged as well and that there are no splits with it. there is really no need to clean appliance at all unless you are using liquid detergent which over time leaves a smell like drains. if you are, recommmend using powder
Apr 18, 2007 | Asko W6461 Front Load Washer
Asko W6761 Front Load Washer Logo
266 people viewed this question
Top Asko Washing Machines Experts
Marvin
Marvin
Sal De
Lollo Pop
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
